    MPCNC: Duet 3 + SBC + Dual Endstop for X and Y axes.
    Firmware installation
    1.2k
      @mtcl said in MPCNC: Duet 3 + SBC + Dual Endstop for X and Y axes.:
      M574 X1 S1 P"io1.in+io2.in"
      Ok how bout just sending the M574 command in the console by itself. If there's something wrong with it, it should complain.
      mtclundefined 1 Reply Last reply Reply Quote 0
      • mtclundefined
        mtcl @Phaedrux
        @Phaedrux said in MPCNC: Duet 3 + SBC + Dual Endstop for X and Y axes.:
        The fact that M119 isn't showing a status change makes me think the wiring isn't making a connection.
        That's exactly what i thought. So i checked each wire again (even before this message). I will do a more thorough test again, most likely tomorrow. I mean if one endstop wire was loose it would make sense, how come all four of them are reporting it incorrectly, right? (that too after me checking each one of them for continuity). Is it possible that it is the beta firmware?
        • mtclundefined
          mtcl @Phaedrux
          I just did that, I got a green message back for that as well.
          12/11/2020, 12:05:22 AM M574 X1 S1 P"io1.in+io2.in"
            Are you clicking both endstops when you check M119 or just one?
            mtclundefined 2 Replies Last reply Reply Quote 0
            • mtclundefined
              mtcl @Phaedrux
              I tried it both ways, but let me double check and try it again. Please gimme 2 minutes, i will run to garage and do this test and report back.
                It would also be good to do the more basic setup of single axis and single endstop just to confirm things are working and then add the complexity.
                There's also the SBC and Beta being added into the mix.
                It might also be worthwhile to temporarily switch over to standalone mode to rule out the SBC being the issue. That would involve getting a new SD card and setting it up with the folder structure for the duet and copying your config files over to the /sys folder. Put the SD card into the duet, disconnect the SBC, plug the ethernet into the duet.
                If that still doesn't work, could then upload the 3.1.1 firmware zip file to quickly check if it's a beta firmware issue.
                Those are some things to check. For now though I must sleep.
                • mtclundefined
                  mtcl @Phaedrux
                  @Phaedrux
                  Here are the two results.
                  First one is with both end stops depressed. Second one is with both released.
                  • mtclundefined
                    mtcl @Phaedrux
                    @Phaedrux
                    Thank you for the pointers. I will do these steps when I wake up myself. Your help is highly appreciated!
                      We're not crazy right? You have them wired correctly in your screen shot?
                      Duet 3: connect the switch between the IN and GND pins of your chosen IO_x connector.
                      • mtclundefined
                        mtcl @Phaedrux
                        @Phaedrux
                        That's absolutely correct. Only thing I can think of is the final white JST connector that is inserted into the duet may not be connecting properly?
                        I pulled them all out and will wire using individual ones and plug them in using more reliable black ones.20201211_002606.jpg
                        • mtclundefined
                          mtcl @Phaedrux
                          Those white connectors that came with official duet 3 were not making contact with the endstop pins, i removed them and replaced them with black dupont pins.
                          Thank you, it works well now!
                            Ok good, glad we're not crazy.
                            Did the crimp get a bit too crushed maybe? Or maybe the 5 pin connector just needs most of the wire spots populated to get enough pressure on the connector?
                            • mtclundefined
                              mtcl @Phaedrux
                              I think i will attribute it to my user error. I have never crimped those white ones (JST? right?). But for some reason I could test continuity in them from the housing, they were not connecting to the pin when they were inserted in.
                              I am glad that we are not crazy, for sure for sure!
                              • N7JTIundefined
                                N7JTI
                                I had a similar problem. I just bent the little pins before I put them in the connector for the one that had that problem.
