    Help
    Gcode meta commands
    • Leblondundefined
      Leblond
      Evening guys a question about Gcode meta commands for novices like me.
      Eg: sensors.probes [0] .value [0] is part of a command set? if so, where can I find these commands? if not how do i create them?
        Do you mean like this?
        https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
        Leblondundefined 2 Replies Last reply Reply Quote 0
        • Leblondundefined
          Leblond @Phaedrux
          @Phaedrux
          Maybe I explained myself wrong, forgive me.
          This is an example:
          G1 X {move.axes [0] .max-10} Y {move.axes [1] .min + 10}
          Between the braces, we find {move.axes [0] .max-10}
          What I'm asking is: is move.axes part of a command set? If so, where do I find these commands
          • Leblondundefined
            Leblond @Phaedrux
            @Phaedrux
            what I don't understand is the MOVE and AXES command in the link you sent me and that I had already seen I didn't find them
            • OwenDundefined
              OwenD
              Move and Axes are part of the object model which is used to query various parameters
              https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
              Think of it like a tree or a flow chart.
              Each object may branch out into other objects.
              Where it's necessary to identify the same parameter on many tools or axes, each one is allocated a unique identifier in an array. Arrays are surrounded by square brackets [ ]
              In the case of move.axes[0].min
              It will give the the axis minima you set for axis 0. (X) in your config.g using M208
              move.axes[1].min would be Y minima.
              You can the use curly brackets { } to allow you to do math based on the values.
              This allows you to write macros which will automatically update if you were to change the value in M208 for example
