    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Vetiundefined
      Veti
      well yes if you spend the time porting it yourself.
      otherwise you will be out of luck as very few people will have the raise controller board.
      there are ports for skr boards.
      • Proschi3Dundefined
        Proschi3D
        I think it must be possible.
        There is already Duet WiFi firmware on the Motionboard.
        Only on the control board where the WiFi module is located is Raise's own software or firmware.
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
          Proschi3D
            jay_s_uk
            have you seen they've released the source for their own build?
            It should be possible to build your own firmware and bring it up to date with current sources.
            https://github.com/Raise3D/Reprap-Raise3D-E2-Series
              Proschi3D
              my main concern is to be able to use the Duet Web App
              • Vetiundefined
                Veti
                see if you can install klipper on it.
                then you can install https://github.com/meteyou/mainsail which will give you a similar experience
                  dc42 administrators @Proschi3D
                  @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                  If it's running RRF and supports HTTP then you should be able to use DWC on it.
                  Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                    Proschi3D @dc42
                    @dc42 Is only the question how?
                    I'm not a specialist in the field
                      jay_s_uk
                      @Proschi78 what does the contents of the SD card for the board look like?
                      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                        Proschi3D @jay_s_uk
                        looks like this
                          jay_s_uk @Proschi3D
                          @Proschi78 so replace the contents of the www folder with the latest version of DWC from here. https://github.com/Duet3D/DuetWebControl/releases/tag/3.1.1
                          I suggest taking a backup of the sd card before you make any modifications
                          Proschi3Dundefined 2 Replies Last reply Reply Quote 0
                            Proschi3D @jay_s_uk
                            @jay_s_uk On the motion board map.
                            The control board on the display has no card in it.
                            it boots from internal memory
                              Proschi3D @jay_s_uk
                              @jay_s_uk thanks, I'll test that at noon today
                                Proschi3D
                                here again the pictures of the two cards.
                                with a description of the connectionsMotionboard.jpg Controller.jpg Controler 2.jpg
                                  jay_s_uk
                                  ah, that might be difficult then as the networking isn't handled by the control board and instead by the LCD screen.
                                  • Vetiundefined
                                    Veti
                                    can you post the output of m122?
                                      Proschi3D @Veti
                                      @Veti I do after work
                                        Proschi3D @jay_s_uk
                                        @jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                                        That's the problem
                                          If the pins for the dedicated SPI channel are available on the main board, then you might be able to connect an ESP12-based WiFi module to the main board.
                                          Proschi3Dundefined 1 Reply Last reply Reply Quote 2
                                            Proschi3D @dc42
                                            @dc42 how can I find out ?
