First Layer Way Too High / Extrusion is off?
851
    tmeryhew
    I'm not sure why my first layer is so high up above the bed. I downloaded the plugin for Duet in Cura. It sent the sliced file over to the printer no problem. But the first layer is not close to the bed.
    Below I have posted the first chunk of the print file gcode.
    ;FLAVOR:RepRap
    ;TIME:6861
    ;Filament used: 3.7848m
    ;Layer height: 0.2
    ;MINX:113.127
    ;MINY:90.906
    ;MINZ:0.2
    ;MAXX:179.789
    ;MAXY:129.093
    ;MAXZ:48
    ;Generated with Cura_SteamEngine 4.8.0
    T0
    M190 S50
    M104 S200
    M109 S200
    M82 ;absolute extrusion mode
    M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
    M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
    M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
    M220 S100 ;Reset Feedrate
    M221 S100 ;Reset Flowrate
    G28 ;Home
    G92 E0 ;Reset Extruder
    G1 Z2.0 F3000 ;Move Z Axis up
    G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
    G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
    G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
    G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
      3dML
      Have you calibrated the probe offset and stored the values with G31?
      undefined 1 Reply Last reply 18 Dec 2020, 22:42 Reply Quote 0
        tmeryhew @3dML
        @3dML
        I don’t have a probe yet.
          3dML
          Is the nozzle touching the bed if you move to z0 after homing?
            tmeryhew
            I homed all. Then used the controls in DWC to move the X and Y axis into position. Then I manually leveled the bed with a sheet of paper.
            After this I went ahead and re-tried the print file again for a simple Benchy. But now it seems like it's not putting out enough material. And the movement of X and Y are wayyy slower than it was with the original board.
            Any thoughts?
            undefined 1 Reply Last reply 19 Dec 2020, 16:14 Reply Quote 0
              Veti
              @tmeryhew said in First Layer Way Too High:
              check the filament setting in cura. the default is 2.85. its in the machine tab
              undefined 1 Reply Last reply 20 Dec 2020, 00:44 Reply Quote 0
                Stephen6309 @tmeryhew
                @tmeryhew Remove the lines with M201, M203, M204, M205, M220, M221, they're slowing down your printer. If you can, set the firmware to RepRap in Cura.
                undefined 1 Reply Last reply 21 Dec 2020, 19:07 Reply Quote 1
                  tmeryhew @Veti
                  @Veti
                  I’m on a Mac. Where specifically in the Machine tab? Are we talking in the Printers “Machine Settings” area?
                  2.85 what? mm/sec? What type of setting is the 2.85 referring to? Thanks!
                  undefined 1 Reply Last reply 20 Dec 2020, 03:39 Reply Quote 0
                    Phaedrux Moderator @tmeryhew
                    2.85mm filament diameter. Cura can sometimes default to that size instead of 1.75 because the Ultimaker printers use the larger filament.
                    You can get to the machine tab from the top menu items. Settings > Printer > Manage Printer
                    Then choose your printer from the list and click manage printer.
                    Then on the machine settings window that pops up you can change the gcode flavor to reprap. Remove the M201, M203, M204, and M205 lines from the start gcode.
                    Then in the extruder tab make sure it's set to 1.75 filament.
                    Post your full config.g and your homeall.g file as well.
                    Also the results of M122 and M98 P"config.g".
                    With all of that information we'll have a better idea of what's going on with your printer.
                    undefined 5 Replies Last reply 21 Dec 2020, 19:22 Reply Quote 0
                      tmeryhew @Stephen6309
                      @Stephen6309 I went ahead and deleted those and the printer is moving much faster. Thank you
                        tmeryhew @Phaedrux
                        @Phaedrux thank you for clarifying, I wasn't sure if we were talking about a speed setting or something else. The setting was in fact at 1.75 mm, so we're good there.
                        Below are some screenshots of my printer settings in Cura. However, I have installed the Duet plugin from the Ultimaker website. So far I have been able to send sliced files directly to my printer from Cura. Though, what settings are being incorporated into those G-code files seems ambiguous. Would it be pulling the Start / Stop gcode from this Preferences menu for what I have called "New Style" printer?
                        The last screenshot details what appears on my screen. The printer named "Genesis" is through the IP address to the printer. It's what I have named the printer on the Duet side of things. I wanted to be able to differentiate between the different settings areas.
                        undefined 1 Reply Last reply 21 Dec 2020, 19:50 Reply Quote 0
                          tmeryhew @Phaedrux
                          @Phaedrux here is the current "config.g" file
                          ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sun Dec 20 2020 20:13:30 GMT-0700 (MST)
                          M550 P"Genesis" ; set printer name
                          M551 P"REDwagon12!!" ; set password
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M569 P0 S0 ; physical drive 0 goes backwards
                          M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                          M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X9000.00 Y9000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X300 Y220 Z300 S0 ; set axis maxima
                          M574 X1 S1 P"^xstop" ; configure active-high endstop for low end on X via pin ^xstop
                          M574 Y1 S1 P"^ystop" ; configure active-high endstop for low end on Y via pin ^ystop
                          M574 Z1 S1 P"^zstop" ; configure active-high endstop for low end on Z via pin ^zstop
                          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                          M557 X15:285 Y15:205 S20 ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                          M143 H0 S100 ; set temperature limit for heater 0 to 100C
                          M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                          M143 H1 S250 ; set temperature limit for heater 1 to 250C
                          M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0.9 H-1 ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
                          T0 ; select first tool
                          undefined 1 Reply Last reply 21 Dec 2020, 23:36 Reply Quote 0
                            tmeryhew @Phaedrux
                            @Phaedrux here is the "homeall.g"
                            ; homeall.g
                            ; called to home all axes
                            G91 ; relative positioning
                            G1 H1 X-305 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                            G1 H2 X5 Y5 F6000 ; go back a few mm
                            G1 H1 X-305 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
                            G1 H1 Z-305 F360 ; move Z down stopping at the endstop
                            G90 ; absolute positioning
                            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                            ;G91 ; relative positioning
                            ;G90 ; absolute positioning
                              tmeryhew @Phaedrux
                              @Phaedrux M122:
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
                              Board ID: 08DGM-917DA-G4MSJ-6J1F4-3S06K-99PRB
                              Used output buffers: 3 of 24 (10 max)
                              Static ram: 27980
                              Dynamic ram: 93520 of which 24 recycled
                              Exception stack ram used: 256
                              Never used ram: 9292
                              Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                              Owned mutexes:
                              Last reset 00:37:09 ago, cause: power up
                              Last software reset at 2020-12-20 17:08, reason: User, spinning module GCodes, available RAM 9084 bytes (slot 0)
                              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                              Error status: 0
                              MCU temperature: min 20.3, current 26.7, max 27.1
                              Supply voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                              Date/time: 2020-12-21 12:26:23
                              Slowest loop: 147.19ms; fastest: 0.12ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 2.0ms, write time 0.0ms, max retries 0
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              === AuxDDARing ===
                              Heater 1 is on, I-accum = 0.0
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 155.28ms; fastest: 0.02ms
                              HTTP sessions: 1 of 8
                              Interface state active, link 100Mbps full duplex
                                tmeryhew @Phaedrux
                                @Phaedrux here is that M98 result
                                M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                                Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 413C
                                  tmeryhew
                                  So after deleting M201, M203, M204, M205, M220, M221 from the "Start G-Code" section of the printer settings within Cura, the status quo has changed a little bit.
                                  I also manually leveled the bed with the bed heater set at 50 C and 200 C for the nozzle.
                                    Yes.
                                    If you're still printing too high, you need to change either the position of the Z axis endstop switch so that the nozzle is just touching the bed when it stops, or set the actual distance between the nozzle and the bed in the homeall.g file.
                                    G92 Z0 could be changed to whatever the gap is between the bed and the nozzle. So if the nozzle is 1mm above the bed when the endstop switch is triggered, you'd use G92 Z1.
                                    Getting the bed nice and level will be the first thing. Beyond that you would need to use mesh compensation with a Z probe to measure multiple points on the surface of the bed to be able to adjust for a curved bed or other imperfections.
                                    undefined 1 Reply Last reply 21 Dec 2020, 20:05 Reply Quote 0
                                      tmeryhew @Phaedrux
                                      @Phaedrux
                                      So I believe I may have solved the issue of the extruder being too high off the bed, maybe. As soon as I can I will instal a Z probe as it seems that’s the best way to go.
                                      But check out my pictures below, what would cause my test prints to come out like this?
                                        If that's the bottom layer, likely over extrusion, either from being too close to the bed or extruding too much plastic.
                                        Maybe give this a read.
                                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                                        undefined 1 Reply Last reply 21 Dec 2020, 20:33 Reply Quote 0
                                          tmeryhew @Phaedrux
                                          @Phaedrux
                                          I added some more pictures to that post. I didn’t think you’d get to a response so quick!
                                          So are you saying I should go through and calibrate extruder steps per mm? Step 5 on that link you sent me?
                                          Also, since you seem to have so many answers to my questions, what do I need to do to turn on the part cooling fan (fan 0)? That seems to not be turning on automatically, even though I can go in and turn it on with the G-code commands.
                                          5 out of 25
