Duet2 WiFi Firmware on Raise 3d E2 ?
Firmware installation
10.9k
    Veti @Proschi3D
    @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
    the display controller is also operated via this interface
    they can easily just route the spi lines to the display.
    that is why the full M122 output is relevant.
    you probably did not update the wifi firmware when you updated to the rrf3 firmware.
    undefined 1 Reply Last reply 17 Dec 2020, 20:37 Reply Quote 0
      Proschi3D @Veti
      @Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
      I cannot update the WiFi firmware.
      because the wifi module is on a different board.
      and I have no access to it via the pc
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
        Veti
        the wifi firmware is not updated via the pc.
        see
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware
        but the M122 output is important
          dc42 administrators @Veti
          @jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
          iap4e.bin
          did you rename it to Duet2combinesIAP.bin like the error message says?
          Duet2CombinedIAP is not the same as iap4e.bin! Renaming it will not work. You can get Duet2CombinedIAP.bin from one of the RRF 3.x releases.
          undefined 1 Reply Last reply 18 Dec 2020, 07:43 Reply Quote 1
            Proschi3D @dc42
            @dc42 can I go back from V3.0 to V2.02 that easily?
            undefined 1 Reply Last reply 18 Dec 2020, 07:48 Reply Quote 0
              jay_s_uk @Proschi3D
              @Proschi78 that'll be why the downgrade didn't work then.
              use the IAP file dc42 linked to and the firmware from my google drive
              undefined 1 Reply Last reply 18 Dec 2020, 07:51 Reply Quote 1
                Proschi3D @jay_s_uk
                @jay_s_uk ok i will try today at noon
                  Proschi3D
                  Hello everyone here who helped me. I was able to successfully install a version that was before 2.02. Then the printer could be updated via the Raise software. The whole thing was worth it for me, because now I have the possibility to control it via octoprint for whatever reason. thank you again
                    Proschi3D
                    Do you think an original duet2 Wifi would work with the hardware components?
                    undefined 1 Reply Last reply 19 Dec 2020, 17:39 Reply Quote 0
                      Veti @Proschi3D
                      @Proschi78
                      not with the display, but you only did a third of the firmware update of rrf3. it might be that you could update the board to 3.1.1
                        Proschi3D
                        Yes that may be, but then I have no chance to use the display and control board. I am currently having the problem that the Gcode is being sent from the control board to the motionboard. This causes errors and the printer pauses printing, a stutter.
                          Veti
                          or if you want to invest some time and since you already have an octoprint server, run klipper with mainsail os.
                            Proschi3D
                            Here are two videos of the problem
                            https://youtu.be/esYPmuN4yWE
                            https://youtu.be/oTwaAePwyBw
                            undefined 1 Reply Last reply 19 Dec 2020, 18:04 Reply Quote 0
                              Veti @Proschi3D
                              @Proschi78
                              do you mean octoprint by control board to motionboard?
                                Proschi3D
                                No, I connected Octoprint directly to the Motionboard. As a result, I have no way of controlling it directly at the printer.
                                undefined 1 Reply Last reply 19 Dec 2020, 18:09 Reply Quote 0
                                  Veti @Proschi3D
                                  @Proschi78
                                  since you are running stock configuration now, i suggest you take that up with raise 3d.
                                    Proschi3D
                                    Do you think the error has been fixed with an original duet wifi + deux5 + display? The rest of the hardware would have to take part, since it is now based on a duet motionboard
                                      Proschi3D
                                      I ordered a duetwifi. I'm curious how it goes
                                        Proschi3D
                                        The duet wifi came today. I have a question about this, can I connect a second x axis instead of the second z axis?
                                          A Former User
                                          Sure, board doesn't know what you're connecting, and firmware only cares about the config.
                                          The two headers for the driver labeled Z are in series, and doesn't require any special configuration other than assigning driver 2 to x instead of z. To actually use two drivers you can follow the independent z axis instructions, just assign the drivers to x instead of z.
                                          Alternatively you can also wire two motors in series or parallel to any of the other outputs with custom wiring as needed.
                                          97 out of 169
