    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Proschi3Dundefined
      Proschi3D @jay_s_uk
      @jay_s_uk ok i will try today at noon
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
        Proschi3D
        Hello everyone here who helped me. I was able to successfully install a version that was before 2.02. Then the printer could be updated via the Raise software. The whole thing was worth it for me, because now I have the possibility to control it via octoprint for whatever reason. thank you again
          Proschi3D
          Do you think an original duet2 Wifi would work with the hardware components?
          • Vetiundefined
            Veti @Proschi3D
            @Proschi78
            not with the display, but you only did a third of the firmware update of rrf3. it might be that you could update the board to 3.1.1
              Proschi3D
              Yes that may be, but then I have no chance to use the display and control board. I am currently having the problem that the Gcode is being sent from the control board to the motionboard. This causes errors and the printer pauses printing, a stutter.
              • Vetiundefined
                Veti
                or if you want to invest some time and since you already have an octoprint server, run klipper with mainsail os.
                  Proschi3D
                  Here are two videos of the problem
                  https://youtu.be/esYPmuN4yWE
                  https://youtu.be/oTwaAePwyBw
                  • Vetiundefined
                    Veti @Proschi3D
                    @Proschi78
                    do you mean octoprint by control board to motionboard?
                      Proschi3D
                      No, I connected Octoprint directly to the Motionboard. As a result, I have no way of controlling it directly at the printer.
                      • Vetiundefined
                        Veti @Proschi3D
                        @Proschi78
                        since you are running stock configuration now, i suggest you take that up with raise 3d.
                          Proschi3D
                          Do you think the error has been fixed with an original duet wifi + deux5 + display? The rest of the hardware would have to take part, since it is now based on a duet motionboard
                            Proschi3D
                            I ordered a duetwifi. I'm curious how it goes
                              Proschi3D
                              The duet wifi came today. I have a question about this, can I connect a second x axis instead of the second z axis?
                                A Former User
                                Sure, board doesn't know what you're connecting, and firmware only cares about the config.
                                The two headers for the driver labeled Z are in series, and doesn't require any special configuration other than assigning driver 2 to x instead of z. To actually use two drivers you can follow the independent z axis instructions, just assign the drivers to x instead of z.
                                Alternatively you can also wire two motors in series or parallel to any of the other outputs with custom wiring as needed.
                                  jay_s_uk
                                  @Proschi78 did you ever get any reply from raise3d about the pinout/schematic of the board?
                                  Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                                    Proschi3D @jay_s_uk
                                    @jay_s_uk No, unfortunately not
                                      jay_s_uk @Proschi3D
                                      @Proschi78 disappointing
                                        Proschi3D @jay_s_uk
                                        @jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                                        disappointing
                                        yes it upsets me. but what should i do
                                          A Former User @Proschi3D
                                          @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                                          Is likely very resource demanding to anything other than asking; maybe EFF has some tips?
                                          Did you link them to this thread to rule out any lost in translation issues? I'd think they might care about the publicity of violating the license if they understood the issue.
                                          • Vetiundefined
                                            Veti
                                            they have released the source code. if they changed the pinout its in there.
                                            i think that satisfies the license.
