    Stepper motor
    290
    • Rattlemycageundefined
      Rattlemycage
      Hi, I replaced the stock board in a Chiron for a Duet2 WiFi. No matter what I did, I could not get the Z motors to turn, they would only vibrate. I had a second board so I just replaced it. Now the Z motors work but the X motor vibrates and moves in both directions for a few centimetres. I used the same SD card with each board. What am i doing wrong?
      Thanks
      • Vetiundefined
        Veti
        check the wiring. a bad crimp in the connections will cause this.
          Rattlemycage
          Have tried 3 cables and 4 stepper motors. Still the same, vibration but not turning.
          • Vetiundefined
            Veti
            are you sure you got the phases wired correctly?
              Rattlemycage
              It was working correctly on one board but the Z motors would not operate. replacing the board brought the Z motors into play but lost the X
              • Vetiundefined
                Veti
                are you sure you are running the correct current?
                • Stephen6309undefined
                  Stephen6309
                  Verify the stepper motor wiring is correct for the Duet. Other boards may not be the same.
                    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                    Check the phases. Check wire continuity.
                    Provide the results of M122.
                    • Tim N.undefined
                      Tim N.
                      Sounds to me like the two wires in the middle of the motor connector need to be swapped. Try that!
                      Duet 2 Wifi on Ender 3 (2019) // Duet 2 Wifi on Tronxy X5SA-500 Pro // (shared Printer: Duet 2 Wifi on Flash forge creator Pro)
                        Don't randomly swap wires around, you'll blow a driver.
                        Test to identify the motor coil phases and wire them accordingly.
