Underextrusion
    StaticRed
    Hey guys, im having another issue with my duet 2 ethernet board. I got now most of it working and printing works to one point, the extrusion. I use Cura for slicing, and set for the start a flow of 100%, but the prints look crappy. So i rechecked my steps/mm in my config.g and it looks fine. If i print with a flow multiplier of around 250% my prints look like a print, with a solid body. But why is it like this? Can anybody help me?
    Config.g:
    https://hastebin.com/umoceyitup.sql
    Start/End Gcode:
    https://hastebin.com/etiyuqiyir.properties
      PCR
      which extruder are you using?
      undefined 1 Reply Last reply 23 Dec 2020, 16:06 Reply Quote 0
        Veti
        check that you set the filament diameter to 1.75, the default in cura is 2.85.
        its in the machine settings
        undefined 1 Reply Last reply 23 Dec 2020, 16:22 Reply Quote 1
          StaticRed @PCR
          @PCR bmg direct drive
            StaticRed @Veti
            SOLUTION
            @Veti yep it was that, thank you!
            2 out of 5
