Duet2 Wifi Sing! HELP
Hi!
New on this forum and need some help...
I actually use a Duet 2 Wifi with RRF 3.1.1 on my CR10 (dual Z motor, indepedant driver) and when my bed is hot and the hotend start to heat my Duet "sing" but I don't know why...
If anyone know this problem and can help me...
https://www.youtube.com/watch?v=WLYqSekXPsoSlicer: Cura
CR10: E3D V6 Titan Extruder direct drive 12v
12v heat bed Without mosfet
Stock supply from Cr10If you need some info let me know!
Ps: Sorry for my english, I try to do my best, I'm French ><
are you sure its the duet and not the power supply?
This post is deleted! -
On the video you can see the Duet "sing" in the same time of the LED for me it's the Duet but the issue can come from the supply yes....
@Kawadarze
the led turning on means more power is being drawn as power is supplied to the bed.
this puts more pressure on the power supply.therefore the led turning is is no indication that it is the duet.
Thanks for indication, I try with another power supply tomorrow
Have you PID tuned the bed and hotend heaters?
@Phaedrux yes, I did it...
