    z motor not driving when connected to leadscrew
    My Duet controlled machine
    1.8k
      post your config.g and a photo of your wiring and the gcode you're trying to execute?
      • Ian Millerundefined
        Ian Miller
        There is no specific gcode I am trying to run, this just happens with any type of z move so I have been using the z hop of the x home to test.
        M569 P1 S0 ; physical drive 1 goes Backwards
        M569 P4 S0 ; physical drive 3 goes forwards
        M584 X0 Y1:4 Z2 E3 ; physical drive 4 goes Backwards
        M350 X16 Y16:16 Z16 E16 I1 ; configure microstepping with interpolation
        M92 X80.00 Y80.00:80.00 Z1600.00 E420.00 ; set steps per mm
        M566 X900.00 Y900.00:900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00:600.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00:500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
        M906 X800 Y800:800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X950 Y650 Z500 S0 ; set axis maxima
        M574 Y2 S1 P"ystop+e1stop"
        M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        M557 X50:900 Y50:600 S50 ; define mesh grid
        M143 S265 ; Set maximum heater temperature to 265C
        M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
        M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
        M563 P0 D0 H1 ; Define tool 0
        ; Custom settings
        M552 S1
        Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @Ian Miller
          @Ian-Miller said in z motor not driving when connected to leadscrew:
          You don't need the double values for Y. It's per axis, and not per motor.
          Which drivers are you using for which axis?
          Your photo shows two motors connected to driver 4, but your config shows Y is using driver 1 and 4.
            Ian Miller
            So essentially this printer has 2 Y axis drivers because I'm trying to set them up to use independent endstops to home themselves then drive together for the combined y motion. Each one of those drivers drives 2 motors witch are wired in parallel. Witch is why I thought i needed the double values for y because I'm trying to make the printer use one of the unused extruder drivers to to drive the 2nd set of y drivers. I'm using every driver on the board for its intended axis except for E1 witch is the other side of the Y. And to answer your last question, I don't know how the drivers are numbered but as I said all but E1 is used as the board diagram shows.
              A Former User @Ian Miller
              dual z motors because they are wired in parallel
              the default wiring on the duet is for the two z motors to be in series, if you have wired them in parallel instead you should probably increase the current as its now shared between the motors. (although if the board is a 1oz copper clone you might not want to push the drivers too hard)
                Ian Miller
                Sorry I misspoke the z motors are wired to the board as is standard. But for the Y motors they are wired in parallel 2 motors to a single driver.
                (sorry for the confusion)
                The power supply is a standard cr-10 power supply and should have more than enough power for the motors.
                Additionally if it would help to upload a video of the problem I can do that.
                  would probably help to know if its a 24v or 12v supply for those of us wihtout a cr-10, motors in series will benefit from higher supply voltage as they have to share the voltage while the current is the same through each motor
                    Ian Miller
                    Its a 12v power supply
                    • theruttmeisterundefined
                      theruttmeister
                      Ignoring the Y axis setup.
                      I'd start with increasing the current to Z, it sounds like there isn't enough power to turn both motors.
                      If that doesn't fix it I'd check the Z motor wiring, bad crimps are a common cause of intermittent motor issues.
                      Are you getting any error messages? The Duet will normally detect when most of the common issues with the drivers/motors happen and give you an error in DWC or via the PanelDue. I assume you are using DWC?
                      And can you post your homex.g ? Its probably not that, but it what you are running to generate the issue.
                      Isolate, substitute, verify.
                        Ian Miller
                        How would I go about increasing the current? Is there a potentiometer that I should use on the board to do that?
                        Additionally would it be worth trying to wire them both to a single set of pins on the board so they got equal current?
                          Change Z800 to f.ex. Z1200 to change current from 0.8A to 1.2A.
                          But as the motors are wired in series they're already receiving 0.8A (each) like all the other motors. It would be the power supply voltage limiting the speed they can run at compared to the single motors.
                            Ian Miller
                            I did what you asked about increasing the current. Each motor is only rated to 0.33 amps. Each motor is working intermittently and is is active but failing. The motors themselves should be able to lift the load. I will be checking the crimps and doing a little test with any tension on the leadscrews. Just to help I'm providing a video of the printer. IMG-5149-1.mp4
                              Ian Miller
                              Tested with multimeter and redid wiring, the motors are able to drive both ways but function is still intermittent.
                              error message says 12/27/2020, 1:57:12 PM G28 X
                              Warning: motor phase A may be disconnected reported by driver(s) 2
                              Warning: motor phase B may be disconnected reported by driver(s) 2
                              Homex.g
                              G91 ; relative positioning
                              G1 H1 X-955 F1800 ; move quickly to X axis endstop and stop there (first pass)
                              G1 H2 X5 F6000 ; go back a few mm
                              G1 H1 X-955 F360 ; move slowly to X axis endstop once more (second pass)
                              G1 H2 Z-5 F6000 ; lower Z again
                              G90 ; absolute positioning
                              Additionally I have problems with some endstops as well but I'm trying to figure those out myself but that's why the homing for x isn't happening.
                                would suggest the wiring is questionable or motors have high inductance (in which case you'll need to not run them in series or increase the supply voltage)
                                  Those are quite small motors. How much does the gantry weigh? How much compliance is there in the gantry? When they aren't perfectly even they are likely binding a bit and the motors aren't very powerful. I think they may not be suitable for your Z axis. Do you have the specs for them?
                                    Ian Miller
                                    I tried wiring them in parallel and now neither motor activates whatsoever, but I will work on that.
                                    As for the motor specs I will post them below. The entire gantry the 2 motors are lifting is between 2.5 and 3 pounds.
                                      I can't make anything out on that blurry image.
                                      • Vetiundefined
                                        Veti
                                        are you aware that you have bought a cloned board?
                                        those motors are not suitable for 3d printers
                                        https://images-na.ssl-images-amazon.com/images/I/A1N+z7VtiNL.pdf
                                        see
                                        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
                                        Avoid motors with rated voltage (or product of rated current and phase resistance) > 4V or inductance > 4mH.
                                          Ian Miller
                                          I did not realize that those motors were not ok with 3d printers, I'm using them for driving every other axis on this machine and they all 5 seem to be working well. Do you recommend I just get new motors for that axis or is there anything else I can try?
                                          Btw thank you guys for all the tips and ideas, I'm only 15 and this is my first fully custom printer build.
                                          • Vetiundefined
                                            Veti
                                            this is incorrect, y does not allow for double settings.
                                            delete the second y entry.
                                            also if your motors are 0.33A you are running them with 0.8A, you might have damaged to motors.
