    motor phase A may be disconnected help a newby out
    645
    • Fisherundefined
      Fisher
      cables came with the motors, the small ammount of movement i am getting is in the correct direction when homing.
        Check your motor phases are paired correctly and that the crimps are good.
        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
          Driver 2 is the one marked Z. There are two output connectors for that driver, connected in series. If you have only one Z motor, do you have 2 jumpers in the second Z motor connector? If it's a genuine Duet, it should have been supplied with those jumpers already fitted.
          Nellorundefined 1 Reply Last reply Reply Quote 0
          • Fisherundefined
            Fisher
            solved: incorectly wired endstops... i knew it would be somthing silly, thanks all the same.
            • Nellorundefined
              Nellor @dc42
              Im running the current version 3.2-RC2 (2020-12-24) at a Duet 3 6HC
              When homing the Y-Axis I get a warning:
              Warning: motor phase A may be disconnected reported by driver(s) 2
              Warning: motor phase B may be disconnected reported by driver(s) 2
              What does the number 2 means? Thought it indicates the corresponding drivers in that case number 1.
              I only connected Y at the Driver_1 connector and the corresponding endstop.
              M569 P0.0 S0 ; physical drive 0.0 goes backwards
              M569 P0.1 S0 ; physical drive 0.1 goes backwards
              M569 P0.3 S0 ; physical drive 0.3 goes backwards
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
              What wonders me even more is if I try to Home X - of course no motor/endstop is connected to X I get the same warning.
                A Former User @Nellor
                @Nellor said in motor phase A may be disconnected help a newby out:
                probably best to start a new thread rather than continuing someone elses solved thread.
                drivers are usually
                0=x
                1=y
                2=z
                3=e0
                4=e1
                edit: d'oh .. the duet3, unlike they duet 2, the numbers match the pcb silk screen so just refer to the board and see what you've connected to driver2.
                • Nellorundefined
                  Nellor @A Former User
                  @bearer
                  I posted that here as maybe something is wrong with the number indication at the warning where DC42 assumed the thread opener is talking about Z - I assume he never talked about z axis...
                  With your explanation it makes even more no sense with the warning.
                  I will delete or shift the post if it is a big problem.
                    A Former User
                    its not a problem as such; its just not easy for others to relate to a solved topic with a new question, and notifications go to everyone else, but not necessarily you etc.
                    • Nellorundefined
                      Nellor
                      Ok, got it... will delete or move it.
                      I found out whats the reason of getting it when I Home Y.
                      • If nothing else is wired besides the Y-Axis you will get all the time this warning. So i assumed it must be Y related even showing Z.
                      • If you don't know that a Y movement results also in a short Z move/lift you end up with not understanding whats going on...
                      • In my case even a Duet Maestro connected before at this build stage without warning.
                      -> Hooked up also a Z Motor and the warning is gone.
                        Phaedrux Moderator @Nellor
                        @Nellor Your homing file probably has a Z lift.
