    Duet3 Mainboard CNC Mill
    21
    1.3k
    • R4ffersundefined
      R4ffers @dc42
      @dc42 This looks excellent, i have only just started with duet3d and so far I'm impressed.
      Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        I've created a discussion thread for the DWC preview in the CNC forum.
        https://forum.duet3d.com/topic/20416/preview-version-of-cnc-optimized-dwc
        Shanian79undefined 1 Reply Last reply Reply Quote 1
        • Shanian79undefined
          Shanian79 @Phaedrux
          I got my mill up and running on my Duet3 with the Workbee version of DWC.
          What is the best post processing option from Fusion360 to use with Duet?
          jay_s_ukundefined R4ffersundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Shanian79
            @Shanian79 i would use the workbee post processor.
            haven't seen any others about.
            Theres a modified version about as well that allows the spindle to be controlled through gcode
            http://www.makergeek.co.uk/makergeek/2019/8/3/improved-duet3d-fusion-360-post-processor-for-ooznest-ox
            • R4ffersundefined
              R4ffers @Shanian79
              @Shanian79 did you have to do much to get it working?
              Shanian79undefined 1 Reply Last reply Reply Quote 0
                Shanian79 @R4ffers
                @R4ffers No not really. 10x simpler than setting up a printer. Just setting up the config and wiring up the steppers is all it really took. I set it up with sensor-less homing, which I haven’t done before. That took me a little over an hour to get figured out dialed in. Overall it’s really simple for a 3 axis.
                The workbee DWC is very simple and straight forward.
                R4ffersundefined 1 Reply Last reply Reply Quote 0
                • R4ffersundefined
                  R4ffers @Shanian79
                  @Shanian79 excellent well done. I've just finished building a CNC router using ooznest ox plates. I'm currently using grbl on a protoneer pi hat but have finally made the plunge and bought the duet 3 m6hc. I have made a test bed and installed endstops and steppers with a dual y axis, got things to finally start and stop last night. Been a big learning curve.
                  • tenajaundefined
                    tenaja @dc42
                    @dc42 said in Duet3 Mainboard CNC Mill:
                    I'm glad you find Duets meet your needs!
                    There is a preview of the CNC version of DWC at https://github.com/Duet3D/DWC-CNC/releases.
                    Sounds like progress towards CNC use!
                    Can it work on duet2 wifi?
                    Can it work without needing the fake printer things, like extruders?
                    Thanks!
                    jay_s_ukundefined A Former User? 2 Replies Last reply Reply Quote 0
                      jay_s_uk @tenaja
                      @tenaja yes, it works on the duet 2.
                      Just make sure you use M453 to set the machine in CNC mode
                        A Former User @tenaja
                        @tenaja said in Duet3 Mainboard CNC Mill:
                        yes
                        thats just a RRF thing, not DWC, see https://duet3d.dozuki.com/Wiki/Gcode#Section_M453_Select_CNC_Device_Mode
