need some help please Duet 2 Wifi BL touch Ender 3
@Zayy said in need some help please Duet 2 Wifi BL touch Ender 3:
do you have a discord I could get in contact via a call with you
we want the information available for everyone. the forum is a important part of the community info.
if we move to discord this dissipaters. -
@Zayy For 3.0 to 3.2rc2, endstops need the pin.
My defines:
M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 1.io1.in
M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^121.io0.in" H10 F120 T6000 ;A2 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-11 Y-50 Z0 ; set Z probe trigger value, offset and trigger height
M557 X10:400 Y10:300 S30 ; define mesh grid -
@Stephen6309 should i copy what you have because i honestly do not know what it should say and im lost. sorry i feel bad for not knowing but i basically have a $400 metal brick on my desk at this point
@Veti i do not even know what rrf2 config please elaborate
its the firmware version you selected in the first step.
the config you posted is for version 2
in the screenshot you posted of the configurator, you selected version 3
the config version needs to match the installed version
so post your new config.g and homing and retract and deploy scripts.
still showing up as "M574 X1 Y2 S1"
this is not the config that the online configurator with version 3 produces. you need to replace your existing config with the new ones.
@Veti someone went through and helped me reconfig the whole thing thank you for the help.
