need some help please Duet 2 Wifi BL touch Ender 3
your homing scripts still assume there is a z endstop.
copy the generated homing scripts from the configurator. there should be a G30 in them when homing z.G31 P50 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
you forgot to define all offsets. this will cause problems. you need to define x y and z.
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M280 P3 S10 I1 ; deploy BLTouch
this does not match. your deploy scripts and heater configuration must be identical.
@Zayy said in need some help please Duet 2 Wifi BL touch Ender 3:
"response to long. see console"
So go to the console for the full response.
@Phaedrux it gives me this with the M98 gcode
Warning: Macro file config-override.g not found.
12/29/2020, 5:42:18 AM M98 P"config.g"
Warning: M918 command is not supported
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled...and this with the M122 gcode
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MS8-6JKF6-3S86R-19GAN
Used output buffers: 1 of 24 (9 max)
Static ram: 25712
Dynamic ram: 93184 of which 44 recycled
Exception stack ram used: 272
Never used ram: 11860
Tasks: NETWORK(ready,900) HEAT(blocked,1232) MAIN(running,3752) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:55 ago, cause: software
Last software reset at 2020-12-29 05:42, reason: User, spinning module GCodes, available RAM 11860 bytes (slot 2)
Error status: 0
Free file entries: 10
MCU temperature: min 33.5, current 35.2, max 35.2
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-12-29 05:43:55
Cache data hit count 338494399
Slowest loop: 5.26ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.43ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 84:0d:8e:b2:6c:8a
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22688
WiFi IP address 10.0.0.237
WiFi signal strength -48dBm, reconnections 0, sleep mode modem
- WiFi -
@Veti i have the z endstop still plugged in and i have the BL touch plugged into probe input on the board, and i just updated to the latest version so the config tool is different now it looks like this...
in https://configtool.reprapfirmware.org/Endstops you need to select z probe for z or the bltouch will not be used.
@Veti do you have a discord I could get in contact via a call with you because it honestly feels like I've taken 2 steps forward and 3 steps back because after I updated the firmware to 3.1.1 its now giving me a "G28 X" error saying it failed to enable endstop.
@Zayy How do you have your endstops defined in config.g? They not in the config.g you posted.
@Stephen6309 im sorry but what exactly do you mean. I have them in the first screenshot it shows
M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min -
M574 X1 Y2 S1 ;
that is the rrf2 config, you need to switch to rrf3 config
we want the information available for everyone. the forum is a important part of the community info.
if we move to discord this dissipaters. -
@Zayy For 3.0 to 3.2rc2, endstops need the pin.
My defines:
M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 1.io1.in
M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^121.io0.in" H10 F120 T6000 ;A2 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-11 Y-50 Z0 ; set Z probe trigger value, offset and trigger height
M557 X10:400 Y10:300 S30 ; define mesh grid -
@Stephen6309 should i copy what you have because i honestly do not know what it should say and im lost. sorry i feel bad for not knowing but i basically have a $400 metal brick on my desk at this point
@Veti i do not even know what rrf2 config please elaborate
its the firmware version you selected in the first step.
the config you posted is for version 2
in the screenshot you posted of the configurator, you selected version 3
the config version needs to match the installed version
so post your new config.g and homing and retract and deploy scripts.
still showing up as "M574 X1 Y2 S1"
this is not the config that the online configurator with version 3 produces. you need to replace your existing config with the new ones.
@Veti someone went through and helped me reconfig the whole thing thank you for the help.
