    PanelDueFirmware 3.2.6 released
    PanelDue
    10
    25
    1.3k
    • Cobaltundefined
      Cobalt @wilriker
      @wilriker
      now added this line to config.g M575 P1 B57600 S1. but bunch of stuff popping up at start. like (tool not selected) and more. but after that works .
      • soccerpaulundefined
        soccerpaul
        Hi, I have a multi-heater tool on my printer. It displays well in web control, but on the PanelDue the second and third heaters line up with the wrong tools (EDIT: actually, after rechecking they just aren't displayed. Only the first heater is visible). I'm running version 3.2.6 of the firmware but I believe this was the case in previous versions as well.
        • wilrikerundefined
          wilriker @soccerpaul
          @soccerpaul said in PanelDueFirmware 3.2.6 released:
          Yes, that is still a limitation of PanelDueFirmware. It will only display the first heater of each tool due to space constraints. 3.2.5 added support for a heater being shared across different tools (not your setup, obviously) which was also not supported earlier but multi-heater tools are not yet supported. I have some ideas on how to solve this but it might be a few releases out until I can really get to it. But right now release-cycle is pretty quick. 😉
          Manuel
          My Tool Collection
          • medicusdkfzundefined
            medicusdkfz
            @Cobalt said in PanelDueFirmware 3.2.6 released:
            M575 P1 B57600 S1
            I got a "Error: Failed to communicate with PanelDue bootloader (no START signal received)."...
              medicusdkfz
              My fault: Forget to erase and reset...
              Everything works fine.
              Thank you!
              • R4ffersundefined
                R4ffers @observatoer
                @observatoer Hi there, did you get anywhere with this? i've just got the same message on a brand new 7i.
                Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                  dc42 administrators @R4ffers
                  @R4ffers said in PanelDueFirmware 3.2.6 released:
                  Upgrade RepRapFirmware to 3.2RC2.
                  R4ffersundefined 2 Replies Last reply Reply Quote 0
                  • R4ffersundefined
                    R4ffers @dc42
                    @dc42 , ok will do. thanks.
                    • R4ffersundefined
                      R4ffers @dc42
                      @dc42, Hi there i've just noticed i'm running rrf3.1.1 on duet 3 with rpi4 even though i have run the sudo apt-get update sudo apt-get upgrade
                        A Former User @R4ffers
                        @R4ffers that is the last stable version. You'll need to switch to the unstable repo to use the beta and release candidate versions.
                        ; ref second paragraph https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
                        Edit: autocarrot
                        • R4ffersundefined
                          R4ffers @A Former User
                          @bearer , thanks for that. Do you have to remove the stable package feed first?
                          • R4ffersundefined
                            @bearer ,sorted now thankyou
                              A Former User @wilriker
                              @wilriker
                              First: Thanks for your great work! Nice upgrade for me from PDF1.x to PDF3.x -> now a nice screensaver and so much more
                              my setup this post refers to: duet-ethernet1.4 -> from RRF3.1.x upgraded first to RRF3.2RC2, the actual install of PDF3.x was easy via "M9... S4"!
                              Just a curious thing hapened: When I use the paneldue to home all axis and not do it via DWC, then the paneldue (and only paneldue not DWC) throws at the end when it sucessfully finished all homing, that the "homing failed" -> BUT in both paneldue & dwc the axis are marked as "homed" and can be jogged -> Is this just some wrong link to some message that is not intended to pop up OR (since it is the only thing I changed in between) could it be related to current-dimming of the motors which is the only thing I integrated in the homing files before upgrading from RRF3.1&PDF1.x (and I have not checked if it worked before upgrading)?
                              homeall.g (Sorry: Please ignore those "{1}" since they are not present in my code but just on this website here(?)!):
                              ; homeall.g
                              ; called to home all axes
                              ;M300 S300 P1000	; beep a sound (requires piezo e.g. on the PanelDue it is integrated) S___ frey Hz, P___ in milli-sec
                              M117 "homeall.g starts..." ; display message on screen, e.g. the PanelDue
                              ;let the user aknowledge (double check)
                              M291 R"Homing all axis?" P"make sure nothing is in the way" S3 ;T5
                              ;first check if any axes are not homed and optionally home them
                              ;while iterations < #move.axes
                              ;	if !move.axes[iterations].homed ; check if each axis is homed
                              ;		M291 P{"Axis " ^ move.axes[iterations].letter ^ " is not homed.  Home now?"} R"Axis un-homed" S3 ; continue or abort?
                              ;		M98 P{"0:/sys/home" ^ (move.axes[iterations].letter) ^ ".g"} ; home axis if answer is OK - G28 doesn't accept object variable so run macro
                              ;if !move.axes[0].homed
                              M98 P"homex.g" ; check for correct directory, default folder is /sys on sd-card
                              ;if !move.axes[1].homed
                              M98 P"homey.g" ; check for correct directory, default folder is /sys on sd-card
                              ;if !move.axes[2].homed
                              M98 P"homez.g" ; check for correct directory, default folder is /sys on sd-card
                              M117 "...finished homeall.g"  ; display message on screen, e.g. the PanelDue
                              M292						; clear all messages
                              homex.g (Sorry: Please ignore those "{1}" since they are not present in my code but just on this website here(?)!):
                              ; homex.g
                              ; called to home the X axis
                              M117 "homex.g starts..." ; display message on screen, e.g. the PanelDue
                              G53				   ; use abs machine coordinates, without translation, tool-offset, ...
                              G91                ; relative positioning
                              ;lift z (to not hit anything):
                              M98 P"z-do-lift.g"  ; check for correct directory, default folder is /sys on sd-card
                              M400				;M913 does not wait and therfor needs an M400 in advance
                              M913 X75			;set current for defined motor in % of 100 as defined within M906 (in config.g)
                              G1 H1 X{-(move.axes[0].max+10)} F1500   ; move quickly to X axis endstop and stop there (first pass)
                              G1 H2 X5 F750     					  ; go back a few mm
                              G1 H1 X{-(move.axes[0].max+10)} F100    ; move slowly to X axis endstop once more (second pass)
                              M913 X100			;set current for defined motor in % of 100 as defined within M906 (in config.g)
                              G1 H2 X2.5 F100     ; go to what shall be "0" (a little bit away from endstop)
                              G90       		    ; absolute positioning
                              G92 X0              ; set _ position to axis val__, in absolut coordinate system (G90)
                              ;move Z back:
                              M98 P"z-un-lift.g"  ; check for correct directory, default folder is /sys on sd-card
                              M564 S1 H1				; Limit axis: S for boundaries 0=allow/1=limit; H for homing 0=allow/1=limit
                              G0 F1500				; set min feed back
                              G1 F1500   				; set min feed back
                              M117 "...finished homex.g" ; display message on screen, e.g. the PanelDue
                              homey.g (Sorry: Please ignore those "{1}" since they are not present in my code but just on this website here(?)!):
                              ; homey.g
                              ; called to home the Y axis
                              M117 "homey.g starts..." ; display message on screen, e.g. the PanelDue
                              M913 Y75			;set current for defined motor in % of 100 as defined within M906 (in config.g)
                              G1 H1 Y{-(move.axes[1].max+10)} F1500 ; move quickly to Y axis endstop and stop there (first pass)
                              G1 H2 Y5 F750       ; go back a few mm
                              G1 H1 Y{-(move.axes[1].max+10)} F100  ; move slowly to Y axis endstop once more (second pass)
                              M913 Y100			;set current for defined motor in % of 100 as defined within M906 (in config.g)
                              G1 H2 Y2.5 F100     ; go to what shall be "0" (a little bit away from endstop)
                              G92 Y0              ; set _ position to axis val__, in absolut coordinate system (G90)
                              ;move Z back:
                              M117 "...finished homey.g" ; display message on screen, e.g. the PanelDue
                              homez.g (Sorry: Please ignore those "{1}" since they are not present in my code but just on this website here(?)!):
                              ; homez.g
                              ; called to home the Z axis
                              M117 "homez.g starts..." ; display message on screen, e.g. the PanelDue
                              M290 R0 S0		   ; clear any "baby"(/micro)-steps (they currently apply only to z), In RRF>=1.21 homing&||bed probing don't reset babystepping
                              ;make sure z has some distance to endstops:
                              M913 Z80			;set current for defined motor in % of 100 as defined within M906 (in config.g)
                              ; split Z motor control to Z and U
                              ; for it to work we have to show U (param P4) in the UI
                              M584 Z2 U4 P4
                              G1 H1 Z{-(move.axes[2].max+10)} U{-(move.axes[2].max+10)} F500 		; move Z1=Z & Z2=U down until each endstop for its axis is triggered
                              G1 H2 Z5 U5 F1500  			; lift Z relative again to current position
                              G1 H1 Z{-(move.axes[2].max+10)} U{-(move.axes[2].max+10)} F80 		; move Z1=Z & Z2=U down until each endstop for its axis is triggered
                              ; back to combined z-axis & hidden U-axis (since combined) in Gui via the Px
                              M584 Z2:4 P3
                              M913 Z100			;set current for defined motor in % of 100 as defined within M906 (in config.g)
                              G90						; Back to absolute positioning
                              G92 Z0            		; set Z position to axis minimum (you may want to adjust this), in absolut coordinate system (G90)
                              ;move tool away from plate again
                              M117 "...finished homez.g" ; display message on screen, e.g. the PanelDue
                              Edit: Related to the behaviour of M291 in RRF3.2
                              • wilrikerundefined
                                wilriker @A Former User
                                @LB Short answer is that PanelDueFirmware only displays messages that it received from RRF. There is no hard-coded message (in a popup) in the firmware. So in this case it must have received this error from RRF.
                                I've looked up the reason for "homing failed" a couple of times in the past but I can never remember what is the cause. @dc42 can you help out here?
                                Manuel
                                My Tool Collection
                                  "Homing failed" is generated when a G28 command is executed but it didn't result in all of the specified axes being flagged as homed. All the requested axes will be flagged as "not homed" at the start of executing G28.
                                    A Former User @dc42
                                    @dc42 said in PanelDueFirmware 3.2.6 released:
                                    Thanks! Since everything works it might have to do with the specific setup and my specific code? For now I will just ignore it and dig deeper when I will find time.
                                    Edit: Thanks to @deckingman we know that my issue is related to RRF3.2 and the behaviour of M291 within homing files
                                    • wilrikerundefined
                                      wilriker
                                      I have now released PanelDueFirmware 3.2.7. I will lock this thread. Please continue over there.
                                      Manuel
                                      My Tool Collection
