Unsolved Pause.g Resume.g problems
@Deluxe-600 said in Pause.g Resume.g problems:
; resume.g
; called before a print from SD card is resumed
G28 X Y ; home X and Y
G1 R1 X0 Y0 Z5 F4000 ; go to 5mm above position of the last print move
G1 R1 X0 Y0 ; go back to the last print move
M83 ; relative extruder moves
G1 E10 F3600 ; extrude 10mm of filamentAssuming this is still your resume.g you should add something there to home z as well as XY
Now my resume.g looks like this
T0 ; activate tool again
M116 ; wait for all temperatures.
M98 P"homex.g" ;
M98 P"homey.g" ;
G1 E10 F3600 ; extrude 10mm of filament -
@Phaedrux it works as it is. Now i am trying to figure out why is it not working trough the "resume" button but trough macro (M98 P"resume.g") it does. I thought that the button calls the macro just liek the command?
Firmware version?
@Phaedrux RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
The resume button uses M98 P"resume.g" right?
I believe so, yes. The only difference that comes to mind is maybe which gcode stream the commands is coming through.
@Phaedrux What can i do to make it work properly? I would like to use the normal web control buttons. If possible
@Deluxe-600, what happens when you press the Resume button?
@dc42 The printing head goes back to the saved position lowers to the print and then "G0/G1: insufficient axes homed" error and cancels the print. I can change whatever i want in the "resume.g" file but nothing changes.
This is just weird. If i create a macro for resume in which i have :
M98 P"homex.g" ;
M98 P"homey.g" ;
M106 P0 T1 ; restores the previous fan speed
M83 ; relative extruder movesIt does all it should but then it just moves above the print and pauses.
Then i have to push the "Resume" button in the interface. It homes again and then starts printing....but if i dont run the macro first it doesnt home or wait for the tool to heat up. It just moves above the print and then throws an error messeage. I realy dont know what to do . Im fighting it for the last 4 days. -
The button is checking to see if any axis are unhomed and will not run if it's unhommed. Which is why when you force resume.g to run and it runs the homing macros you can then use the button the second time.
Can you try splitting out the homing from the resume.g file?
As I suggested before, create a macro that contains a G92 command to set the current location for X Y Z. If your pause.g moves the axis to a certain location, and your axis stay stable when the motors are off, then you can use that same position. No rehoming needed.
Then you can run that macro to set the axis as homed, and then you can use the resume button. Remove any homing calls from resume.g.
@Phaedrux I will definetly try that and let you know. CAn i have one more question? When pausing i would like to turn off the part cooling fan but also somehow save the value it was on so i can resume cooling when resuming the print. I was trying to figure it out using M106 R1 or R2 but no luck so far. Thanks
I would have thought M106 R1 or R2 would have worked. How are you turning the fan off in pause.g? M107?
@Phaedrux M106 S0
Try using M107 in pause.g to turn off the fan and then M106 R1 to return it to it's last speed in resume.g
@Phaedrux said in Pause.g Resume.g problems:
M107
I put M107 is the pause.g but the cooling fan still didnt turn back on . Dont understand why. Also i have tried the G92 but it didnt have any effect, when pressing the resume button the print head just went above the print and then i got the "G0/G1: insufficient axes homed" error again.
Here is what i changed
; pause.g
; called when a print from SD card is paused
G1 E-10 F3600 ; retract 10mm of filament
G91 ; relative positioning
G1 Z5 F360 ; lift Z by 5mm
G90 ; absolute positioning
G1 X20 Y525 F6000 ; go to X=20 Y=525
M18 X Y E ;turn off X,Y,E steppers
G10 P0 R20 ; Set standby temp of tool 0 to 20*
T-1 ; put tools in standby
M107 ; FAN off; resume.g
G92 X20 Y525 ; axis position
G1 E20 F500 ; extrude 10mm of filament
M106 R1 ; FAN on -
Don't put G92 into the resume.g file. As I said, put it in a separate macro and then run that manually before pressing resume button.
@Phaedrux Yeah that works. But i cant figure out that print fan, any ideas?
Post your config.g
