    Firmware Skips a few gcode instructions -- known issue?
    CNC
    935
    • N7JTIundefined
      N7JTI
        Phaedrux Moderator @N7JTI
        @N7JTI said in Firmware Skips a few gcode instructions -- known issue?:
        Is there a version of the CNC specific web interface that is approved/safe for the beta firmware?
        Yes. https://forum.duet3d.com/topic/20416/preview-version-of-cnc-optimized-dwc/36
        Probing with my z-probe now appears to be unreliable. It either doesn't probe downward, or probes downward very little. This was very reliable before. I couldn't find any documentation related to changes in this area.
        Would need some more details on your probe.
        I do notice that your configuration for the probe is missing some parameters.
        M558 K0 P5 C"^!io1.in" F120 T6000 ; Z probe speed and travel speed
        G31 Z25.4 ; set the z-probe trigger height to 1 inch
        G31 is missing P for trigger sensitivity and the X Y offset.
        N7JTIundefined 3 Replies Last reply Reply Quote 0
        • N7JTIundefined
          N7JTI @Phaedrux
          @Phaedrux The z-probe is just a machined touch plate. Basically it acts like a switch, but really it is just measuring current passing through the tool itself into the touch plate. Well, to be brutally specific, the tool is "ground" and the current source is the touch plate. x-y offset should be zero, as the tool itself makes the contact and there is no offset. The z-offset is 1 inch.
          I haven't been able to figure out how to get G30 to do anything like what I need. I've pasted the macro I use to set my z0 below. Should this be possible from a G30 command? How?
          The behavior of this macro seemed to be different with the new firmware. I've had to update my "dive height" with an h-parameter in M558 so that it probes toward the workpiece more than just a handful of mm.
          z_probe.g macro
          ; Probe in Z and reset 0
          G91 ; Set Relative Mode
          G38.2 Z P0 ; probe in the z direction
          G10 L20 P1 Z25.4 ; set the z-height of WCS 1 to 1 inch
          G0 Z50 ; rise up around 25mm to remove the z-plate
          G90 ; Set Absolute Mode
          • N7JTIundefined
            N7JTI @Phaedrux
            @Phaedrux My recent updates to try and get probing to actually probe down far enough to reliably set zero
            M558 K0 P5 H20 C"^!io1.in" F120 T6000 ; Z probe speed and travel speed
            G31 X0 Y0 Z25.4 ; set the z-probe trigger height to 1 inch
            • N7JTIundefined
              N7JTI @Phaedrux
                Try adding P500 to G31 as well
                Does G30 work now?
                I'm not as familiar with g38 for CNC
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G38_2_to_G38_5_Straight_Probe
                N7JTIundefined 1 Reply Last reply Reply Quote 0
                • N7JTIundefined
                  N7JTI @Phaedrux
                  @Phaedrux Well, that just cost me a bit and damaged my touch-pate.
                  I ran "g30" and the head dropped carefully down till it touched the plate... and then drove the v-bit straight down into the plate until the motors couldn't drive any further... badly scratching the touch plate and chipping the bit.
                  So, what I would like to have seen it do is STOP when it made contact with the touch plate.
                  So, how is G30 supposed to work?
                    Well g30 should stop when triggered provided the trigger pin is configured correctly, but I'm not a CNC user at all, so I'm not sue what else could be going on.
                    If the macro you have using G38.2 works as you expect that should be fine.
                    Only thing I can think of is to remove the K0 from M558 since you only have a single probe anyway.
                    • N7JTIundefined
                      N7JTI @Phaedrux
                      @Phaedrux but the problem I seem to be having with BOTH of these is that the directions are very backwards. instead of lifting on a g30 contact it is diving. And instead of probing DOWN towards the touchplate with the G38 command it is probing UP.
                      Does the beta firmware probing not pay attention to which direction is positive on my z-axis? This used to work.
                      • N7JTIundefined
                        N7JTI
                        Ok, I think I may have found it. The dive height I set negative becase it was probing the wrong direction... that seemed to have unintended consequences. So it is no longer diving after touching the plate.
                        • N7JTIundefined
                          N7JTI
                          Ok, so here's the problem I've got with G30. It probes the bed and sets the machine coordinates.
                          That isn't helpful. I need the WCS coordinates to be updated to z0.
                            That would do it.
                            Ok, so does G38.2 and the macro you have do what you're needing?
                            • N7JTIundefined
                              N7JTI
                              Ok, the machine seems to be performing mostly correctly now. I'm still seeing my macro probing the wrong direction occasionally, but I haven't caught it doing that in the last half-our. So I'm going to mark this as "solved" since my problem of the head occasionally not lifting seems to be fixed by the updated firmware.
                              If I can find a clear pattern for when the probing macro probes "towards the workpiece" in the wrong direction I'll open another question.
                              Thanks again for the great support!
