    Pause.g Resume.g problems
    Gcode meta commands
    8
    58
    3.7k
    • Deluxe 600undefined
      Deluxe 600 @Phaedrux
      @Phaedrux M106 S0
        Try using M107 in pause.g to turn off the fan and then M106 R1 to return it to it's last speed in resume.g
        Deluxe 600undefined 1 Reply Last reply Reply Quote 0
          @Phaedrux said in Pause.g Resume.g problems:
          M107
          I put M107 is the pause.g but the cooling fan still didnt turn back on 😕 . Dont understand why. Also i have tried the G92 but it didnt have any effect, when pressing the resume button the print head just went above the print and then i got the "G0/G1: insufficient axes homed" error again.
          Here is what i changed
          ; pause.g
          ; called when a print from SD card is paused
          M83 ; relative extruder moves
          G1 E-10 F3600 ; retract 10mm of filament
          G91 ; relative positioning
          G1 Z5 F360 ; lift Z by 5mm
          G90 ; absolute positioning
          G1 X20 Y525 F6000 ; go to X=20 Y=525
          M18 X Y E ;turn off X,Y,E steppers
          G10 P0 R20 ; Set standby temp of tool 0 to 20*
          T-1 ; put tools in standby
          M107 ; FAN off
          ; resume.g
          ; called before a print from SD card is resumed
          G92 X20 Y525 ; axis position
          T0 ; activate tool again
          M116 ; wait for all temperatures.
          G1 E20 F500 ; extrude 10mm of filament
          G1 R1 X0 Y0 Z5 F4000 ; go to 5mm above position of the last print move
          G1 R1 X0 Y0 ; go back to the last print move
          M106 R1 ; FAN on
            Don't put G92 into the resume.g file. As I said, put it in a separate macro and then run that manually before pressing resume button.
              @Phaedrux Yeah that works. But i cant figure out that print fan, any ideas?
                Post your config.g
                  @Phaedrux
                  Here 🙂
                  ; Configuration file for Duet Ethernet (firmware version 1.16 or older)
                  ; generated by RepRapFirmware Configuration Tool on Thu May 03 2018 12:19:37 GMT+0200 (Střední Evropa (letní čas))
                  M111 S0 ; Debug off
                  M550 Deluxe600 ; Machine name (can be anything you like)
                  M551 inman. ; Machine password (used when you connect Duet Web Control or via FTP)
                  M540 PBE:EF:DE:AD:FE:ED ; MAC Address (only needed if you have more than one Duet 0.6 or 0.8.5 on the same network)
                  M552 S1 ; IP address (0 = use DHCP)
                  M554 192.168.0.220 ; Gateway (not used yet)
                  M553 P255.255.255.0 ; Netmask
                  M555 P2 ; Set output to look like Marlin
                  M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
                  M350 Z16 X16 Y16 I1 ; Configure microstepping with interpolation
                  M350 E32 I0 ; Configure microstepping without interpolation
                  M92 X50 Y50 Z800 E280 ; Set steps per mm
                  M566 X480 Y480 Z19.2 E270 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X12000 Y12000 Z720 E7200 ; Set maximum speeds (mm/min)
                  M201 X1000 Y1000 Z850 E5000 ; Set accelerations (mm/s^2)
                  M906 X1650 Y1650 Z1650 E700 I1 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S5 ; Set idle timeout
                  M208 X0 Y0 Z0 S0 ; Set axis minima
                  M208 X545 Y545 Z700 S0 ; Set axis maxima
                  M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                  M574 Y2 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                  ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                  M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" A2 H3 F100 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  G31 X0 Y0 Z1.45 ; set Z probe trigger value, offset and trigger height
                  M557 X0:500 Y40:500 S100:100 ; define mesh grid
                  M143 H0 S100 ; set temperature limit for heater 0 to 100C
                  M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                  M106 P1 S0.5 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"fan2" Q500 ; create fan 2 (bed) on pin fan2 and set its frequency
                  M106 P2 S1 H0 T50
                  M563 P0 D0 H1 ; Define tool 0
                  ;LED control
                  M950 P5 C"e1heat" ;set e1heat as a GPIO output pin
                  M501
                  M107
                    Phaedrux Moderator @Deluxe 600
                    @Deluxe-600 said in Pause.g Resume.g problems:
                    You may want to add your X Y offset for your BLTouch. Unexpected things can happen if you don't.
                    Try adding F0 to your tool definition to make sure it's using fan0 for the part fan.
                      @Phaedrux The bl touch has a mechanical offset so its ok, but thank you 🙂 . I added the F0 to the tool definition (now looking like this"M563 P0 D0 H1 F0" correct?) . Doesnt seem to change anything, the fan still doesnt turn back up. Any other ideas what could i try? This is realy strange.
                        How did you set the fan speed before the pause: did you use M106 with or without the P parameter? If you used it without (the usual way that slicers generate it) then your pause/resume code looks OK to me.
                          Deluxe 600 @dc42
                          @dc42 Its set by the Slicer. So no ideas? Ow man 😞
                            Deluxe 600
                            Well didnt know this would be such a problem
                              an you share a sample gcode file? What slicer?
                                @Phaedrux Hi.
                                Im using PrusaSlicer for slicing.
                                Here is a gcode i tried printing.
                                test 1_0.3mm_PLA_MK3.gcode
                                  So basically it turns the fan on with M106 S255 and leaves it on a full power for the duration of the print and then turns it off at the end.
                                  If that's normally the case, as a work around, why not just set the fan speed to 100% in resume.g?
                                    Now that 3.2 is released can you test with that?
                                      Deluxe 600
                                      It is S255 for PLA but once you start printing PETG the speed changes how its needed. No i havent tried 3.2 yet. Could it solve this problem?
                                        I don't know, but testing on the most recent code base would be ideal in case it has been solved and any work to fix it if it is a bug would happen there. Since you're on 3.1.1 it's an easy update by uploading the Duet2and3CombinedFirmware zip file to the system tab.
                                          @Phaedrux Hi.
                                          So i have updated to 3.2 and tried the pause.g with M107 and also with M106 S0 and the resume.g with M106 R1 and also with M106 R2 but still no luck. Seems like the M106 R1 command sets the speed always to 0rpm. Thank you guys for helping.
                                            Deluxe 600
                                            I think its a bug in the software. There is no reason why should this not work, you guys dont use pause on your printers? I went trough every forum i could find and the M106 R1 command should turn the print fan back on...but it doesnt for unknown reason.
