cannot get 3hc to connect.
@Veti ; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 01 2021 12:00:51 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Duet 3" ; set printer name; Drives
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M569 P1.1 S1 ; physical drive 1.1 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.4:0.5:1.0:1.1 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
M92 X100.00 Y100.00 Z400.00 E100.00:100.00:100.00:100.00 ; set steps per mm
M566 X600.00 Y600.00 Z18.00 E300.00:300.00:300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E6000.00:6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00:10000.00:10000.00 ; set accelerations (mm/s^2)
M906 X500 Y500 Z500 E800:800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-50 Y-10 Z0 S1 ; set axis minima
M208 X300 Y300 Z350 S0 ; set axis maxima; Endstops
M574 Z1 S3 ; configure sensorless endstop for low end on Z; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X20:200 Y20:200 S40 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M308 S1 P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 1.temp0
M143 H1 S300 ; set temperature limit for heater 1 to 300C
M308 S2 P"1.temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin 1.temp1
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S300 ; set temperature limit for heater 2 to 300C; Fans
M950 F0 C"1.out3" Q500 ; create fan 0 on pin 1.out3 and set its frequency
M106 P0 S1 H1:2 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"1.out4" Q500 ; create fan 1 on pin 1.out4 and set its frequency
M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
@dc42 changed the can address switches on 3hc to 1, same as the config.g file. now we have a slow flash on the mb and a fast flash on the eb
@bam fast flash is no connection to mb
@bam said in cannot get 3hc to connect.:
@dc42 That’s probably the issue then because I am just using standard issue phone cord
That should be OK if it is short and wired with the middle 2 pins straight through; however it may be wired crossed.
Thar suggests a problem with the CAN wiring.
@dc42 i just took a look and the wires are not crossed
m122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956BA-NA3TJ-6JTD2-3SN6K-9BAQU
Used output buffers: 1 of 40 (14 max)
Static ram: 154604
Dynamic ram: 162320 of which 100 recycled
Exception stack ram used: 272
Never used ram: 75920
Tasks: NETWORK(ready,1968) HEAT(blocked,476) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,192) MAIN(running,5056) IDLE(ready,76)
Owned mutexes:
Last reset 00:06:53 ago, cause: software
Last software reset details not available
Error status: 0
MCU temperature: min 43.7, current 44.6, max 44.8
Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Driver 0: standstill, reads 6854, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 6855, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 6855, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 6858, writes 11 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 6856, writes 14 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 6856, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2021-01-01 23:45:44
Slowest loop: 2102.42ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.81ms; fastest: 0.01ms
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 1636, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 7
Last transfer: 17ms ago
RX/TX seq numbers: 46099/13071
SPI underruns 7, overruns 7
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Full transfers per second: 1.17
1/1/2021, 11:45:04 PM m115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2
- Ethernet -
@dc42 what does this mean?
M32 "0:/gcodes/Duet3Firmware_EXP3HC.bin"
Error: Unterminated string in line 3 -
@dc42 and now this
Warning: Incompatible firmware, please upgrade as soon as possible
M32 is start a print.
you want to print a firmware binary file?
and why is that file in the gcodes folder?
@Veti I Got It!!!
Finally!!
m122 b1
Diagnostics for board 1:
Duet EXP3HC firmware version 3.2-RC2 (2020-12-24)
Bootloader ID: not available
Never used RAM 154536, free system stack 200 words
HEAT 75 CanAsync 94 CanRecv 87 TMC 64 MAIN 173 AIN 257
Last reset 00:00:35 ago, cause: software
Last software reset data not available
Driver 0: position 0, 100.0 steps/mm, standstill, reads 63861, writes 16 timeouts 0, SG min/max 0/0
Driver 1: position 0, 100.0 steps/mm, standstill, reads 63863, writes 16 timeouts 0, SG min/max 0/0
Driver 2: position 0, 80.0 steps/mm, standstill, reads 63871, writes 11 timeouts 0, SG min/max 0/0
Moves scheduled 0, completed 0, in progress 0, hiccups 0
No step interrupt scheduled
VIN: 24.1V, V12: 12.2V
MCU temperature: min 45.9C, current 46.1C, max 46.1C
Ticks since heat task active 73, ADC conversions started 35564, completed 35564, timed out 0
Last sensors broadcast 0x00000006 found 2 76 ticks ago, loop time 0
CAN messages queued 243, send timeouts 0, received 252, lost 0, free buffers 36
1/2/2021, 1:13:10 AM m122
RepRapFirmware for Duet 3 MB6HC version 3.2-RC2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Used output buffers: 1 of 40 (13 max)
Static ram: 149788
Dynamic ram: 62676 of which 136 recycled
Never used RAM 146232, free system stack 200 words
Tasks: Linux(ready,119) HEAT(blocked,188) CanReceiv(blocked,836) CanSender(blocked,371) CanClock(blocked,360) TMC(blocked,53) MAIN(running,1217) IDLE(ready,19)
Owned mutexes: HTTP(MAIN)
Last reset 00:00:15 ago, cause: software
Last software reset time unknown, reason: StuckInSpinLoop, GCodes spinning, available RAM 147880, slot 1
Software reset code 0x0083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0x00000000 SP 0x204334e4 Task Linu Freestk 443 ok
Stack: 00429a2d 00429ab0 61000000 a5a5a5a5 a5a5a5a5 a5a5a5a5 00000000 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU temperature: min 43.8, current 46.0, max 46.1
Driver 0: position 0, standstill, reads 23487, writes 14 timeouts 0, SG min/max 0/0
Driver 1: position 0, standstill, reads 23487, writes 14 timeouts 0, SG min/max 0/0
Driver 2: position 0, standstill, reads 23487, writes 14 timeouts 0, SG min/max 0/0
Driver 3: position 0, standstill, reads 23491, writes 11 timeouts 0, SG min/max 0/0
Driver 4: position 0, standstill, reads 23488, writes 14 timeouts 0, SG min/max 0/0
Driver 5: position 0, standstill, reads 23488, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2021-01-02 01:13:08
Slowest loop: 0.45ms; fastest: 0.05ms
=== Storage ===
DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Daemon is idle in state(s) 0
=== CAN ===
Messages queued 55, send timeouts 0, received 95, lost 0, longest wait 1ms for reply type 6018, free buffers 48
=== SBC interface ===
State: 4, failed transfers: 0
Last transfer: 2ms ago
RX/TX seq numbers: 442/442
SPI underruns 0, overruns 0
Number of disconnects: 0, IAP RAM available 0x2c8a8
Buffer RX/TX: 0/0-0
Duet Control Server v3.2.0-rc2
Full transfers per second: 35.67
Maximum length of RX/TX data transfers: 5196/900 -
@Veti i dont know why the file is in there, not sure how to delete either. mightve shown up with the .bin i downloaded.
this whole time ive just been trying to get the boards online and the software updated. I can config the printer later.
twisted pair wasnt actually twisted. just looked twisted.
Either right click and delete, or if that won't work, you can try and do it from the SBC side. The first SD card (0:/) is emulated by DCS and its default directory is /opt/dsf/sd
@Phaedrux
yeah theres nothing here so idk
you are editing a file called gcodes.g
nothing phaedrux said mentioned any of that.
i did it from the duet3webcontrol.
sorry if i dont know anything about these and i jumped in feet first.
go to the macros tab in dwc.
find the file Duet3Firmware_EXP3HC.bin and right click on it.
a dropdown menu should appear where you can select delete
