    Heated bed wiring
    532
    • Blacksheep99undefined
      Blacksheep99 @A Former User
      @bearer said in Heated bed wiring:
      @Blacksheep99 said in Heated bed wiring:
      4.3 ohms I believe it reads
      you might want to just short your multimeter probes togeter and see what they read when it should be 0 and correct.
      Then you can use ohms law to work out the power at various voltages, but 4 ohms and 24v is only 144W .. however at mains voltage its probably waaay too much. how big is this thing?
      Thanks. I'll check this. The printer physically is large for the build size. Bed is 280x150.
        Blacksheep99 @Veti
        @Veti said in Heated bed wiring:
        unless there is a led. no
        Thanks, I do appreciate the help. Slightly off topic, maybe I should start a build thread for my questions. The printer has a server controlled microswitch/probe for the bed levelling which also doubles as an end stop for X. How should I approach this with the Maestro?
        My alternative idea was to use the door sensor microswitch as an end stop and use a different probe for the bed levelling sensor.
        • Vetiundefined
          Veti @Blacksheep99
          server controlled
          do you mean servo?
          Blacksheep99undefined 1 Reply Last reply Reply Quote 0
            Blacksheep99 @Veti
            @Veti Sorry yes, should say servo
            • Vetiundefined
              Veti
              if you install version 3 of the firmware you can reconfigure the microswitch for x or probe, but it will take some work.
                Blacksheep99 @Veti
                @Veti I've updated the board to 3.1 but then i have a whole new learning curve....
                • Vetiundefined
                  Veti @Blacksheep99
                  @Blacksheep99
                  sooner or later you will need to do it, as v2 does not get updates anymore
                    Blacksheep99 @Veti
                    @Veti Already done it. I figure I should start on the latest stable version. I see 3.2 is likely released soon so I'll update to that once it is. I am familiar with gcode and the principles so I may as well learn the Duet side using v3
                    • Vetiundefined
                      Veti
                      you cant assign 2 endstops to the same pin at the same time.
                      so what you will need to do is
                      when homing x configure the x endstop to use the pin and configure the z probe to the nil pin.
                      and when probing with the probe do the opposite.
                      this needs to happen in the homex, homez and homeall scripts.
                        Blacksheep99
                        Thanks, the logic makes sense. How i go about achieving it will be something to work out. My desire now is to get everything connected to the board and see if I can get some initial control.
