    No Homeing after fw update to 3.2
    • fragleundefined
      fragle
      i ve updated my duet2 wifi to 3.2 and i am struggling with the home funktion on my delta.
      i i say home all axes, i am getting an G28 Failed to enable endstops.
      Thermistors an already working, display too.
      homedelta.g
      G91 ; relative positioning
      G1 H1 X470 Y470 Z470 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      ;G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
      G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      ;G1 X0 Y0 F6000 ; move X+Y to the centre
      Maybe someone have an idea ?
      best regards
      Chris
        A Former User
        post the config.g (section with your endstops at least)?
        • Vetiundefined
          Veti
          i assume you are comming from a version 2 firmware
          please read
          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
          • fragleundefined
            fragle
            found it 🙂
            But now i am stuck with the print cooling fan
            i the old config.g i use for the print cooling fan /Heatsink
            M106 P0 S0 I0 F100 H-1 C"Print Cooling"
            M106 P1 S1 I0 F100 H1 T45 C"Heatsink"
            if i understand the new system correct, for V3 it should be
            M950 F0 C"Print Cooling" Q500 ; create fan 0 on pin fan0 and set its frequency
            M950 F1 C"Heatsink" Q500 ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45
            But no print cooling fan and the heatsink fan is running permanent
            • Vetiundefined
              Veti @fragle
              @fragle said in No Homeing after fw update to 3.2:
              those are not valid pin names
              fan0-fan2 are the pin names
              • fragleundefined
                fragle
                i switched back to 2.05, i do not get warm with the new System. On my others printer there is klipper and reptier running, which i can understand, but reprap is too high for me 😉
                • Vetiundefined
                  Veti
                  just use the configurator to generate a rrf3 config
                  https://configtool.reprapfirmware.org/Start
                  put in the relevant details and it should not be that hard.
