    belt tension measurement app
    4.3k
    • c310undefined
      c310
      Hi! long time ago i have seen android app that helps to calculate belts and also has a tension measurement mechanism. it did not require and extra hardware, but the phone itself.
      anyone knows the app name? thanks!!!
      • piperswundefined
        pipersw
        Every tune app for guitar will work. But the best I have found is a belt tension meter
          A Former User
          A trummeter works very well
            https://www.hutchinson.com/en/easy-tension-app
            • Adrian52undefined
              Adrian52
              Gates have an app called Carbon Drive. I have felt happier with a sprung displacement device - I use something like the one mentioned above, modified so that you can measure the displacement using digital callipers.
                A Former User
                @pipersw
                Found this post interesting - I think I will also printout something easy for now (I still can later ruin my bank account for something expensive)
                That brought me to search a little bit on thingiverse, wanted to share what I think is doing maybe the job:
                measure (the original from pipersw but the high-end version of it):
                https://www.thingiverse.com/thing:2589577
                only indicator:
                https://www.thingiverse.com/thing:2923242
                  A Former User @A Former User
                  @A-Former-User said in belt tension measurement app:
                  Seems like those with light are the most precise one, but they cost also, found this one which seems to be comparable to the one you posted:
                  https://www.carlislebelts.com/product/belts/tools/frequency-finder
                  And then there are so many with microphones (instead of light) which might take up some background noise but might be cheaper(?):
                  http://ebike-center-metzingen.de/Fahrradzubehoer/Sonstiges/CONTITECH-Frequenzmessgeraet-Belt-Tension-Tester-BTT-Hz-Zur-Erm::273896.html
                  https://www.optibelt.com/de/produkte/technische-geraete/optibelt-tt/
                  https://www.synchrotech.eu/produkte/zubehoer
                  Maybe for a first guess the mobile-phone-app might be sufficient? But if I would go ever exact I think I would also opt for light instead of microphone, because there is no background noise any more 😉 So thanks for posting the link above
                  • c310undefined
                    c310
                    thank you very very much
