    HELP WITH HEIGHT MAP HAS SUBSTANTIAL Z OFFSET WARNING
    1.5k
      The position that you use to probe the Z axis should be the same between homeall and homez. It should also be the same point you use for the G30 before running G29.
      G1 X137 Y156 F2000 ; put head over the centre of the bed, or wherever you want to probe
      G0 X127 Y142 F12000 ; go to back center of bed for measurement
      Jaw8850undefined 3 Replies Last reply Reply Quote 0
      • Jaw8850undefined
        Jaw8850 @Phaedrux
        @Phaedrux
        Got the fans sorted, thank you
        1/8/2021, 8:20:45 PM m98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        and I adjusted the Homez and homeall to match
        config.g
        bed.g
        homeall.g
        homez.g
        • Jaw8850undefined
          Jaw8850 @Phaedrux
          @Phaedrux
          Reference a Mesh Bed Leveling Macro, does this look right? I commented out the temperature settings until I know it's probing correctly etc.
          ;M140 S70 ; Start Heating the bed
          ;M109 S200 ; Start Heating the nozzle
          G32 ; Home all & adjust lead screws
          G1 X137 Y156 Z5 ; move to center of the bed
          G30 ; probe Z
          G29 ; run mesh bed leveling
          G1 H1 X240 Y240 Z50
          ;M140 S0
          ;M109 S0
          • Jaw8850undefined
            Jaw8850 @Phaedrux
            @Phaedrux
            Here is a picture of my bed surface. I also have a buildtak flexplate with PEI on it but it's translucent yellow and shiny in spots, I was going to wetsand it with 1000 grit to try and dull it out if I can't get this textured sheet to work
              G30 Z					; lower head, stop when probe triggered and set Z to trigger height
              G1 Z5 F4000             ; lower Z 5mm
              G30 Z                   ; lower head, stop when probe triggered and set Z to trigger height (second pass)
              In homez you still have the G30 Z. Also, if you want it to do two passes, say a fast pass and then a slower pass use something like this
              M558 F500 A1 ; set fast single dive speed
              G30 ; probe the bed
              M558 F60 A5 ; set slow multi dive speed
              G30
              That gets you a fast first z homing and then a slower more accurate one.
              In your homeall, you should remove this line
              G1 H1 X10 ;move X away from frame to home Y
              Your mesh macro looks ok, but instead of this
              G30 ; probe Z
              you could just use G28 Z to home the z axis
              Jaw8850undefined 1 Reply Last reply Reply Quote 0
                Have you recently remeasured your trigger height?
                G31 X-27 Y0 Z2.062 P500
                  As for the bed surface a good way to test if it's a factor you can place a plane piece of paper over the bed and see if the mesh looks much different.
                  The white lines might have an effect and it looks a bit shiny. Hard to say.... best to test with something matte.
                  • Jaw8850undefined
                    Jaw8850 @Phaedrux
                    @Phaedrux
                    with the sensorless homing when I don't move X back away from 0 it hits and stops Y at about 20mm from 0. also when I hit G30 without the G1 command it just probes the bed at the right lead screw where it parked from doing the G32
                    I have remeasured trigger height what seams like 100 times but not opposed to doing it more. this is the method I'm using for that from https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
                    Cancel any currently active mesh compensation with M561
                    Use the X and Y jog buttons to position the nozzle over the centre of the bed
                    Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                    Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                    Jog the head up by 5 to 10mm
                    Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
                    Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                    In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                    Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                    To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.
                    • Jaw8850undefined
                      Jaw8850 @Phaedrux
                      @Phaedrux
                      I ran through Live Z twice - below are screen shots of stopped heights. I set Z offset to 2.075 in config.g after running this twice
                        Phaedrux Moderator @Jaw8850
                        @Jaw8850 said in HELP WITH HEIGHT MAP HAS SUBSTANTIAL Z OFFSET WARNING:
                        Then use just a G1 X move. leave out the H1.
                        Yes, but what I'm saying is a G28 Z command will do the positioning and probing for you.
                        That's fine. As long as the trigger height seems consistant. The important thing is that the nozzle is just touching the bed when Z=0.
                        How does your mesh look now? You're only using 9 points total, so the shape will always look a bit weird if there is some tilt.
                        Change your M557 command from M557 X40:240 Y30:270 S100 to M557 X40:240 Y30:270 P4
                        That will add a few more points. 4 in each direction. You could increase it even more to get a more detailed picture of the bed.
                        I also note that your bed would appear to be tilted in the Y direction. Your 2 point tilt correction along the X axis won't be able to solve for that. You should start from as level a bed as possible.
                        See if running through this guide helps.
                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                        • Jaw8850undefined
                          Jaw8850
                          Gotcha
                          Removed the H1
                          Replaced the G1 and G30 with G28 Z
                          Mesh is getting better. I replaced springs with silicone bed spacers so I was using as few points as possible to get the tilt out and try to get left/right and front/back as good as I could since there are only the screws at the 4 corners to make adjustment. I wet sanded the PEI Flex Sheet I have with 1000 grit, and now it's getting much much better. Not perfect but much better than it was
                            That's looking much better.
                            You can run the bed.g a few times in a row to get it a bit tighter.
                            • Jaw8850undefined
                              Jaw8850 @Phaedrux
                              @Phaedrux
                              Yep, I set it to P5 just to make sure it gets the center of the bed again. Now I can at least tweak the 4 adjustment screws 1 at a time as I run the Mesh to get it as close as possible. Before I was just going in circles. Appreciate your help greatly!!!! This forum makes owning a Duet worth it.
                              Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                                Glad to hear.
                                • fcwiltundefined
                                  fcwilt @Jaw8850
                                  Are you aware of the Manual Bed Leveling Assistant?
                                  It allows you to adjust your leveling screws quickly and easily.
