load unload macro with endless loop and cancel condition
Gcode meta commands
3.0k
    A Former User @garethky
    @garethky
    Hi, really impressive - hat´s off! 👍
    It is promising to us all to simplify things by getting rid of redundant code via "links" & "variables"!
    What I do not understand by looking at the code:
    -> How does this work with the code you just posted, because is RRF not looking for the "un-"/"load.g" within the filament-folder of the selected filament? Since yours seems to be within the macros/filaments/ how does it find it automatically without throwing an error?😐
    -> Does this work really automatic with pressing within e.g. DWC here:
    What I really like:
    It does make sense to have a general/1-for-all un-/load.g one layer "before" in the folder-structure within Files/Filaments so to say, and to only be able to "overwrite" it with a more specific un-/load.g within that filament-folder, IF a special filament really needs it I guess 🤓 That way we could get rid of some redundant code?
    -> Wouldn´t some sort of it be cool as the general layout? Or did I oversee something here 🤔
    undefined undefined 2 Replies Last reply 2 Jan 2021, 12:27 Reply Quote 0
      Krohm Koala @A Former User
      @LB Personnally, i've updated my filament change macro to have specific heat file by filament, it's not the most intuitive at first, but now that i have all my files, it's insanely good to use, i also add an axe movement to choose the filament i'm loading wich is also useful, loading a config file at the end could be easy to add but don't need it now, thanks to meta code 😄
      I hope the endless loop for purging could be done at one time but it's already good now
      M291 P"Mettre les chauffes et changer le filament ?" R"Changement du Filament" S3
      M80
      T0 P0 ;Select tool
      M106 S0
      M98 P{"0:/filaments/" ^ {move.extruders[state.currentTool].filament} ^ "/e-heat.g"}
      M291 P"Mise aux origines..." R"Changement du Filament" S0 T30
      G28 ; homing
      M291 P"Mise à la position de purge..." R"Changement du Filament" S0 T30
      G1 X253 Y-5.9 F12000 ; aller à la position de purge
      while heat.heaters[1].current <= heat.heaters[1].active
      M291 P"Chauffes en cours... Veuillez Patienter..." R"Changement du Filament" S0
      if sensors.filamentMonitors[0].status == "ok"
      M291 P"Déchargement en cours, veuillez patienter..." R"Changement du Filament" S0 T30
      G1 E5 F150 ;Extrude 10mm filament at low speed
      ;G1 E-15 F500 ;Retract 15mm filament at low speed
      G1 E-100 F3600 ;Retract 100mm filament at high speed
      M400
      while sensors.filamentMonitors[0].status == "ok"
      M291 P"Merci de retirer le filament." R"Changement du Filament" S0 T30
      G4 S0.1 ;attendre 0.1s pour éviter de surcharger le processeur
      while true
      if sensors.filamentMonitors[0].status == "noFilament"
      M291 P"Filament déchargé, merci d''insérer le nouveau filament." R"Changement du Filament" S0 T30
      else
      break
      else
      while true
      M291 P"Aucun filament, merci d''insérer un filament." R"Changement du Filament" S0 T30
      else
      break
      G4 S0.7 ;attendre 1s pour laisser le temps d'insérer le filament
      M291 P"Chargement en cours...." R"Changement du Filament" S0
      M106 S255 ;mise en route du ventilateur pour refroidir la purge
      G1 E65 F3600 ; extrude 65mm at high speed
      M83 ; mode d'extrusion relative
      G1 E20 F200 ; extrude 10mm at low speed
      M400
      M98 P"/macros/Filament/Purge.g"
      G1 Z0.1 F200 ;Essuyer la purge
      G1 X0 F12000
      G1 Z20 F3000
      M106 S0
      M291 P"Filament chargé. Merci de définir le nouveau filament." R"Changement du Filament" S2
      M291 P"Déplacez l''axe X pour choisir le filament voulu. 0 = Aucun Changement / 1 = PLA / 2 = PETG / 3 = TPU" R"Changement du Filament" S2 X1
      if move.axes[0].machinePosition < 1
      elif move.axes[0].machinePosition < 2
      M702
      M701 S"PLA"
      elif move.axes[0].machinePosition < 3
      M702
      M701 S"PETG"
      elif move.axes[0].machinePosition < 4
      M702
      M701 S"TPU"
      M291 P{"""" ^ move.extruders[0].filament ^ """ a bien été défini comme filament chargé."} R"Changement du Filament" S2
      M98 P{"0:/filaments/" ^ {move.extruders[state.currentTool].filament} ^ "/heat.g"}
        garethky @A Former User
        @LB
        For whatever reason my version of RRF seems happy finding these paths (3.1.1, Duet 3 with a Pi attached). I've actually tried to use relative paths, but found that they are all relative to /sys/. If you are having trouble there is an absolute path option for M98 that starts from 0:/some/path/macros/filaments/loadFilament.g.
        Yes this it totally automatic from the GUI!
        I had another idea last night that im going to try: maybe the filament name is somewhere in the Object Model after M703 gets run and I don't have to use that extra tool to store the filament name string. I'll work on it some more today.
          The filament name is available in the OM as move.extruders[n].filament.
            garethky
            Thanks everyone for the props and the new information. I was able to get rid of that "virtual tool" and use the object model for the filament name. I tried M703 but it doesn't work in the filament load script, so I have to execute the config file with a macro call instead.
            So now that I lost my virtual tool I needed somewhere to store the temprature and feed rate. I looked into this idea of "virtual axes" so I could store the filament settings per-tool rather than globally. This took some trial and error and I still have some warnings in the console but it work. And once I had gone that far I didn't see any reason not to do the same thing to tool changing, no reason that cant be just 3 macros either!
            I'm using the A axis to store the filament temp, B for the slow feed rate, U and V to hold the machine absolute coordinates of each tool and S to hold the nozzle diameter. then I use expressions like {tools[state.currentTool].offsets[7]} and Y{tools[state.nextTool].offsets[8]} to get the setting from the appropriate tool in the macros.
            Firmware 3.2 fixes the bug with G1 commands not accepting expressions so now the feed rate setting works as well and my flexibles wont shoot out the side of the extruder 😁
            I'm not going to attempt to post all of the code here, that's what github is for: https://github.com/garethky/E3D-ToolChanger-Configuration/compare/8ee9b057f122e24b47c47b57480a3bb26d76375d..206529f2f50617df253abac9db369fd81ff42fc8
            Cheers! 🍻
            ? 1 Reply Last reply 8 Jan 2021, 09:28 Reply Quote 0
              @garethky
              @Krohm-Koala
              I got 2 questions for giving the approach to only have 1 load.g/unload.g with in the general filaments folder a try (also that needs a workaround with a macro in each filament to point to the general file):
              1st
              for the individual load.g that is more or less only a macro-call-file for the general parametric ones you had post the example
              M98 P"/filaments/PLA/config.g" ; the filament config isn't loaded until AFTER this macro runs, but we need the variables set now
              With the new move.extruders[n].filament that could be something like
              M98 P"/filaments/move.extruders[0].filament/config.g"
              Or wouldn´t just M703 be sufficient
              2nd
              How can I fetch the nozzle-temperature from the material (beside calling M703 of course), now I have:
              G10 S235 ; Set current tool temperature direct S___
              -> Would that become something like:
              G10 S{heat.heaters[1].active} ;fetch from what is in filament-config.g of selected filament
              3rd
              And for the temperature-reach-wait now
              M116 P0
              -> would that be something like:
              M116 P{tools[0]} ; wait for temps to be reached - for tool selected
              Looking at the object model that comes with RRF3.2, but I will only learn how to use it - every help appreciated 😀
              undefined 1 Reply Last reply 9 Jan 2021, 09:41 Reply Quote 0
                garethky
                #1 That's a good optimization! I upgraded to 3.2 firmware and now it seems that the Filament name is not set in the object model when load gets called. I haven't had a chance to investigate further. M703 didn't work there on 3.1.1. I have to go back and experiment again in 3.2
                #2 I have 2 ideas:
                First idea: If you don't have a tool selected (maybe its the beginning of the print) then this should work:
                T-1
                T2 P0 ; set the active tool but do not run the tool change macors
                M703
                ; do whatever needs doing with the filament settings
                T-1 P0
                This should also be a durable solution long term.
                Second idea: storing per-tool filament settings in the work offset system. I got started with some of the ideas over in this thread: https://forum.duet3d.com/topic/20681/virtual-axis-break-stall-detection/6?_=1610137141350
                My end goal with this is to have enough information to write a Live-Z calibration print that uses the math expressions for the extrusion lengths so they adapt to the filament diameter and nozzle diameter to print an accurate test pattern regardless of machine configuration. This doesn't require that I have access to multiple tool temperatures at the same time, so M703 will work for me.
                #3 In my tpost.g macro I have this to handle getting the tool up to temp:
                ; wait for hot end temp
                M116 P{state.currentTool}
                ? 1 Reply Last reply 9 Jan 2021, 16:45 Reply Quote 0
                  @LB
                  1st
                  it'll be that to load the config.g of the current loaded filament
                  M98 P{"0:/filaments/" ^ {move.extruders[state.currentTool].filament} ^ "/config.g"}
                  2nd
                  You can do as i've done, create a heat.g file in each filament, in wich you put your G10 (and maybe the bed temp also, i've separate the two and made a file that call the two macros) so you'll just have to call
                  3rd
                  @garethky line is the way to go 😄
                  ? 1 Reply Last reply 9 Jan 2021, 16:46 Reply Quote 0
                    @garethky
                    Thanks!
                    1.
                    yeah now in my filament specific load/unload there is just a macro that points to the one and only load/unload for all the filaments since I get the temperatures from the filament-config.g
                    2.
                    have to think about it or even better: try it out 🙂
                    3.
                    THANKS! Now it works!
                      A Former User @Krohm Koala
                      @Krohm-Koala
                      Thanks!
                      1.
                      Thanks now it works but I had to take out the last "/" before config.g
                      2.
                      Yep
                      We are some sort of "brothers in lazyness" I guess 😉
                      3.
                      What? I do not get it...
                      undefined 1 Reply Last reply 9 Jan 2021, 16:58 Reply Quote 1
                        @LB the 3 was just saying that the @garethky gcode was right 🙂 (sorry if it have a meaning or something that i don't understand, i haven't the greatest english x) )
                        It's weird that you had to take the last "/" before config.g, it's working for me ^^
                        ? 1 Reply Last reply 9 Jan 2021, 17:01 Reply Quote 0
                          @Krohm-Koala said in load unload macro with endless loop and cancel condition:
                          YOU are correct here -> That was an error of me, because when no filament is yet selected ("empty tool") that just threw an error SORRY -> YOU are correct here!
                          undefined 1 Reply Last reply 9 Jan 2021, 17:13 Reply Quote 0
                            @LB Nice that it works now 🙂
                            ? 1 Reply Last reply 9 Jan 2021, 17:28 Reply Quote 0
                              It is not "really" working clean and cool, rather a big "workaround" to get it done somehow, but let´s see how this all evolves the next month.
                              undefined 1 Reply Last reply 9 Jan 2021, 17:52 Reply Quote 0
                                @LB How does it look now ? and what's left to do ? It's really cool to see how everyone do it their ways 😄
                                  garethky
                                  I have upgraded to 3.2 final and I no longer get the filament name in move.extruders[n].filament inside load.g. This now mirrors the behavior of tool changes where there is no tool selected when tpreN.g is called. I'm not against the logical consistency of this. But for tool changes we have state.nextTool which contains the tool being loaded, we don't have a similar concept for filaments. I think we should ask for a move.extruders[n].nextFilament variable in the Object Model.
                                  Using this to find the filament macros directory is a neat idea. Although what we have essentially done is eliminate the need for M703 almost entirely.
                                    OwenD
                                    Still works for me
                                    1/10/2021, 10:53:33 AM echo move.extruders[0].filament
                                    ABS
                                    Board: Duet 2 WiFi (2WiFi)
                                    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
                                    Duet WiFi Server Version: 1.25
                                    Are you sure that there is a filament recorded in filaments.csv?
                                    If there is a filament loaded in all tools the next tool is accessable using
                                    echo move.extruders[state.nextTool].filament
                                      garethky
                                      @OwenD
                                      Maybe this is because I'm using the SBC? (Duet 3 running 3.2_final and a Pi)
                                      Whenever I get into load.g (either loading or changing filaments) the filament variable is empty:
                                      ; load.g
                                      echo "Current Filament: '" ^ {move.extruders[state.currentTool].filament} ^ "'"
                                      Current Filament: "
                                      undefined 1 Reply Last reply 10 Jan 2021, 08:10 Reply Quote 0
                                        Krohm Koala @garethky
                                        @garethky i've just tested you echo, it works for me too, but i think it store the name after the load.g or config.g.
                                        I'm loading it myself using M702 to clear filament and use M701 S"(filament)" but i don't use load/unload.g and config.g (maybe i'll be using it later but not for now) so it do nothing instead of changing the filament loaded name ^^
                                        I also don't use the loading/unloading function of DWC as i have a all-in-one load/change filament macro
                                        undefined 1 Reply Last reply 10 Jan 2021, 08:21 Reply Quote 0
                                          garethky @Krohm Koala
                                          @Krohm-Koala
                                          The documentation for M701 states that it stores is after load.g exits. If you echo inside load.g, then it hasn't happened yet, so the echo will be empty.
                                          I want to use the GUI to change filament and guide the user (me 😊 ) through the process with helpful prompts.
                                          undefined undefined 2 Replies Last reply 10 Jan 2021, 09:06 Reply Quote 0
                                          30 out of 44
