    load unload macro with endless loop and cancel condition
    Gcode meta commands
    3.2k
    • Krohm Koalaundefined
      Krohm Koala @A Former User
      @LB
      1st
      it'll be that to load the config.g of the current loaded filament
      M98 P{"0:/filaments/" ^ {move.extruders[state.currentTool].filament} ^ "/config.g"}
      2nd
      You can do as i've done, create a heat.g file in each filament, in wich you put your G10 (and maybe the bed temp also, i've separate the two and made a file that call the two macros) so you'll just have to call
      M98 P{"0:/filaments/" ^ {move.extruders[state.currentTool].filament} ^ "/heat.g"}
      3rd
      @garethky line is the way to go πŸ˜„
        A Former User @garethky
        @garethky
        Thanks!
        1.
        yeah now in my filament specific load/unload there is just a macro that points to the one and only load/unload for all the filaments since I get the temperatures from the filament-config.g
        2.
        have to think about it or even better: try it out πŸ™‚
        3.
        THANKS! Now it works!
          A Former User @Krohm Koala
          @Krohm-Koala
          Thanks!
          1.
          Thanks now it works but I had to take out the last "/" before config.g
          2.
          Yep
          We are some sort of "brothers in lazyness" I guess πŸ˜‰
          3.
          What? I do not get it...
          Krohm Koalaundefined 1 Reply Last reply Reply Quote 1
            @LB the 3 was just saying that the @garethky gcode was right πŸ™‚ (sorry if it have a meaning or something that i don't understand, i haven't the greatest english x) )
            It's weird that you had to take the last "/" before config.g, it's working for me ^^
              @Krohm-Koala said in load unload macro with endless loop and cancel condition:
              YOU are correct here -> That was an error of me, because when no filament is yet selected ("empty tool") that just threw an error SORRY -> YOU are correct here!
              Krohm Koalaundefined 1 Reply Last reply Reply Quote 0
                @LB Nice that it works now πŸ™‚
                  It is not "really" working clean and cool, rather a big "workaround" to get it done somehow, but letΒ΄s see how this all evolves the next month.
                    @LB How does it look now ? and what's left to do ? It's really cool to see how everyone do it their ways πŸ˜„
                    • garethkyundefined
                      garethky
                      I have upgraded to 3.2 final and I no longer get the filament name in move.extruders[n].filament inside load.g. This now mirrors the behavior of tool changes where there is no tool selected when tpreN.g is called. I'm not against the logical consistency of this. But for tool changes we have state.nextTool which contains the tool being loaded, we don't have a similar concept for filaments. I think we should ask for a move.extruders[n].nextFilament variable in the Object Model.
                      Using this to find the filament macros directory is a neat idea. Although what we have essentially done is eliminate the need for M703 almost entirely.
                      • OwenDundefined
                        OwenD
                        Still works for me
                        1/10/2021, 10:53:33 AM 	echo move.extruders[0].filament
                        ABS
                        Board: Duet 2 WiFi (2WiFi)
                        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
                        Duet WiFi Server Version: 1.25
                        Are you sure that there is a filament recorded in filaments.csv?
                        If there is a filament loaded in all tools the next tool is accessable using
                        echo move.extruders[state.nextTool].filament
                        • garethkyundefined
                          garethky
                          @OwenD
                          Maybe this is because I'm using the SBC? (Duet 3 running 3.2_final and a Pi)
                          Whenever I get into load.g (either loading or changing filaments) the filament variable is empty:
                          ; load.g
                          echo "Current Filament: '" ^ {move.extruders[state.currentTool].filament} ^ "'"
                          Current Filament: "
                            Krohm Koala @garethky
                            @garethky i've just tested you echo, it works for me too, but i think it store the name after the load.g or config.g.
                            I'm loading it myself using M702 to clear filament and use M701 S"(filament)" but i don't use load/unload.g and config.g (maybe i'll be using it later but not for now) so it do nothing instead of changing the filament loaded name ^^
                            I also don't use the loading/unloading function of DWC as i have a all-in-one load/change filament macro
                            garethkyundefined 1 Reply Last reply Reply Quote 0
                            • garethkyundefined
                              garethky @Krohm Koala
                              @Krohm-Koala
                              The documentation for M701 states that it stores is after load.g exits. If you echo inside load.g, then it hasn't happened yet, so the echo will be empty.
                              I want to use the GUI to change filament and guide the user (me 😊 ) through the process with helpful prompts.
                              OwenDundefined Krohm Koalaundefined 2 Replies Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @garethky
                                @garethky
                                I use a dummy fan name to store the name of the filament to be loaded.
                                My setup is done so that I can ensure the correct filament is loaded for a sliced file, but DWC filament buttons still functions normally.
                                Ultimately I want all the files in the filaments folders to be identical, but can't quite achieve that yet.
                                In Prusa Slicer start G Code I have
                                T[current_extruder] ; select tool
                                M104 S0 R0 T[current_extruder] ; Set temps to zero to stop slicer adding them
                                M106 P[current_extruder] S0 ;Start with fan off
                                M950 F3 C"duex.fan3" Q0  ;create a dummy fan so we can use it's details as variables
                                M106 P3 C"[filament_type]" S0 H-1
                                M98 P"0:/macros/filament/check-filament-type.g"
                                in config.g I have
                                ; create dummy fan so we can use variables
                                M950 F3 C"duex.fan3" Q0                                       ; create fan 3 on pin and set its frequency
                                M106 P3 C"No_Filament" S0 X255 H-1
                                ; Calibrate MCU temp
                                M912 P0 S-4																	; Adjust MCU temp reading to match ambient
                                M563 P0 S"Extruder1" D0 H1 F0                               ; define tool 0
                                G10 P0 X0 Y0 Z0                                             ; set tool 0 axis offsets
                                G10 P0 R0 S0  ; set initial tool 0 active and standby temperatures to 0C
                                ; create dummy tool so we can store some variables
                                M563 P2 S"DummyTool"                              ; define dummy tool 2
                                G10 P2 X0 Y0 Z0                                             ; set tool 2 axis offsets
                                G10 P2 R0 S0  ; set initial tool 2 active and standby temperatures to 0C
                                ;Select tool zero
                                T0 P0
                                ; extrusion
                                if move.extruders[state.currentTool].filament=""
                                	echo "No filament loaded.  Cold extrude & retract set to defaults"
                                	M302 S190 R110 ; Allow extrusion starting from 190Β°C and retractions already from 110Β°C (defaults)
                                else
                                	echo "Filament loaded.  Set values per config for filament"
                                	M703 ; if a filament is loaded, set all the heats and speeds for it by loading config.g
                                	M106 P3 C{move.extruders[state.currentTool].filament} S0 H-1
                                At present I have to do this in /filament/*/load.g.
                                This will be easier once variables are available
                                ;; load.g
                                ; set the dummy fan name to the filament being loaded
                                M106 P3 C"ABS" S0 H-1 ; set the fan name to ABS in case this is called from web interface
                                M98 P"0:\macros\filament\universal_load.g"
                                All my preheat settings and speeds etc are done in the filament/config.g
                                These are tuned per filament naturally
                                ; Used to set parameters for filament such as retracts, temperatures etc
                                M302 S210 R130 ; set cold extrude and retract temperatures
                                M291 P"loading config.g for ABS" R"Loading config" S1 T5
                                ;M592 D0:1 A0.012 B0 ; Set non linear extrusion
                                M572 D0 S0.09 ;Set pressure advance
                                M207 S1.0 F2400  Z0	; Set retraction
                                ;M593 F25  ; cancel ringing at 25Hz
                                filament/unload.g for all filaments just calls my universal unload.g
                                ;; calls universal unload file.
                                M98 P"0:\macros\filament\universal_unload.g"
                                This is the "check filament" code
                                if move.extruders[state.currentTool].filament!= fans[3].name
                                	if job.file.fileName!=null
                                		M25
                                	M291 R"Incorrect filament loaded" P{"Incorrect filament loaded  - ("  ^ move.extruders[state.currentTool].filament ^ ").  Print calls for (" ^ fans[3].name ^ ")." } S0 T3
                                    G4 S3
                                    M291 R"Change filament?" P"Press OK to begin filament change or CANCEL to abort job" S3
                                	M564 S0 H0; allow movement without homing
                                	M591 P1 C"e0stop" S0  D0  ; disable filament sensor for now
                                	M291 R"Incorrect Filament" P{"Move head and press OK to begin unloading " ^ move.extruders[state.currentTool].filament} S3 Z1
                                	M702 ; unload current filament
                                	M291 R"Ready to load" P{"Move head and press OK to begin loading " ^ fans[3].name}  S3 Z1
                                	M701 S{fans[3].name} ; load new filament
                                	M564 S1 H1 ; do not allow movement unless homed.
                                	M591 P1 C"e0stop" S1  D0 ; enable filament sensor
                                		M291 R"Filament loaded" P"Print ready to be resumed" S3
                                This is universal load
                                ;; universal_load.g  All filament load.g files call this one.
                                ; filament to load is stored in fans[3].name
                                M291 R{"Loading " ^ fans[3].name} P"Loading config and heating" S1 T3
                                G4 S3
                                echo "attempting to load config for " ^ fans[3].name
                                M98 P{"0:\filaments\" ^ fans[3].name ^ "\config.g"} ; load config to get extrude temps etc
                                if result==0
                                	echo "config loaded"
                                else
                                	echo "error loading config"
                                echo "check tool"
                                ;check if no tool selected or if heater is off
                                if state.currentTool=-1
                                	T0 P0
                                if heat.heaters[state.currentTool].state="off"
                                	T0 P0
                                	G10 P{state.currentTool} R0 S0
                                echo "waiting for temp"
                                M291 R{"Loading " ^ fans[3].name} P"Waiting for nozzle loading temperature..." S1 T0
                                M98 P"0:/macros/heating/preheat_current_filament.g" ; preheat to the temps set in filament config.g
                                M116                            ; Wait for temperature
                                ;check if the requested filament is already loaded
                                if move.extruders[state.currentTool].filament=fans[3].name
                                	echo "filament already loaded"
                                	M291 R"Cancel loading" P"Filament already loaded.  Skipping load moves" S3
                                	G4 S3
                                	M99;
                                ; opt out option as print in running
                                if job.file.fileName!=null && state.status!="paused"
                                	echo "Print job is running - confirmation required"
                                	M291 R"Confirm?" P"A print job is in progress.  Press OK to continue or CANCEL to abort" S3
                                ;we know the requested filament isn't loaded, but if something else is, we need to unload it first
                                if move.extruders[state.currentTool].filament!=""
                                	echo "unload required"
                                	if move.extruders[state.currentTool].filament!=fans[3].name
                                		M702 S{"{move.extruders[state.currentTool].filament}"}
                                		M291 R"Unload finished" P"Press OK when ready to load new filament" S3
                                		echo "another filament loaded, so load new one"
                                ; we check filament loaded again in case this is a second loop from an unload.
                                	echo "loading filament"
                                	M291 R{"Loading " ^ fans[3].name} P"Feeding and priming..." S0 T3
                                	M98 P"0:/macros/filament/do_moves_for_load.g"
                                	echo "loading complete"
                                G92 E0 ; set extruder position to zero
                                M291 R{"Loading " ^ fans[3].name} P"Filament loaded....." S1 T5
                                M98 P"0:/macros/songs/simpsons.g"
                                echo "exiting universal_load.g"
                                G4 S3
                                This is universal unload
                                ;; Universal unload.g  - direct all other filament unoad.g instances to this file
                                if state.currentTool==-1
                                	M291 R"Error" P"No tool selected.  Unload aborted" S2
                                	M99
                                echo "waiting for unload temp"
                                if move.extruders[state.currentTool].filament == ""
                                	M291 R"Error" P"No filament loaded.  Unload aborted" S2 T2
                                	M99
                                M703 ; ensure correct filament settings are loaded.
                                M291 R{"Unloading " ^ move.extruders[state.currentTool].filament} P"Waiting for nozzle unloading temperature..." S0 T10
                                G4 S2
                                G10 S{heat.coldRetractTemperature+5} R{heat.coldRetractTemperature} ; Heat current tool just enough to cold pull
                                G4 S1
                                M292 ; close popup
                                ;show progress of heating from lower temp
                                while (heat.heaters[tools[state.currentTool].heaters[state.currentTool]].current) < (heat.coldRetractTemperature + 5 - 2)
                                	M291 R"Preheating..  Please wait" P{"Current temp = " ^  heat.heaters[tools[state.currentTool].heaters[state.currentTool]].current ^ " : target = " ^ (heat.coldRetractTemperature+5)}  S0 T1
                                	G4 P500
                                ;show progress of cooling from hotter temp
                                while  (heat.heaters[tools[state.currentTool].heaters[state.currentTool]].current) > (heat.coldRetractTemperature + 5 + 2)
                                	G4 P500
                                M116 S0.5                       ; Wait for temperature to be within 0.5 degrees of target
                                echo "waiting for filament to settle"
                                M291 R{"Unloading " ^ move.extruders[state.currentTool].filament} P"Waiting for filament to soften (or firm)..." S0 T10
                                G4 T10; Wait for additional delay for filament to cool or soften
                                echo "unloading"
                                M291 R{"Unloading " ^ move.extruders[state.currentTool].filament} P"Retracting..." S0 T5
                                M98 P"0:/macros/filament/do_moves_for_unload.g"
                                echo "unloading complete"
                                  @garethky I use a macro, it show at the first page btw πŸ˜„ it's universal in one file (i just had to separate the purge loop to be able to cancel it) and i also like to be guide, i've done everything to be as simple and explicit as possible for the ease of use πŸ˜„ but i admit that it can be nice to use the built-in solution πŸ™‚
                                  also it detects if there's a filament, if not it skip the unload
                                  @OwenD wow it's a nice approach ! A bit too complicated for me but man, it's nice work πŸ™‚
                                  • garethkyundefined
                                    garethky
                                    Also, if you put this in your load.g
                                    echo "In PETG.load, calling M703"
                                    M703
                                    echo "In PETG.load, M703 returned"
                                    echo {move.extruders[state.currentTool].filament}
                                    and this in your config.g
                                    echo "PETG Config Loaded"
                                    Then click the load filament button in the UI, You will get this in the console:
                                    M701 S"PETG" M703
                                    PETG Config Loaded
                                    If you drop the same code into the unload macro you get different output:
                                    M702
                                    In PETG.unload, calling M703
                                    PETG Config Loaded
                                    In PETG.unload, M703 returned
                                    PETG
                                    So calls to M703 inside load.g don't appear to work. This is similar to how homing calls inside a homing file are illegal, so I'm not surprised. M703 inside of unload work just fine. So I love all of the optimizations above but I cant get any of them to work. I'm just going to ignore the blank string in load.g until variables show up.
