    Upgradet to RRF3 with some trouble
    • ErwinH78undefined
      ErwinH78
      I‘m building a new printer.... xyz homing is working so I tried true bed leveling... I tried with 3 and 4 points... but everytime I got this error:
      „warning: 3/4-point-bed compensation is deprecated and will be removed in a future firmware release. Please use G29 mesh bed compensation instead“
      I was confused because it worked fine in my old printer with the same configuration...
      So i tried to update to 3.2...
      I get the same error and additional to that after the 4. point the printhead moves in the middle of bed for homing bed... during homing duet loose connection and nozzle crashes into bed 🤦🏻‍♂️
      Anyone an idea?
      Board is Duet 3 6HC + RP4
      Printer: HevORT
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 26 2020 16:14:58 GMT+0200 (Mitteleuropäische Sommerzeit)
      G92 S2 ; clear bed high map
      G28 ; home
      M913 Z50 ; drop motor currents to 50%
      G30 P0 X60 Y40 Z-99999 ; probe near a leadscrew
      G30 P1 X60 Y370 Z-99999 ; probe near a leadscrew
      G30 P2 X365 Y370 Z-99999 ; probe near a leadscrew
      G30 P3 X365 Y40 Z-99999 S4 ; probe near a leadscrew and calibrate 3 motors
      M913 Z100 ; motor currents back to 100%
      G28Z
      M915 X Y Z R1 F0 S8 ; Disable stall for prevent false detect
      Config
      M550 P"RatRig VCORE Pro" ; set printer name
      ; M551 P"RatRig" ; Passwortschutz
      M667 S1 ; select CoreXY mode
      M669 K1 ;switch to CoreXY mode
      M569 P0.0 S1 ; physical drive 0.0 goes backwards
      M569 P0.1 S1 ; physical drive 0.1 goes backwards
      M569 P0.2 S1 ; physical drive 0.2 goes backwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5 ; set drive mapping
      M92 X80.00 Y80.00 Z800.00 E831.29 ; set steps per mm
      ; Slow
      M566 X400.00 Y400.00 Z100.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) JERK
      M201 X1500.00 Y1500.00 Z180.00 E10000.00 ; set accelerations (mm/s^2)
      M203 X2400.00 Y2400.00 Z500.00 E3000.00 ; set maximum speeds (mm/min)
      M906 X1500 Y1500 Z1500 E1000 I15 ; set motor currents (mA) and motor idle factor in percent
      M84 S30 ; Set idle timeout
      M208 X415 Y415 Z300 S0 ; set axis maxima
      M574 X1 S1 P"io0.in" ; configure sensorless endstop for low end on X
      M574 Y1 S1 P"io1.in" ; configure sensorless endstop for low end on Y
      ; Z leadscrew positions
      M671 x-8.298:217.911:444.12 Y2.021:430,231:2,021 S50
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F180 T3000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 x37.449 Y26.253 Z1.15 ; set Z probe trigger value, offset and trigger height wenn +wert, dann von z abziehen
      M557 X40:360 Y40:360 S80 ; define mesh grid
      ;M308 S0 P"temp1" Y"thermistor" A"Heizbett" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      ;M950 H0 C"out1" T0 ; create bed heater output on out0 and map it to sensor 0
      ;M143 H0 S110 ; set temperature limit for heater 0 to 120C
      ;M307 H0 A255.6 C558.3 D1.8 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit and PID settings
      ;M140 H0 ; map heated bed to heater 0
      ;M308 S1 P"temp0" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      ;M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
      ;M143 H1 S265 ; set temperature limit for heater 1 to 245C
      ;M307 H1 A384.5 C364.6 D3.3 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit and PID settings
      ; Fan Hotend
      ;M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      ;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      ; Fan Bauteilkühlung
      ;M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
      ;M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 ; define tool 0
      ;M572 D0 S0.08 ; Pressure Advance Factor
      ;M593 F42.19 ; Dynamic Advance Frequenz
      T0
        Phaedrux Moderator @ErwinH78
        @ErwinH78 said in Upgradet to RRF3 with some trouble:
        That should be G29 S2
        G28Z
        Missing space.
        Are you trying to do independen lead screw leveling?
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        Can you verify you're in 3.2 with M115?
        Can you post the results of M98 P"config.g"?
        • ErwinH78undefined
          ErwinH78
          hi... first of all thx for your time....
          --- ok i change
          G28Z
          Missing space.
          OK. changed
          yes during that the error occurs.
          Yes it is
          10.1.2021, 08:16:01 M115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-01-05
          here it is
          10.1.2021, 08:17:07 M98 P"config.g"
          Specify 1, 2, 3 or 4 X and Y coordinates in M671
          • ErwinH78undefined
            ErwinH78
            so i found an another misstake in the config.
            in M671 there was also a , intead of .
            so i tried it 5 times no. no error. seams it´s all fine now....
            thanks for your quick support 🙂
              Yes that would do it. Glad you figured it out.
