    how to config a ipcamera with dwc 3
    Duet Web Control
    345
    • denisvdbundefined
      denisvdb
      hello, how to make an ip camera work under dwc v3? what url should he use. my ip camera is a esp32-cam.
        What kind of url options are you given by your cam? I believe a still image stream should work.
        What version of DWC are you using specifically? 3.2?
        denisvdbundefined 1 Reply Last reply Reply Quote 0
        • hmortensenundefined
          hmortensen
          If it's the default ESP32-cam sketch, then this URL should work:
          http://<IP OF ESP>/capture
          • denisvdbundefined
            denisvdb @Phaedrux
            @Phaedrux
            Hello, i use a duet 2 wifi with rrf 3.2 en dwc 3.2.0
            I put the following in the camera config: http://192.168.1.27.
            with this url in a browser it work but no in dwc.
            Denis.
              hmortensen
              Have you tried with:
              http://192.168.1.27/capture
              • denisvdbundefined
                denisvdb @hmortensen
                @hmortensen
                no, i will try tonight
                • denisvdbundefined
                  denisvdb
                  it seems to work. but it captures an image every 15 or 20 sec. it is not possible to have the video stream? is there a doc on the config of the camera in v 3.2?
                  • denisvdbundefined
                    denisvdb
                    I just checked again it's an image every 5 sec
