    Need help with piezo Z probe and Simplify 3d combination
    602
    • fcwiltundefined
      fcwilt @luckyflyer
      @luckyflyer said in Need help with piezo Z probe and Simplify 3d combination:
      Ok so I'm trying to fully understand this. print_begin.g is a duet macro file, correct? I don't see filament config.g or start.g in my system section so they need to be created. Are there examples of them somewhere?
      Edit, I'll check the dozuki for more info.
      OK you know where in S3D you can put code to be executed at the start and end of a print - correct?
      In the place for the start of a print I simply put M98 P"print_begin.g".
      In the place for the end of a print I simply put M98 P"print_end.g".
      Then I created these files in the System directory using the Duet DWC. There is nothing special about the names I chose other than they are consistent with their use.
      I DO NOT use start.g because of when it is executed - before any S3D code - thus S3D code may override anything done in start.g.
      The files related to filament management are created when you create a new filament with the Duet DWC. Once they are created then you can edit them, again using the Duet DWC.
      Each filament you create has three associated files: load.g unload.g and config.g
      • luckyflyerundefined
        luckyflyer
        Yes I know where to put starting and ending code.
        You've told me enough that I should be able to get it from here.
        Thanks again. ...........Mark
        • fcwiltundefined
          fcwilt @luckyflyer
          If you get stuck don't hesitate to ask more questions.
            luckyflyer
            I have print_begin_.g and print_end.g in the system directory. I just copied and pasted my start and stop scripts into these files. I replaced the start and stop scripts in s3d with their respective M98 commands. It works except the nozzle still has a start temp of 200c instead of the 160c in the begin_print.g file. I'm running S3d 4.1.2. I included my start script at the beginning of this post.
            Ok I figured it out , all temperature controllers in S3d needs to be disabled for this to work correctly.
            Depundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            • Depundefined
              Dep @luckyflyer
              @luckyflyer can you tell how you turned off temperature controllers in S3D?
              • fcwiltundefined
                fcwilt @luckyflyer
                It certainly doesn't hurt to do that but you can tweak what code S3D generates.
                I have attached my S3D firmware settings file. You can save your existing settings to your own file and load these if you want to see what I am doing. Then you can restore you settings from your file.
                fcw Simplify3D.frm.txt
                  luckyflyer
                  @Dep
                  In process1, temperature tab, toward bottom "remove temperature controller". I did this for bed and h.e.
                    luckyflyer
                    Ok so I'm making pretty good prints, I have my print_start and print_end files working correctly. Now on to setting up filament profiles.
                      luckyflyer
                      @fcwilt
                      Since my printer is a relatively simple one tool machine I've been looking for examples of load.g unload.g and config.g that would be appropriate for that type of printer. Really all I want is to have seperate profiles for pla,abs and tpu. Can you point me to where I can find examples of this type of filament profile?
                      Thanks
                      Edit,
                      So it seems that all I really need is a separate config.g for each filament since I load and unload filament manually. .....Right?
                      • fcwiltundefined
                        fcwilt @luckyflyer
                        Glad to hear things are moving forward for you.
                        I only edit the config.g file for my filaments - see below for one of mine - the M291 are optional but I like to see what is happening:
                        Notice that this is for Amazon - Gray PLA - I have found that different brands and even different colors sometimes need specific settings.
                        M291 R"PLA - Amazon - Gray" P"Configuring..." T0
                        M221 S100 D0    ; set extrusion multiplier
                        G10 S200 R0	; set extruder temps
                        M140 S60 R0	; set bed temps
                        M291 R"PLA - Amazon - Gray" P"Configuring - Done" T3
                          luckyflyer
                          @fcwilt
                          Thank you again.
