    U-axis without limit
    Firmware wishlist
    11
    33
    2.8k
    • tntjetundefined
      tntjet
      @Phadrux The pendant only recognises the axis if it is named U. A,B,C or D wont work
        Phaedrux Moderator @tntjet
        @tntjet Do you have a link to the pendant?
        • tntjetundefined
          tntjet
          @Phaedrux
          https://forum.duet3d.com/topic/11389/cnc-style-pendant/2?_=1607728006898
          • cpiriusundefined
            cpirius
            I'm having trouble with this as well for an openpnp machine. Trying to move from using an "extruder" to a rotary axis for part rotation. But whether I define:
            M584 X0 Y2 Z1 A3
            or
            M584 X0 Y2 Z1
            M584 U3 R1
            or
            M584 X0 Y2 Z1
            M584 A3
            My rotary axis, either A or U, still only lets me move from 0 - 200 position. There is no infinite rotation.
            Is there something beyond configuring the axis as a rotation axis to remove the limits?
            Thanks
            Stephen6309undefined 1 Reply Last reply Reply Quote 0
            • Stephen6309undefined
              Stephen6309 @cpirius
              @cpirius AFAIK, you have to define it as an extruder. Extruders have no limits on distance.
              tntjetundefined 1 Reply Last reply Reply Quote 0
              • tntjetundefined
                tntjet @Stephen6309
                @Stephen6309 they certainly do have unlimited rotation , unfortunately not helpful for cnc applications nor using a pendant.
                  I have added this to my list to look into for RRF 3.3.
                  tntjetundefined cpiriusundefined 2 Replies Last reply Reply Quote 0
                  • tntjetundefined
                    tntjet @dc42
                    @dc42 thank you David.
                    • cpiriusundefined
                      cpirius @dc42
                      @dc42 Awesome, thanks 🙂
                      • RandyL00123undefined
                        RandyL00123
                        @wuem said in U-axis without limit:
                        imit. Ev
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                        Rn allows you to set an axis as rotational. Like printing on a pot can maybe?
                        • rryundefined
                          rry
                          Hi David. Thank your for good job!
                          Can someone did continues rotation?
                          I expect something like this:
                          M584 X1 R1; set X axis as continues rotational
                          //on working program
                          G1 X F100 ; rotate X continuesly with speed 100 or best way to use some new M code for rotation
                          G1 Y10 F200;
                          G1 X F300; after Y moved to 10 and some other things rotate X with speed 300
                          G1 Y-10 F200;
                          G1 X F0; after Y moved to -10 stop X rotation
                          or may be somebody can suggest working solution, then I need continues rotation on pulling tape or similar.
                          One solution I see to use analog output connected to external drive with analog speed control like Spindle.
                          Thank you
                          • o_lampeundefined
                            o_lampe @rry
                            @rry
                            I guess for combined XY moves you have to define an angle for X, not just a speed.
                            EG. positive angle = clockwise, neg. angle = CCW
                            G1 X1000 Y10 F100 ; turn X axis 10 times (100rad = 1 turn) while moving Y 10mm
                            rryundefined 1 Reply Last reply Reply Quote 0
                            • rryundefined
                              rry @o_lampe
                              @o_lampe
                              Yes, you are right, my g-code is wrong, i only tried to show idea that for continues rotation distance does not matter, you need only speed and direction.
                              seem the most correct way will use new M code for that purpose for example:
                              Mxxx Xnnn; start to rotate axis X with speed xxx (non blocking command!)
                              Mxxx A-600; rotate axis A (setup A as continuesly rotation in config) with speed 600 counter-clockwise
                              • joshuabirdundefined joshuabird referenced this topic
