Bl touch doesn't deploy
@hotrodford said in Bl touch doesn't deploy:
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.2.1 on Wed Jan 13 2021 02:45:17 GMT-0600 (Central Standard Time)
;M280 P3 S10 ; deploy BLTouch
M950 S0 C"exp.heater3"The M950 belongs in config.g. The deploy file still needs an M280 command. The difference is that instead of M280 P3 you would have M280 P0.
Perhaps would be a good idea to generate a config file using the online tool for comparison.
@Phaedrux i did use the on line generater
G31 P25 x-8 y-15 z2
G31 P25 X-20 Y50.0 Z0.0
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger heightYou've also got G31 3 times. Only the last one will have effect.
Here's an example
; Z-Probe M950 S0 C"io3.out" ; create servo pin 0 for BLTouch M558 P9 C"^io3.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P25 X-44 Y-17 Z2 ; set Z probe trigger value, offset and trigger height M557 X5:190 Y5:215 S10 ; define mesh grid
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Jan 05 2021 23:45:25 GMT-0600 (Central Standard Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Jan 05 2021 23:45:26 GMT-0600 (Central Standard Time) M280 P0 S90 ; retract BLTouch
@jay_s_uk said in Bl touch doesn't deploy:
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-02-09b1
This is part of the problem. Your config file is formatted for RRF3 but your firmware is only RRF2.
This will go much smoother after updating your firmware to RRF3.
First download these zip files.
Then upload the 3.0 zip file to the system tab in the web interface.
Then after it installs the firmware and reboots, upload the 3.2 zip file.https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
@Phaedrux thanks hope this is the problem.
That will get you back on track, but you'll still need to clean up your files to mimic the examples I posted.
Your pin names will stay the same. exp.heater3 and zprobe.in But you should only have one G31 command and you need to remove the M950 from your deploy and retract files.
Got it upgrade and the error is gone. but the bltouch will not deploy.
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X10 Y10 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.2.1 on Wed Jan 13 2021 16:04:06 GMT-0600 (Central Standard Time)
M280 P0 S10 ; deploy BLTouch -
Are you sure you're connected to heater pin 3?
Photo of your wiring?
Check continuity?
Check crimps? -
ok now i can make it deploy and retract. but when I home It . it gives me and error of zprobe already triggered.
Double check your white wire as that one is the signal wire.
Is this a clone BLtouch or genuine? What version?
