    IMPORTANT ISSUE with bed temp controller
    Firmware developers
    fire risk
    8
    86
    4.4k
    • jrocklandundefined
      jrockland @Luke'sLaboratory
      @Luke-sLaboratory the relay turn off as soon as they are not fed power
        jrockland @Veti
        @Veti looked online for ssr relays
          jrockland @Veti
          @Veti you are right, they are ntc 3950. Ill have to find out how to change that
          • Vetiundefined
            Veti @jrockland
            @jrockland said in IMPORTANT ISSUE with bed temp controller:
            ntc 3950
            they are not the best and become inaccurate at high temperatures.
            jrocklandundefined 1 Reply Last reply Reply Quote 0
              jrockland
              Anyway thank for all the answers, tones of thing to look at;
              like why my board seem to work the opposite way ? (compared to my other 6hc's)
              Stop.G files (that files is empty ??)
              thermistor: wrong model ? (ill have to find how to change that)
              port 0.out instead of 3.out (will move some stuff around)
              Also I will add an external fail safe (I should had done that long time ago)
              Just to reassure anyone, the relays does shut down as soon as I send a M999/M112 or shut the board off. even if they are written as "!out.3".... maybe the connection to the board is wrong.
              Luke'sLaboratoryundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk
                if you use out0 don't forget to add power in for it
                  jrockland @Veti
                  @Veti I know, but with what I use them for they are easy to get and cheap..: I prototype parts so I actually destroy parts as a daily task. I basically apply change, then run the project until it break. then make it better. I crashed so many hot ends I buy those sensors in 50 packs XD
                    jrockland @jay_s_uk
                    @jay_s_uk wait.. just want to make sure im not wrong here.. i mean C"io0.out".. my bad. too much power out of OUT0.
                    • Luke'sLaboratoryundefined
                      Luke'sLaboratory @jrockland
                      This is positive.
                      Could you post model #'s or pictures of the relays used? Still want to get to the bottom of why you overheated by a considerable margin
                      Luke
                      http://lukeslab.online
                      jrocklandundefined 2 Replies Last reply Reply Quote 0
                      • Vetiundefined
                        Veti @jrockland
                        @jrockland
                        you forgot the most imporant part. the frequency for the ssr.
                          @Luke-sLaboratory let me check, Ill have to open an other part of the machine for that.
                            @Luke-sLaboratory Actually when I read the code, bang bang mode wasn't deactivate, might explain a lot. it always been deactivated but that specific machine crashed hard before the last update and we had to re write the whole thing.
                            Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
                              @jrockland If the previous configuration was bang-bang, and instead we're using PWM @500hz, that could be a huge indicator of an issue.
                              Luke
                                @Luke-sLaboratory Ill have to read more about bang bang but if I check on my other machines it is deactivated everywhere
                                  Using an inverted heater output isn't safe. When you power up, you are relying on the Duet booting up and running that M950 command to turn the heater off. If any of that fails (for example, something prevents the Pi from running, e.g. the SD card goes bad), then the heater will remain on.
                                  What connection are you using that requires an inverted heater output?
                                    @jrockland info on the relays would still be useful, but yes, probably should look into disabling PWM control if it was previously operated bang-bang and it was successful.
                                    Luke
                                      jrockland @dc42
                                      @dc42 well that is the thing, it is inverted so it doesn't turn on as soon as I turn the board on. that is really weird. Ill have the board sent to my tech so he can look at it.
                                      if I remove the inversion the board feed power as soon as it turn on (checked with a meter)
                                      Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • Vetiundefined
                                        Veti @jrockland
                                        this suggests you got the wrong ssr.
                                          jrockland @Veti
                                          @Veti ssr's are out of the equation, they are disconnected. Im testing the board whit a multimeter
                                            dc42 administrators @jrockland
                                            We really need to know what sort of relay or SSR you are using, and how you have connected it to the Duet. If it's a relay board then it may be better to connect it to an IO_x_OUT pin instead; but a SSR is better because it allows you to use PWM and hence PID.
                                            Luke'sLaboratoryundefined jrocklandundefined 2 Replies Last reply Reply Quote 0
