    DAA Ringing help please
    474
    • Paskalundefined
      Paskal
      I have a problem tuning my printer. This is a Hypercube Evolution with 17 hs4401 engines. Settings here. Hotend is E3D V6 with BMG.
      Thank you for the advice.
      config.g Config file
      IMG_20210113_213814.jpg IMG_20210113_213759.jpg IMG_20210113_213750.jpg IMG_20210113_213721.jpg IMG_20210113_213707.jpg IMG_20210113_213645.jpg
        https://forum.duet3d.com/topic/20791/daa-ringing-help-please
        Take a look?
        • Paskalundefined
          Paskal
          That's exactly what I was looking at, but I don't know what the appropriate settings are for my engines and printer.
            Well no one does without some testing. In that thread there are some suggestions made on how to find good results.
            I think the hypercube design is prone to ringing due to the heavy rods. There is a lot of mass to sling around with only printed parts to hold it back, so you'll likely be limited to low jerk and accel values for external walls if you want to eliminate the ringing effect. Most slicers allow you to set separate jerk/accel values for different print moves. So you can have slower outer walls and faster for the rest where looks don't matter.
            I think a good place to start would be 600 jerk and 600 accel.
            Print a ringing tower and use various values along the way to try and find a good one.
            • Paskalundefined
              Paskal
              If I understand correctly M201 xy600 and M566 xy600
              • Paskalundefined
                Paskal
                  yes to M201 and M566
                  and those speeds look reasonable.
                  • Paskalundefined
                    Paskal
                    Thanks, I'm going to check out some script.
                    • Paskalundefined
                      Paskal
                      Is it right for the test?
                      ; 0.2mm layer, 8 bands 5mm each, total height 40mm
                      {if layer_num== 1}M572 D0 S0.06
                      {elsif layer_num== 25}M204 P300
                      {elsif layer_num== 50}M204 P400
                      {elsif layer_num== 75}M204 P500
                      {elsif layer_num== 100}M204 P600
                      {elsif layer_num== 125}M204 P700
                      {elsif layer_num== 150}M204 P800
                      {elsif layer_num== 175}M204 P900
                      {elsif layer_num== 200}M204 P1000
                      {elsif layer_num== 225}M204 P1200
                      {elsif layer_num== 250}M204 P1400
                      {endif}
                        Yes that should work to change the print acceleration
                        • Paskalundefined
                          Paskal
                          P300 -> P1400 ( +100 )
                          P1500 -> P2400
