    IMPORTANT ISSUE with bed temp controller
    Firmware developers
    fire risk
    8
    86
    4.3k
    • Vetiundefined
      Veti @jrockland
      @jrockland said in IMPORTANT ISSUE with bed temp controller:
      pretty sure it is what there telling us to do in the wiring diagram.. I might be wrong..
      what wiring diagram?
      • Luke'sLaboratoryundefined
        Luke'sLaboratory @jrockland
        @jrockland IOs are fine, but you're trying to use a PWM signal (based on PID values) instead of a simple off/on. the mechanical relay can't keep up, and it may cause some other issues like latching on and causing the issue described. You'll need to re-enable Bang-bang, which will output either full voltage or none.
        Luke
        http://lukeslab.online
        jrocklandundefined 2 Replies Last reply Reply Quote 0
        • jrocklandundefined
          jrockland @Veti
          @Veti O don't worry for me, theses machines are intended to crash so they have fire extinguishing system in place. and I don't run them in my house.
          ever seen an axis with over 60lbs of torque crash ? parts goes flying XD
            jrockland @Luke'sLaboratory
            @Luke-sLaboratory That would explain why it was working before the update, bang bang was probably activated before...
            I will try to find how to write it properly using bang bang.
            • fcwiltundefined
              fcwilt @jrockland
              This post is deleted!
                @Luke-sLaboratory hmm wait if I look at my config file bang bang IS activated..
                  jrockland
                  @fcwilt you where right (before deleting your comment) but my config was set as using bang bang..
                  • fcwiltundefined
                    fcwilt @jrockland
                    Even with the slow rate of "bang bank" a mechanical relay is not a good choice.
                    jrocklandundefined 1 Reply Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @jrockland
                      I saw that someone had already mentioned that issue so I tried to delete mine.
                        jrockland @fcwilt
                        @fcwilt true, probably why they where changed on the other machines
                          jrockland
                          Good news tho, the 3/4 inch aluminum bed survived (still straight). the only thing that died is the embedded magnets (n52).. Ill get those replaced then work on the gcode once the board is back.
                            jrockland
                            reprap is getting better and better, and those 6hg/3hc boards are really solid. we blown multiple motors and heaters core (I remember something crashed IN the board hard enough that the thin metal door bended and shorted the board) and it still running strong.
                            I tried to delete the post as it look like bang bang was deactivated, so not a firmware issue. anyway probably my bad when I wrote the gcode.
