    IMPORTANT ISSUE with bed temp controller
    Firmware developers
    fire risk
    8
    86
    4.2k
    • Luke'sLaboratoryundefined
      Luke'sLaboratory @jrockland
      @jrockland info on the relays would still be useful, but yes, probably should look into disabling PWM control if it was previously operated bang-bang and it was successful.
      Luke
      http://lukeslab.online
      • jrocklandundefined
        jrockland @dc42
        @dc42 well that is the thing, it is inverted so it doesn't turn on as soon as I turn the board on. that is really weird. Ill have the board sent to my tech so he can look at it.
        if I remove the inversion the board feed power as soon as it turn on (checked with a meter)
        Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • Vetiundefined
          Veti @jrockland
          @jrockland said in IMPORTANT ISSUE with bed temp controller:
          this suggests you got the wrong ssr.
          jrocklandundefined 1 Reply Last reply Reply Quote 0
            jrockland @Veti
            @Veti ssr's are out of the equation, they are disconnected. Im testing the board whit a multimeter
              dc42 administrators @jrockland
              We really need to know what sort of relay or SSR you are using, and how you have connected it to the Duet. If it's a relay board then it may be better to connect it to an IO_x_OUT pin instead; but a SSR is better because it allows you to use PWM and hence PID.
              Luke'sLaboratoryundefined jrocklandundefined 2 Replies Last reply Reply Quote 0
                Luke'sLaboratory @dc42
                @dc42 He's talking about the actual board output, but I don't remember if i'm able to measure V_in across inactive outputs or not, since the ground is switched
                Luke
                  jrockland @dc42
                  @dc42 on that specific machine we still use the old SRD-05VDC-SL-C, apparently we haven't blown them up yet. so no SSR'S on that one.
                  problem is probably in my gcode.
                  Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
                    SRD-05VDC-SL-C
                    Oh - so its a mechanical switch you were trying to drive with PWM. Well, that about "solves" it, other than inverting the heater signal. Datasheet shows ratings for 300 electrical switches/min, with only 30 mechanical switches/min allowed.
                    FWIW - this is why we always ask for the config.g when diagnosing issues.
                    Luke
                    • Vetiundefined
                      Veti
                      as i said not having a quality ssr gives you a good chance of burning down your house
                      get some quality components like
                      Omron G3NA-210B-DC5 (10A) or Crydom D2425 (25A) or Crydom 84134000 (10A) SSR
                        jrockland @Luke'sLaboratory
                        @Luke-sLaboratory driving relays with io's isn't the right way ? pretty sure it is what there telling us to do in the wiring diagram.. I might be wrong..
                        Vetiundefined Luke'sLaboratoryundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
                        • Vetiundefined
                          Veti @jrockland
                          what wiring diagram?
                            @jrockland IOs are fine, but you're trying to use a PWM signal (based on PID values) instead of a simple off/on. the mechanical relay can't keep up, and it may cause some other issues like latching on and causing the issue described. You'll need to re-enable Bang-bang, which will output either full voltage or none.
                            Luke
                              jrockland @Veti
                              @Veti O don't worry for me, theses machines are intended to crash so they have fire extinguishing system in place. and I don't run them in my house.
                              ever seen an axis with over 60lbs of torque crash ? parts goes flying XD
                                @Luke-sLaboratory That would explain why it was working before the update, bang bang was probably activated before...
                                I will try to find how to write it properly using bang bang.
                                • fcwiltundefined
                                  fcwilt @jrockland
                                  This post is deleted!
                                    @Luke-sLaboratory hmm wait if I look at my config file bang bang IS activated..
                                      jrockland
                                      @fcwilt you where right (before deleting your comment) but my config was set as using bang bang..
                                      • fcwiltundefined
                                        fcwilt @jrockland
                                        Even with the slow rate of "bang bank" a mechanical relay is not a good choice.
                                        • fcwiltundefined
                                          fcwilt @jrockland
                                          I saw that someone had already mentioned that issue so I tried to delete mine.
                                            jrockland @fcwilt
                                            @fcwilt true, probably why they where changed on the other machines
