DAA Ringing help please
Printing a ringing tower and modify the gcode at various z heights to change the accell/jerk/speed the values on the way up. This can be a big help for tuning out ringing like this. Similar to using a temp tower to find the ideal temp.
The first step is to find the lowest speed settings that doesn't have any ringing and work your way up.
If there is no speed where ringing can be eliminated then It's likely mechanical slop.
Also, disable DAA entirely until you've determined if it's a mechanical issue or not as it could be muddying the waters.
Well it definitely gets worse at the high end of acceleration.
For my external walls if I want absolutely no sign of ringing I use 600 accel and 600 jerk (and then higher for other print moves). So maybe give that a shot.
Though there still appears to be some additional mechanical noise that shows up in the repeating ridges on the long straight that don't seem to die down.
Photo of your printer?
DAA works best when XY jerk is low, jerk mode is 0, and acceleration is high. Your slicer may insert commands to change the jerk (M205 or M566) or acceleration (M201 or M204), so check that your gcode print file doesn't contain those.
The disadvantage of setting jerk too low is that it slows down curves.
Did a lot of test prints and found out that especially decreasing the maximum printing acceleration (M204) is having a huge impact on ringing.
Best values for outer shells I've found so far:
M566 X300 Y300 M201 X6000 Y6000 M204 P500 Added this to my S3D post-processing script:
[...] elif line.startswith('; feature outer perimeter'): linesNew.append('; feature outer perimeter\nM566 X300 Y300\nM201 X6000 Y6000\nM204 P500\n') elif line.startswith('; feature inner perimeter'): linesNew.append('; feature inner perimeter\nM566 X1000 Y1000\nM201 X2000 Y2000\nM204 P10000\n') elif line.startswith('; ; feature solid layer'): linesNew.append('; feature solid layer\nM566 X1000 Y1000\nM201 X2000 Y2000\nM204 P10000\n') elif line.startswith('; feature infill'): linesNew.append('; feature infill\nM566 X1000 Y1000\nM201 X2000 Y2000\nM204 P10000\n') [...] Will test this further.
Of course this will slow down the print massive but only for the outer shell. Let's see if this is something I can live with
Beside of that I think I also have a Y axis issue because ringing is always a lot of "stronger" on the Y axis. X axis looks quite better.
@MartinNYHC said in DAA Ringing help please:
Different mass compared to just X.
I think I cracked it down and found the best compromise between ringing and accel/jerk. It turned out that my ringing frequency is as low as 4.1.
But bet? Now I have another problem
Gcode looks like
[...] ; feature outer perimeter M566 X500 Y500 M201 X6000 Y6000 M204 P500 G1 X155.200 Y174.800 F9000 G92 E0.0000 G1 X155.200 Y155.200 E0.6128 F900 G1 X174.800 Y155.200 E1.2256 G1 X174.800 Y174.800 E1.8384 G1 X155.200 Y174.800 E2.4511 ; feature solid layer M566 X1000 Y1000 M201 X2000 Y2000 M204 P10000 G1 X156.789 Y173.760 F9000 G92 E0.0000 G1 X156.240 Y173.211 E0.0243 F1800 G1 X156.240 Y172.645 E0.0420 G1 X157.355 Y173.760 E0.0913 G1 X157.921 Y173.760 E0.1090 G1 X156.240 Y172.079 E0.1833 G1 X156.240 Y171.513 E0.2010 [...] Although the M566/M201/M204 values are set correctly at the right positions (and verified during printing via console) the solid layer is not printed with the current active values. It is as "lazy" as the outer permimeters. How can that be? Or is it not supported to change these parameters frequently during prints?
Got rid of it by disabling DAA for non outer permimeters. Will test this now.
If someone is interested here's the code snippet:
linesNew = [] for line in lines: if line.startswith('M557'): linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+ S\d+:\d+', gridNew, line, flags=re.MULTILINE)) elif line.startswith('; feature'): if "outer perimeter" in line: linesNew.append(line + 'M566 X500 Y500\nM201 X6000 Y6000\nM204 P500\nM593 F4.1\n') else: linesNew.append(line + 'M566 X1000 Y1000\nM201 X2000 Y2000\nM204 P10000\nM593 F0\n') else: linesNew.append(line) return linesNew -
Don't use M201 at all in this case as it's setting the upper limit. Just set it once in config.g. M204 is the intended way to change it during the print. So in your example, M204 isn't having any effect because 10000 is greater than the 2000 limit set.
Makes sense. Thanks for pointing this out.
