Error when trying to update- Duet3_SBCiap32_MB6HC.bin missing
Firmware installation
798
    cdthomas9
    Had some issues with the latest update not being pushed to the 3HC board, the 6HC showed 3.2 but the 3HC was on 3.0RC1. I uploaded the latest set of Duet3 bin files from the zip, and clicked Yes when prompted to run the update. I immediately got the error Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3_SBCiap32_MB6HC.bin I can't find this file anywhere, not online or anything. Right now the Duet is missing Tool 0 heater controls and temp reading, showing N/A
      Veti
      its part of the 3.2 update
      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
        As you are running with attached RPi or other SBC, it should have been installed when you ran apt update and apt upgrade.
          cdthomas9
          Yes, I have a Pi 4 attached. Ran the sudo apt update and sudo apt upgrade a couple of times, the first time everything ran through good. looks like the 3HC board is still on the old firmware, I can't get it to update for anything. The 6HC and DWC both look like they updated fine using apt
            cdthomas9
            @cdthomas9 said in Error when trying to update- Duet3_SBCiap32_MB6HC.bin missing:
            I don't see the Duet3_SBCiap32_MB6HC.bin anywhere in the file manifest. I see Duet3_SDiap32_MB6HC.bin
            but that's definitely a different file. I'm guessing the file it's saying it needs is due to the SBC interaction with the 6HC board?
              cdthomas9
              I am also getting a number of errors when the board resets:
              1/15/2021, 9:56:25 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 3
              1/15/2021, 9:56:20 AM Connection interrupted, attempting to reconnect...
              1/15/2021, 9:56:20 AM Emergency stop, attemping to reconnect...
              1/15/2021, 9:56:06 AM Error: M307: Heater 1 not found
              1/15/2021, 9:56:06 AM Warning: M950: Command is not supported
              1/15/2021, 9:56:06 AM Warning: M308: Invalid Z probe index
              1/15/2021, 9:56:06 AM Error: M906: Response timeout: CAN addr 1, req type 6043, RID=6
              1/15/2021, 9:56:05 AM Error: M92: Response timeout: CAN addr 1, req type 6042, RID=5
              1/15/2021, 9:56:05 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
              1/15/2021, 9:56:04 AM Error: M350: Response timeout: CAN addr 1, req type 6042, RID=4
              1/15/2021, 9:56:04 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
              1/15/2021, 9:56:04 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 4
              1/15/2021, 9:56:04 AM Error: M584: Response timeout: CAN addr 1, req type 6042, RID=3
              undefined 1 Reply Last reply 15 Jan 2021, 15:15 Reply Quote 0
                Veti @cdthomas9
                @cdthomas9
                post your config. but the error tell you that you have errors in your config
                  cdthomas9
                  M669 K1 ; select CoreXY mode
                  M569 P0.0 S0 ; physical drive 0.0 goes forwards
                  M569 P0.1 S0 ; physical drive 0.1 goes forwards
                  M569 P0.2 S0 ; physical drive 0.2 goes forwards
                  M569 P0.3 S0 ; physical drive 0.3 goes forwards
                  M569 P0.4 S0 ; physical drive 0.4 goes forwards
                  M569 P0.5 S0 ; physical drive 0.5 goes forwards
                  M569 P1.0 S1 ; physical drive 1.0 goes backwards
                  M569 P1.1 S0 ; physical drive 1.0 goes forwards
                  M569 P1.2 S0 ; physical drive 1.0 goes forwards
                  M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0 ; set drive mapping
                  M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z480.00 E1200.00 ; set maximum speeds (mm/min)
                  M906 X800 Y800 Z800 E940 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M671 X33.2:33.2:355.5:355.5 Y447.5:-61:447.5:-61 S20 ; leadscrew definition
                  M208 X374 Y360 Z430 S0 ; set axis maxima
                  M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in
                  M574 Y1 S1 P"!io1.in" ; configure active-low endstop for low end on Y via pin io1.in
                  M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                  M558 P9 C"^io7.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X-48 Y15 Z2.291 ; set Z probe trigger value, offset and trigger height
                  M557 X15:360 Y15:345 S35 ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                  M307 H0 A232.9 C532.1 D1.7 V23.8 B0 ; heater definition as provided by auto tune
                  M143 H0 S130 ; set temperature limit for heater 0 to 130C
                  M308 S1 P"1.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 1.temp0
                  M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
                  M307 H1 B0 S1.00 ; default heater definition
                  ;M307 H1 A570.8 C282.2 D 4.1 V23.8 B0 ; heater definition as provided by auto tune
                  M950 F0 C"1.out6" Q500 ; create fan 0 on pin 1.out6 and set its frequency
                  M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
                  M950 F1 C"1.out7" Q500 ; create fan 1 on pin 1.out7 and set its frequency
                  M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                  M563 P0 D0 H1 F-1 ; define tool 0
                  ; Custom Settings
                  M564 H0 ; Allow movement before axes are homed
                    cdthomas9
                    I've been running with this config for a while now, when running the 3.2 update it just broke
                      cdthomas9
                      It looks like any command that requires it to talk to the 3HC fails with a CAN timeout? The 3HC is blinking in sync with the 6HC though. The errors I'm getting all have a motor or heater defined on the 3HC, I have that set for the extruder motor, heater and thermistor.
                      1/15/2021, 12:51:26 PM Error: M307: Heater 1 not found
                      1/15/2021, 12:51:26 PM Warning: M950: Command is not supported
                      1/15/2021, 12:51:26 PM Warning: M308: Invalid Z probe index
                      1/15/2021, 12:51:26 PM Error: M906: Response timeout: CAN addr 1, req type 6043, RID=6
                      1/15/2021, 12:51:25 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
                      1/15/2021, 12:51:25 PM Error: M92: Response timeout: CAN addr 1, req type 6042, RID=5
                      1/15/2021, 12:51:24 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
                      1/15/2021, 12:51:24 PM Error: M350: Response timeout: CAN addr 1, req type 6042, RID=4
                      1/15/2021, 12:51:23 PM Error: M584: Response timeout: CAN addr 1, req type 6042, RID=3
                      1/15/2021, 12:51:23 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 4
                        I would suggest trying a fresh download and re-image of DuetPi on your Pi SD card followed by a sudo apt update/upgrade. Seems like you may be using the image that came on the card with the Duet3?
                        https://pkg.duet3d.com/DuetPi-lite.zip
                        https://pkg.duet3d.com/DuetPi.zip
                          cdthomas9
                          Yes, I was. I've run the updates and upgrades since though. Is that something that should be done every so often? Reimage the SD card to the latest DuetPi?
                          undefined 1 Reply Last reply 15 Jan 2021, 19:06 Reply Quote 0
                            Phaedrux Moderator @cdthomas9
                            @cdthomas9 No, but the image was updated since and re-imaging has solved problems for others in the past, so worth a shot.
                              cdthomas9
                              I just ran M997 B1 to manually force the 3HC to update to 3.2, and it looks like that fixed it
                                cdthomas9
                                Can I run a PID tuning on the heater attached to the 3HC now? I remember I couldn't before, wasn't sure if 3.2 fixed it
                                undefined 1 Reply Last reply 15 Jan 2021, 19:23 Reply Quote 0
                                  @cdthomas9 the heater tuning algorithm has been updated in 3.2, which paves the way for tuning on tool boards and expansions in 3.3 I believe.
                                  From your first post with the M997 error message I thought you had already tried to manually update it.
                                    cdthomas9
                                    I did, but I wasn't trying to run the expansion board directly or separately. I was letting it run through and update everything in bulk, at least I think I was...
                                      cdthomas9
                                      I ran a M997 to update all firmware, thinking that the command would run through the main board and expansion boards
                                        Ah ok. Well glad it's sorted out. Now that you're on a full release with all boards synced the sudo apt update should work going forward.
                                          cdthomas9
                                          Thanks! What was the file it was looking for? the SBC iap file? I saw an SD iap file but not that one. I couldn't find that anywhere
                                          undefined 1 Reply Last reply 16 Jan 2021, 07:13 Reply Quote 0
                                          10 out of 23
