    Error when trying to update- Duet3_SBCiap32_MB6HC.bin missing
    Firmware installation
    832
    • cdthomas9undefined
      cdthomas9
      @cdthomas9 said in Error when trying to update- Duet3_SBCiap32_MB6HC.bin missing:
      I don't see the Duet3_SBCiap32_MB6HC.bin anywhere in the file manifest. I see Duet3_SDiap32_MB6HC.bin
      but that's definitely a different file. I'm guessing the file it's saying it needs is due to the SBC interaction with the 6HC board?
        cdthomas9
        I am also getting a number of errors when the board resets:
        1/15/2021, 9:56:25 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 3
        1/15/2021, 9:56:20 AM Connection interrupted, attempting to reconnect...
        1/15/2021, 9:56:20 AM Emergency stop, attemping to reconnect...
        1/15/2021, 9:56:06 AM Error: M307: Heater 1 not found
        1/15/2021, 9:56:06 AM Warning: M950: Command is not supported
        1/15/2021, 9:56:06 AM Warning: M308: Invalid Z probe index
        1/15/2021, 9:56:06 AM Error: M906: Response timeout: CAN addr 1, req type 6043, RID=6
        1/15/2021, 9:56:05 AM Error: M92: Response timeout: CAN addr 1, req type 6042, RID=5
        1/15/2021, 9:56:05 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
        1/15/2021, 9:56:04 AM Error: M350: Response timeout: CAN addr 1, req type 6042, RID=4
        1/15/2021, 9:56:04 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
        1/15/2021, 9:56:04 AM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 4
        1/15/2021, 9:56:04 AM Error: M584: Response timeout: CAN addr 1, req type 6042, RID=3
        • Vetiundefined
          Veti @cdthomas9
          @cdthomas9
          post your config. but the error tell you that you have errors in your config
            cdthomas9
            M669 K1 ; select CoreXY mode
            M569 P0.0 S0 ; physical drive 0.0 goes forwards
            M569 P0.1 S0 ; physical drive 0.1 goes forwards
            M569 P0.2 S0 ; physical drive 0.2 goes forwards
            M569 P0.3 S0 ; physical drive 0.3 goes forwards
            M569 P0.4 S0 ; physical drive 0.4 goes forwards
            M569 P0.5 S0 ; physical drive 0.5 goes forwards
            M569 P1.0 S1 ; physical drive 1.0 goes backwards
            M569 P1.1 S0 ; physical drive 1.0 goes forwards
            M569 P1.2 S0 ; physical drive 1.0 goes forwards
            M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0 ; set drive mapping
            M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
            M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z480.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X800 Y800 Z800 E940 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M671 X33.2:33.2:355.5:355.5 Y447.5:-61:447.5:-61 S20 ; leadscrew definition
            M208 X374 Y360 Z430 S0 ; set axis maxima
            M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in
            M574 Y1 S1 P"!io1.in" ; configure active-low endstop for low end on Y via pin io1.in
            M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
            M558 P9 C"^io7.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X-48 Y15 Z2.291 ; set Z probe trigger value, offset and trigger height
            M557 X15:360 Y15:345 S35 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            M307 H0 A232.9 C532.1 D1.7 V23.8 B0 ; heater definition as provided by auto tune
            M143 H0 S130 ; set temperature limit for heater 0 to 130C
            M308 S1 P"1.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 1.temp0
            M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
            M307 H1 B0 S1.00 ; default heater definition
            ;M307 H1 A570.8 C282.2 D 4.1 V23.8 B0 ; heater definition as provided by auto tune
            M950 F0 C"1.out6" Q500 ; create fan 0 on pin 1.out6 and set its frequency
            M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"1.out7" Q500 ; create fan 1 on pin 1.out7 and set its frequency
            M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
            M563 P0 D0 H1 F-1 ; define tool 0
            ; Custom Settings
            M564 H0 ; Allow movement before axes are homed
              cdthomas9
              I've been running with this config for a while now, when running the 3.2 update it just broke
                cdthomas9
                It looks like any command that requires it to talk to the 3HC fails with a CAN timeout? The 3HC is blinking in sync with the 6HC though. The errors I'm getting all have a motor or heater defined on the 3HC, I have that set for the extruder motor, heater and thermistor.
                1/15/2021, 12:51:26 PM Error: M307: Heater 1 not found
                1/15/2021, 12:51:26 PM Warning: M950: Command is not supported
                1/15/2021, 12:51:26 PM Warning: M308: Invalid Z probe index
                1/15/2021, 12:51:26 PM Error: M906: Response timeout: CAN addr 1, req type 6043, RID=6
                1/15/2021, 12:51:25 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
                1/15/2021, 12:51:25 PM Error: M92: Response timeout: CAN addr 1, req type 6042, RID=5
                1/15/2021, 12:51:24 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
                1/15/2021, 12:51:24 PM Error: M350: Response timeout: CAN addr 1, req type 6042, RID=4
                1/15/2021, 12:51:23 PM Error: M584: Response timeout: CAN addr 1, req type 6042, RID=3
                1/15/2021, 12:51:23 PM Warning: Discarded msg src=1 typ=4510 RID=4095 exp 4
                  I would suggest trying a fresh download and re-image of DuetPi on your Pi SD card followed by a sudo apt update/upgrade. Seems like you may be using the image that came on the card with the Duet3?
                  https://pkg.duet3d.com/DuetPi-lite.zip
                  https://pkg.duet3d.com/DuetPi.zip
                    cdthomas9
                    Yes, I was. I've run the updates and upgrades since though. Is that something that should be done every so often? Reimage the SD card to the latest DuetPi?
                      Phaedrux Moderator @cdthomas9
                      @cdthomas9 No, but the image was updated since and re-imaging has solved problems for others in the past, so worth a shot.
                        cdthomas9
                        I just ran M997 B1 to manually force the 3HC to update to 3.2, and it looks like that fixed it
                          cdthomas9
                          Can I run a PID tuning on the heater attached to the 3HC now? I remember I couldn't before, wasn't sure if 3.2 fixed it
                            @cdthomas9 the heater tuning algorithm has been updated in 3.2, which paves the way for tuning on tool boards and expansions in 3.3 I believe.
                            From your first post with the M997 error message I thought you had already tried to manually update it.
                              cdthomas9
                              I did, but I wasn't trying to run the expansion board directly or separately. I was letting it run through and update everything in bulk, at least I think I was...
                                cdthomas9
                                I ran a M997 to update all firmware, thinking that the command would run through the main board and expansion boards
                                  Ah ok. Well glad it's sorted out. Now that you're on a full release with all boards synced the sudo apt update should work going forward.
                                    cdthomas9
                                    Thanks! What was the file it was looking for? the SBC iap file? I saw an SD iap file but not that one. I couldn't find that anywhere
                                      The SBC IAP file would come from doing Sudo apt update/upgrade I believe
                                        dc42 administrators @cdthomas9
                                        The IAP files are needed when updating main board firmware versions. They are not needed to update the 3HC or other expansion or tool board firmware.
                                          cdthomas9
                                          Thanks for all of your help! I appreciate your time and assistance getting me back up and running.
