    Extruder feed just 0/1
    558
    • CedricEundefined
      CedricE
      Hey together,
      this ist my "second" post here, the first I didn't sent, because I got the answer while writing by myself πŸ€ͺ
      But today I can't solve a problem.
      I'm using a Duet 2 Wifi on a kartesian printer to build a WAAM-machine. It will use a MIG/MAG welding torch to print near net shape models in metal.
      The printer runs gcode from Cura now, and in next step, I want to give the welding machine a signal to start the torch.
      Does anybody have an idea, how to do this?
      In Cura I told it would be a usual stepper driven extruder and I tried to grab a signal from the expension breakout bord and also from the Duet 2 Wifi, but this are puls signals, right? How to get a normal off/on signal?
      Or is this way a wrong one and is there an easier?
      In best case, I'd get a 12V on/off signal πŸ˜… but a 3.3V or 5V would be nice too 😊
      I hope you can help me!
      Thank you very much and have a nice evening!
      Cedric
        What are you actually trying to switch on and off? How is it connected?
        CedricEundefined 1 Reply Last reply Reply Quote 1
        • Vetiundefined
          Veti
          maybe you are looking for CNC mode?
          https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine
          • CedricEundefined
            CedricE @Phaedrux
            @Phaedrux said in Extruder feed just 0/1:
            Hey,
            I try to switch on and off the welding torch. This is usually a hand triggered machine with a microswitch. There is a 12V circle and if this is closed, the machine "fires". I plan to go with 12v-Duet-controlled into this circle to start and stop the welding torch.
              I think https://duet3d.dozuki.com/Wiki/Gcode#Section_M571_Set_output_on_extrude should meet your needs.
              • CedricEundefined
                CedricE
                @Veti said in Extruder feed just 0/1:
                Maybe I'm looking for this, I don't know πŸ€ͺ but I'll check it, Thank you!
                • CedricEundefined
                  CedricE @dc42
                  @dc42 said in Extruder feed just 0/1:
                  I think that's it, thank you very much! 😊 I'll try it tomorrow!
                  Are there a few words you can say about
                  • how to know which pin is which number? In pin out grafic I can't see this, right?
                  • which pins I could use? When I take a look to pin out, I'd say there are only the pwm fan output usable? Or are there some more?
                  Thank you!
                  • CedricEundefined
                    CedricE
                    I love this board for its perfect documentation!
                    https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins#Section_Logical_pin_numbers
                    • CedricEundefined
                      CedricE
                      This post is deleted!
                      • CedricEundefined
                        CedricE
                        Hey together,
                        that wasn't succesful today...
                        I don't get a clear signal out of the board, and I can't find a mistake... Maybe I don't see something or do something wrong?
                        I try to geht 0/1 out on pin 64...
                        Like this:
                        ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 12 2020 14:09:27 GMT+0100 (MitteleuropΓ€ische Normalzeit)
                        G90                            ; send absolute coordinates...
                        M83                            ; ...but relative extruder moves
                        M550 P"My Printer"             ; set printer name
                        M575 P1 B57600 S1 ;Set baud rate Duet Board.
                        M575 P0 B57600 S1 ;Set baud rate USB
                        M552 S1                        ; enable network
                        M586 P0 S1                     ; enable HTTP
                        M569 P3 S1                     ; physical drive 3 goes forwards
                        M569 P5 S0                     ; physical drive 5 goes backwards
                        M569 P6 S0                     ; physical drive 6 goes backwards
                        M569 P7 S1                     ; physical drive 7 goes forwards
                        M569 P8 S0                     ; physical drive 8 goes backwards
                        M584 X5:6 Y8 Z7 E3               ; set drive mapping
                        M350 X1 Y1 Z16 I1            ; configure microstepping with interpolation
                        M92 X160.00 Y160.00 Z160.00      ; set steps per mm
                        M566 X900.00 Y900.00 Z60.00    ; set maximum instantaneous speed changes (mm/min)
                        M203 X1000.00 Y2000.00 Z1000.00 ; set maximum speeds (mm/min)
                        M201 X200.00 Y200.00 Z20.00    ; set accelerations (mm/s^2)
                        M84 S30                        ; Set idle timeout
                        M208 X0 Y0 Z0 S1               ; set axis minima
                        M208 X900 Y1200 Z300 S0         ; set axis maxima
                        M574 X1 Y1 Z1 S1                  ; set active high endstops
                        M558 P0 H5 F120 T6000          ; disable Z probe but set dive height, probe speed and travel speed
                        M557 X15:215 Y15:195 S20       ; define mesh grid
                        M140 H-1                       ; disable heated bed
                        M563 P0 D0 F0                           ; define tool 0
                        G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                        G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                        M571 P64 S1
                        is only for checking, if the extruder rotates, if I can get a signal
                        M571 P64 S1
                        is that the right way to use M571?
                        Im using this gcode
                        ;FLAVOR:RepRap
                        ;TIME:492
                        ;Filament used: 2.23337m
                        ;Layer height: 1
                        ;MINX:313
                        ;MINY:435.5
                        ;MINZ:1
                        ;MAXX:587
                        ;MAXY:764.5
                        ;MAXZ:2.564
                        ;Generated with Cura_SteamEngine 4.6.2
                        T0
                        M82 ;absolute extrusion mode
                        G28 ;Home
                        G1 Z15.0 F6000 ;Move the torch high 15mm
                        M83 ;relative extrusion mode
                        G1 F1500 E-6.5
                        ;LAYER_COUNT:2
                        ;LAYER:0
                        M107
                        ;MESH:500x600x5.stl
                        G0 F3000 X313.1 Y764.4 Z1
                        ;TYPE:WALL-OUTER
                        G1 F1500 E6.5
                        G1 F900 X586.9 Y764.4 E115.145
                        G1 X586.9 Y435.6 E138.27492
                        G1 X313.1 Y435.6 E115.145
                        G1 X313.1 Y764.4 E138.27492
                        G0 F3000 X313.6 Y764.4
                        G0 X313.6 Y764.5
                        G0 X586.9 Y764.4
                        G0 X586.9 Y764.5
                        G1 F900 X313.1 Y764.5 E11.5145
                        G1 X313 Y764.5 E0.02356
                        G1 X313 Y764.4 E0.02356
                        G1 X313 Y435.6 E13.82749
                        G1 X313 Y435.5 E0.02356
                        G1 X313.1 Y435.5 E0.02356
                        G1 X586.9 Y435.5 E11.5145
                        G1 X587 Y435.5 E0.02356
                        G1 X587 Y435.6 E0.02356
                        G1 X587 Y764.4 E13.82749
                        G1 X587 Y764.5 E0.02356
                        G1 X586.9 Y764.5 E0.02356
                        G0 F3000 X586.4 Y764.5
                        ;MESH:NONMESH
                        G0 F600 X586.4 Y764.5 Z2
                        G0 F3000 X586.4 Y764.4
                        G0 X313.07 Y764.43
                        G0 X313 Y764.5
                        ;TIME_ELAPSED:189.624310
                        ;LAYER:1
                        M106 S255
                        ;TYPE:WALL-OUTER
                        ;MESH:500x600x5.stl
                        G1 F900 X313 Y435.5 E138.35903
                        G1 X587 Y435.5 E115.2291
                        G1 X587 Y764.5 E138.35903
                        G1 X313 Y764.5 E115.2291
                        G0 F3000 X313 Y764.5
                        G1 F900 X313 Y435.5 Z2.154 E138.35905
                        G1 X587 Y435.5 Z2.282 E115.22912
                        G1 X587 Y764.5 Z2.436 E138.35905
                        G1 X313 Y764.5 Z2.564 E115.22912
                        G1 X313 Y435.5 E96.85132
                        G1 X587 Y435.5 E57.61455
                        G1 X587 Y764.5
                        ;TIME_ELAPSED:492.924824
                        G1 F1500 E-6.5
                        M107
                        M84
                        Which voltage I would measure, if it would work? 3.3V right?
                        I tried using pin 20 before, like here https://forum.duet3d.com/topic/7822/m571-to-turn-on-fan-0-everytime-the-extruder-is-started/3 but I dont want to get a pwm signal. If i write
                        M106 P0 I-1
                        M571 P20  S1
                        I'd get a constant signal, right? But it doesn't work, too...
                        Or is writing M571 in config generally wrong? 😡
                        Thank you and have a relaxed day!
                        PS: wanted to correct some words and now its spaaam 😒
                          Using pins gets a lot simpler with RRF3 and based on your config.g it looks like you're still using RRF2. Check your firmware version with M115.
                          If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                          That will get your firmware and DWC up to date.
                          https://configtool.reprapfirmware.org/Start
                          For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                          You can learn about how pins are defined and named here:
                          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
                          CedricEundefined 1 Reply Last reply Reply Quote 0
                          • CedricEundefined
                            CedricE @Phaedrux
                            @Phaedrux
                            Thank you for showing me the way to make a safe update! I was a little bit scared to crash my system when i upload a wrong file from github πŸ˜•
                            but it worked perfectly!
                            I have now firmware version 3 and I understood the "new" pin names, but I dont have succes to get a signal with M571...
                            M950 P0 C"fan0"
                            M571 P"fan0" S1
                            this above doesn't work...
                            M950 P0 C"connsd.encsw"
                            M571 P"connsd.encsw" S1
                            ...doesn't work...
                            M571 P"0" S1
                            ...doesn't work...
                            is it generally the right way to put M950 and M571 in the end of config.g?
                            Or should it be in the beginning of gcode?
                            I think I started print aboout 100 times now and I really don't now what to try now 😐
                              M571 P0 S1 without the quotes around the 0 should work I think
                              • CedricEundefined
                                CedricE @Phaedrux
                                @Phaedrux
                                Hey, not atm...
                                Only
                                M571 P"bedheat" S1
                                is working.
                                But no problem, I ordered optocoupler now for 24v and get other pins working I'll try another time.
                                Thank you very much for your help!
                                  Ah sorry, when I was looking at it bleary eyed this morning I mistook the command.
                                  https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M571_Set_output_on_extrude
