Duet3 6CH + 3CH expansion board - Missing steps.
@evomotors said in Duet3 6CH + 3CH expansion board - Missing steps.:
Do you need a beta tester?
always welcome.
the firmware will be available for all here
https://github.com/Duet3D/RepRapFirmware/releases -
@dc42 Any updates? I guess there some roadblocks with other issues.
@dc42 said in Duet3 6CH + 3CH expansion board - Missing steps.:
@evomotors, https://forum.duet3d.com/topic/20991/early-rrf-3-3beta-files-available
Issue still exists after 3.3beta install. Visually no difference.
This is after starting and canceling print:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G Used output buffers: 1 of 40 (15 max) === RTOS === Static ram: 149772 Dynamic ram: 64248 of which 104 recycled Never used RAM 140548, free system stack 126 words Tasks: Linux(ready,141) HEAT(blocked,299) CanReceiv(blocked,893) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,52) MAIN(running,613) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:20:29 ago, cause: power up Last software reset details not available Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 23.3, current 35.4, max 35.6 Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 71266, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/243 Driver 1: position 8428, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/248 Driver 2: position 1039, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/269 Driver 3: position 0, standstill, reads 15770, writes 24 timeouts 0, SG min/max 0/267 Driver 4: position 0, standstill, reads 15783, writes 11 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 15783, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-01-16 15:50:32 Slowest loop: 178.46ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 700263ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 2249, completed moves 2249, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.3 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 7096, send timeouts 0, received 38, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 414, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 44700/44700 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c478 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 31.34 Maximum length of RX/TX data transfers: 2656/1664
M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18) Bootloader ID: not available Never used RAM 154492, free system stack 166 words HEAT 92 CanAsync 92 CanRecv 86 TMC 30 MAIN 306 AIN 259 Last reset 00:21:14 ago, cause: power up Last software reset data not available Driver 0: position -343134, 160.0 steps/mm, standstill, reads 45658, writes 24 timeouts 0, SG min/max 0/218, steps req 1681012 done 1337262 Driver 1: position -74772, 160.0 steps/mm, standstill, reads 45661, writes 24 timeouts 0, SG min/max 0/349, steps req 1442638 done 1203360 Driver 2: position 5964, 172.0 steps/mm, standstill, reads 45669, writes 20 timeouts 0, SG min/max 0/198, steps req 32691 done 32719 Moves scheduled 2198, completed 2198, in progress 0, hiccups 185, step errors 0 Peak sync jitter 14, peak Rx sync delay 183, resyncs 0, no step interrupt scheduled VIN: 24.7V, V12: 12.3V MCU temperature: min 43.8C, current 44.0C, max 44.2C Ticks since heat task active 246, ADC conversions started 1274238, completed 1274236, timed out 0 Last sensors broadcast 0x00000000 found 0 0 ticks ago, loop time 0 CAN messages queued 58, send timeouts 0, received 13653, lost 0, free buffers 36, error reg 11004e
And this is after just after boot before printing:
m122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18) Bootloader ID: not available Never used RAM 154420, free system stack 200 words HEAT 79 CanAsync 92 CanRecv 86 TMC 64 MAIN 298 AIN 259 Last reset 00:00:49 ago, cause: software Last software reset data not available Driver 0: position 0, 160.0 steps/mm, standstill, reads 49081, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0 Driver 1: position 0, 160.0 steps/mm, standstill, reads 49083, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0 Driver 2: position 0, 172.0 steps/mm, standstill, reads 49087, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0 Peak sync jitter 11, peak Rx sync delay 181, resyncs 1, no step interrupt scheduled VIN: 24.7V, V12: 12.3V MCU temperature: min 43.8C, current 43.8C, max 44.0C Ticks since heat task active 236, ADC conversions started 49228, completed 49226, timed out 0 Last sensors broadcast 0x00000000 found 0 240 ticks ago, loop time 0 CAN messages queued 60, send timeouts 3, received 403, lost 0, free buffers 36, error reg 11004f
Thanks, from the M122 B1 report there's evidently still an issue with steps being lost on the 3HC.
Have you already posted your config.g and the GCode file somewhere?
Yes, it is the same configuration and stl file as posted above in this thread
https://forum.duet3d.com/topic/20713/duet3-6ch-3ch-expansion-board-missing-steps/79?_=1610818681447
The config is where XY connected to expansion board
Thanks, I'll run those files on my bench system. I guess I should have done that earlier, rather than assuming that the bug that Tony and I reproduced was the one that affected your machine.
Let me know if you need me to run some other tests.
It's running. So far I am seeing the extruder have more reported steps than commanded steps, but X and Y doing exactly the correct number of steps.
It's occurred to me that any homing commands or other G1 H1 moves will mess up the step count, making steps done be less than steps requested. Does your cancel.g file have a homing command in it?
No, no homing in cancel.g
I did another print with print and move speed 40mm/s . Still the same issue. Is your kinematics the same? My is CoreXY
I don't have cancel.g -
This was longer run on slow speeds.
M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18) Bootloader ID: not available Never used RAM 154420, free system stack 164 words HEAT 92 CanAsync 92 CanRecv 86 TMC 30 MAIN 282 AIN 259 Last reset 03:11:52 ago, cause: power up Last software reset data not available Driver 0: position -687060, 160.0 steps/mm, standstill, reads 32218, writes 22 timeouts 0, SG min/max 0/622, steps req 7128898 done 6785821 Driver 1: position -104279, 160.0 steps/mm, standstill, reads 32217, writes 22 timeouts 0, SG min/max 0/1023, steps req 6693175 done 6454161 Driver 2: position 64560, 172.0 steps/mm, standstill, reads 32221, writes 18 timeouts 0, SG min/max 0/693, steps req 218156 done 219933 Moves scheduled 20756, completed 20756, in progress 0, hiccups 25, step errors 0 Peak sync jitter 15, peak Rx sync delay 49081, resyncs 93, no step interrupt scheduled VIN: 24.7V, V12: 12.3V MCU temperature: min 43.8C, current 43.8C, max 44.2C Ticks since heat task active 94, ADC conversions started 11512336, completed 11512334, timed out 0 Last sensors broadcast 0x00000000 found 0 98 ticks ago, loop time 0 CAN messages queued 77, send timeouts 0, received 110725, lost 356, free buffers 36, error reg 1
Thanks. I can see three possible issues in that M122 report:
The X and Y steps done are not the same as steps requested. However, I think this must be because you are doing a homing command somewhere in the sequence, because I don't see this. Perhaps your pause.g or start.g file contains a G28 command? Or you ran the initial M122 command, then homed the printer, then started the print? If you can find and remove that G28 command (or pause and run M122 after doing it) then please do that and do another run, to check that the X and Y steps are correct. To be clear, in the M122 B1 report I expect the X and Y steps done to be the same as steps reported, provided that the axes where not moving when this M122 or the previous M122 were run and there have been no G1 H1 or G1 H3 moves executed between the two M122 commands.
The extruder steps done is greater than the steps commanded. The primary reason for this is that pressure advance causes retraction steps to be generated at the end of a move that ends at low speed, and the steps commanded figure doesn't take account of that. However, if I set pressure advance to zero then the extruder steps done is slightly less than the steps commanded, which is wrong. So I think there is a rounding error in the pressure advance calculation.
Probably the most serious issue is that it has reported that some CAN messages have been lost and the peak Rx sync delay is very high. This suggests that movement messages are not being queued as fast as they are arriving. I was already planning to do that part of the move processing in a different way with lower latency, and I will now work on that urgently.
Thanks for your patience. With your permission, I will retain and use your GCode file as one of our test files.
Homing and leveling is done before every print. I will follow your directions if you need me to change something and re-test.
start.g and stop.g are empty.
This what I have in pause.g
; pause.g ; called when a print from SD card is paused ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 01 2020 21:20:26 GMT-0400 (Eastern Daylight Time) M83 ; relative extruder moves G1 E-10 F3600 ; retract 10mm of filament G91 ; relative positioning G1 Z5 F360 ; lift Z by 5mm G90 ; absolute positioning ;G1 X0 Y0 F6000 ; go to X=0 Y=0
OK, perhaps you were homing between running the first M122 and starting the print?
I do have G28 Z in bed.g and it's been calling before every print. Let me change that. But I will still need to home somehow.
@dc42 Ok , none of my homing files contains G28, it's only in bed. let me remove it and run another test.
Restarted the printer:
@dc42 not sure if it's expected fresh after restartPeak sync jitter 13, peak Rx sync delay 176
Full log:
M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18) Bootloader ID: not available Never used RAM 154492, free system stack 200 words HEAT 104 CanAsync 92 CanRecv 86 TMC 64 MAIN 282 AIN 259 Last reset 00:01:26 ago, cause: software Last software reset data not available Driver 0: position 0, 160.0 steps/mm, standstill, reads 8690, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0 Driver 1: position 0, 160.0 steps/mm, standstill, reads 8689, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0 Driver 2: position 0, 172.0 steps/mm, standstill, reads 8689, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0 Peak sync jitter 13, peak Rx sync delay 176, resyncs 0, no step interrupt scheduled VIN: 24.7V, V12: 12.3V MCU temperature: min 43.8C, current 44.0C, max 44.0C Ticks since heat task active 99, ADC conversions started 86340, completed 86340, timed out 0 Last sensors broadcast 0x00000000 found 0 103 ticks ago, loop time 0 CAN messages queued 24, send timeouts 0, received 105, lost 0, free buffers 36, error reg 4f
Now will run print
No G28 anywhere, no homing moves between M122 commands. And I only ran M122 once after pausing the print. This time I didn't stop, just pause. Still reporting missing steps.M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G Used output buffers: 1 of 40 (12 max) === RTOS === Static ram: 149772 Dynamic ram: 64248 of which 104 recycled Never used RAM 140548, free system stack 130 words Tasks: Linux(ready,141) HEAT(blocked,299) CanReceiv(blocked,893) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,52) MAIN(running,655) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:30:20 ago, cause: power up Last software reset at 2021-01-16 20:06, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 140596, slot 1 Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x00000038 SP 0x204235e8 Task MAIN Freestk 1658 ok Stack: 00000000 00000001 00000001 00000000 20423633 0046dd2d 0046d97c 61010000 2042ad78 00000000 00000000 0046dd37 00000000 00000000 3ca3d70a 0000000a 4374da1d 2042b29c 00000000 00000001 00000000 0046d9e7 2042b29c fffc0000 003fffff 0046dd27 00000000 Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 35.0, current 37.3, max 37.4 Supply voltage: min 24.0, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0 Driver 0: position 79788, standstill, reads 18682, writes 3 timeouts 0, SG min/max 0/240 Driver 1: position -219, standstill, reads 18682, writes 3 timeouts 0, SG min/max 0/240 Driver 2: position 1321, standstill, reads 18682, writes 3 timeouts 0, SG min/max 0/240 Driver 3: position 0, standstill, reads 18682, writes 3 timeouts 0, SG min/max 0/254 Driver 4: position 0, standstill, reads 18685, writes 0 timeouts 0, SG min/max not available Driver 5: position 0, standstill, reads 18684, writes 0 timeouts 0, SG min/max not available Date/time: 2021-01-16 20:36:44 Slowest loop: 183.43ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 768639ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 13893, completed moves 13893, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.3 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 20932, send timeouts 0, received 67, lost 0, longest wait 19ms for reply type 6024, peak Tx sync delay 387, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 4299/4299 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c478 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 38.79 Maximum length of RX/TX data transfers: 3032/1688 File /opt/dsf/sd/gcodes/ZR_BearingTopMount_FR.gcode is selected, paused
M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18) Bootloader ID: not available Never used RAM 154492, free system stack 165 words HEAT 92 CanAsync 92 CanRecv 86 TMC 30 MAIN 274 AIN 259 Last reset 00:30:25 ago, cause: software Last software reset data not available Driver 0: position -252890, 160.0 steps/mm, standstill, reads 47021, writes 1 timeouts 0, SG min/max 0/431, steps req 4754028 done 4495266 Driver 1: position 11122, 160.0 steps/mm, standstill, reads 47021, writes 1 timeouts 0, SG min/max 0/1023, steps req 4516310 done 4257548 Driver 2: position 43107, 172.0 steps/mm, standstill, reads 47022, writes 1 timeouts 0, SG min/max 0/609, steps req 146093 done 148150 Moves scheduled 13764, completed 13764, in progress 0, hiccups 462, step errors 0 Peak sync jitter 15, peak Rx sync delay 48876, resyncs 16, no step interrupt scheduled VIN: 24.7V, V12: 12.3V MCU temperature: min 43.8C, current 44.0C, max 44.2C Ticks since heat task active 148, ADC conversions started 1825390, completed 1825388, timed out 0 Last sensors broadcast 0x00000000 found 0 152 ticks ago, loop time 0 CAN messages queued 43, send timeouts 0, received 29446, lost 76, free buffers 36, error reg 24
