    Duet3 6CH + 3CH expansion board - Missing steps.
    153
    8.7k
    • hackinistratorundefined
      hackinistrator @deckingman
      @deckingman sure , i watched the vid.
      i'm not sure if the issue occurs at random time.
      if you check the vid , you can see the printer completed pretty fast accel moves without issues while moving on XY plane .
      the issue occurred when it was making fast diagonal move - single motor running .
      what is the default motor current on those drivers anyways ?
      maybe its a good idea to try and reduce motor current on exp. board to very low value and see if it has any effect .
      there are no CAN errors so i don't see how it can be comm. error .
        T3P3Tony administrators @hackinistrator
        @hackinistrator there is some timing jitter (as @dc42 has pointed out) that is not currently reported in 3.2.
        @evomotors thanks for all the work in detailing the problem, we are working on it!
        • evomotorsundefined
          evomotors @dc42
          @dc42 @T3P3Tony
          Thank you for your hard work. Waiting to test the changes.
            I am pleased to report that we have made substantial progress on this issue. In addition to fixing the CAN clock jitter, we have identified and fixed an issue that could cause whole moves to be abandoned on CAN-connected expansion boards. We have only been able to reproduce this using high step rates and short moves, however the cause of the issue (floating point rounding error) could conceivably happen at lower step rates too.
            I expect to provide unofficial 3.3beta versions of all firmwares tomorrow.
            Luke'sLaboratoryundefined evomotorsundefined 2 Replies Last reply Reply Quote 2
            • Luke'sLaboratoryundefined
              Luke'sLaboratory @dc42
              @dc42 Holy crap! Big if true!!!!!! I can't wait to try out the firmware to see if it solves my issues!
              Luke
              http://lukeslab.online
                evomotors @dc42
                Do you need a beta tester? 🙂
                • Vetiundefined
                  Veti @evomotors
                  @evomotors said in Duet3 6CH + 3CH expansion board - Missing steps.:
                  always welcome.
                  the firmware will be available for all here
                  https://github.com/Duet3D/RepRapFirmware/releases
                    evomotors
                    @dc42 Any updates? I guess there some roadblocks with other issues.
                      dc42 administrators @evomotors
                      @evomotors, https://forum.duet3d.com/topic/20991/early-rrf-3-3beta-files-available
                      evomotorsundefined 1 Reply Last reply Reply Quote 0
                        evomotors @dc42
                        @dc42 said in Duet3 6CH + 3CH expansion board - Missing steps.:
                        Issue still exists after 3.3beta install. Visually no difference.
                        This is after starting and canceling print:
                        M122
                        RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode)
                        Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G
                        Used output buffers: 1 of 40 (15 max)
                        Static ram: 149772
                        Dynamic ram: 64248 of which 104 recycled
                        Never used RAM 140548, free system stack 126 words
                        Tasks: Linux(ready,141) HEAT(blocked,299) CanReceiv(blocked,893) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,52) MAIN(running,613) IDLE(ready,19)
                        Owned mutexes: HTTP(MAIN)
                        Last reset 00:20:29 ago, cause: power up
                        Last software reset details not available
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        Aux1 errors 0,0,0
                        MCU temperature: min 23.3, current 35.4, max 35.6
                        Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                        Driver 0: position 71266, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/243
                        Driver 1: position 8428, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/248
                        Driver 2: position 1039, standstill, reads 15769, writes 24 timeouts 0, SG min/max 0/269
                        Driver 3: position 0, standstill, reads 15770, writes 24 timeouts 0, SG min/max 0/267
                        Driver 4: position 0, standstill, reads 15783, writes 11 timeouts 0, SG min/max 0/0
                        Driver 5: position 0, standstill, reads 15783, writes 11 timeouts 0, SG min/max 0/0
                        Date/time: 2021-01-16 15:50:32
                        Slowest loop: 178.46ms; fastest: 0.03ms
                        === Storage ===
                        Free file entries: 10
                        DMs created 125, maxWait 700263ms, bed compensation in use: mesh, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 2249, completed moves 2249, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                        === AuxDDARing ===
                        Heater 0 is on, I-accum = 0.4
                        Heater 1 is on, I-accum = 0.3
                        Segments left: 0
                        Movement lock held by null
                        Telnet is idle in state(s) 0
                        File* is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Queue* is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty.
                        === CAN ===
                        Messages queued 7096, send timeouts 0, received 38, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 414, free buffers 48
                        === SBC interface ===
                        State: 4, failed transfers: 0
                        Last transfer: 1ms ago
                        RX/TX seq numbers: 44700/44700
                        SPI underruns 0, overruns 0
                        Number of disconnects: 0, IAP RAM available 0x2c478
                        Buffer RX/TX: 0/0-0
                        === Duet Control Server ===
                        Duet Control Server v3.2.0
                        Code buffer space: 4096
                        Full transfers per second: 31.34
                        Maximum length of RX/TX data transfers: 2656/1664
                        M122 B1
                        Diagnostics for board 1:
                        Duet EXP3HC firmware version 3.3beta (2021-01-16 08:18:18)
                        Bootloader ID: not available
                        Never used RAM 154492, free system stack 166 words
                        HEAT 92 CanAsync 92 CanRecv 86 TMC 30 MAIN 306 AIN 259
                        Last reset 00:21:14 ago, cause: power up
                        Last software reset data not available
                        Driver 0: position -343134, 160.0 steps/mm,  standstill, reads 45658, writes 24 timeouts 0, SG min/max 0/218, steps req 1681012 done 1337262
                        Driver 1: position -74772, 160.0 steps/mm,  standstill, reads 45661, writes 24 timeouts 0, SG min/max 0/349, steps req 1442638 done 1203360
                        Driver 2: position 5964, 172.0 steps/mm,  standstill, reads 45669, writes 20 timeouts 0, SG min/max 0/198, steps req 32691 done 32719
                        Moves scheduled 2198, completed 2198, in progress 0, hiccups 185, step errors 0
                        Peak sync jitter 14, peak Rx sync delay 183, resyncs 0, no step interrupt scheduled
                        VIN: 24.7V, V12: 12.3V
                        MCU temperature: min 43.8C, current 44.0C, max 44.2C
                        Ticks since heat task active 246, ADC conversions started 1274238, completed 1274236, timed out 0
                        Last sensors broadcast 0x00000000 found 0 0 ticks ago, loop time 0
                        CAN messages queued 58, send timeouts 0, received 13653, lost 0, free buffers 36, error reg 11004e
                        And this is after just after boot before printing:
                        m122 B1
                        Never used RAM 154420, free system stack 200 words
                        HEAT 79 CanAsync 92 CanRecv 86 TMC 64 MAIN 298 AIN 259
                        Last reset 00:00:49 ago, cause: software
                        Driver 0: position 0, 160.0 steps/mm,  standstill, reads 49081, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0
                        Driver 1: position 0, 160.0 steps/mm,  standstill, reads 49083, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0
                        Driver 2: position 0, 172.0 steps/mm,  standstill, reads 49087, writes 23 timeouts 0, SG min/max 0/0, steps req 0 done 0
                        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0
                        Peak sync jitter 11, peak Rx sync delay 181, resyncs 1, no step interrupt scheduled
                        MCU temperature: min 43.8C, current 43.8C, max 44.0C
                        Ticks since heat task active 236, ADC conversions started 49228, completed 49226, timed out 0
                        Last sensors broadcast 0x00000000 found 0 240 ticks ago, loop time 0
                        CAN messages queued 60, send timeouts 3, received 403, lost 0, free buffers 36, error reg 11004f
                          Thanks, from the M122 B1 report there's evidently still an issue with steps being lost on the 3HC.
                          Have you already posted your config.g and the GCode file somewhere?
                            evomotors @dc42
                            Yes, it is the same configuration and stl file as posted above in this thread
                            https://forum.duet3d.com/topic/20713/duet3-6ch-3ch-expansion-board-missing-steps/79?_=1610818681447
                            The config is where XY connected to expansion board
                              Thanks, I'll run those files on my bench system. I guess I should have done that earlier, rather than assuming that the bug that Tony and I reproduced was the one that affected your machine.
                                evomotors @dc42
                                Let me know if you need me to run some other tests.
                                  It's running. So far I am seeing the extruder have more reported steps than commanded steps, but X and Y doing exactly the correct number of steps.
                                  It's occurred to me that any homing commands or other G1 H1 moves will mess up the step count, making steps done be less than steps requested. Does your cancel.g file have a homing command in it?
                                  evomotorsundefined 2 Replies Last reply Reply Quote 0
                                    evomotors @dc42
                                    No, no homing in cancel.g
                                    I did another print with print and move speed 40mm/s . Still the same issue. Is your kinematics the same? My is CoreXY
                                      evomotors @dc42
                                      I don't have cancel.g
                                        evomotors
                                        This was longer run on slow speeds.
                                        M122 B1
                                        Never used RAM 154420, free system stack 164 words
                                        HEAT 92 CanAsync 92 CanRecv 86 TMC 30 MAIN 282 AIN 259
                                        Last reset 03:11:52 ago, cause: power up
                                        Driver 0: position -687060, 160.0 steps/mm,  standstill, reads 32218, writes 22 timeouts 0, SG min/max 0/622, steps req 7128898 done 6785821
                                        Driver 1: position -104279, 160.0 steps/mm,  standstill, reads 32217, writes 22 timeouts 0, SG min/max 0/1023, steps req 6693175 done 6454161
                                        Driver 2: position 64560, 172.0 steps/mm,  standstill, reads 32221, writes 18 timeouts 0, SG min/max 0/693, steps req 218156 done 219933
                                        Moves scheduled 20756, completed 20756, in progress 0, hiccups 25, step errors 0
                                        Peak sync jitter 15, peak Rx sync delay 49081, resyncs 93, no step interrupt scheduled
                                        MCU temperature: min 43.8C, current 43.8C, max 44.2C
                                        Ticks since heat task active 94, ADC conversions started 11512336, completed 11512334, timed out 0
                                        Last sensors broadcast 0x00000000 found 0 98 ticks ago, loop time 0
                                        CAN messages queued 77, send timeouts 0, received 110725, lost 356, free buffers 36, error reg 1
                                          Thanks. I can see three possible issues in that M122 report:
                                          1. The X and Y steps done are not the same as steps requested. However, I think this must be because you are doing a homing command somewhere in the sequence, because I don't see this. Perhaps your pause.g or start.g file contains a G28 command? Or you ran the initial M122 command, then homed the printer, then started the print? If you can find and remove that G28 command (or pause and run M122 after doing it) then please do that and do another run, to check that the X and Y steps are correct. To be clear, in the M122 B1 report I expect the X and Y steps done to be the same as steps reported, provided that the axes where not moving when this M122 or the previous M122 were run and there have been no G1 H1 or G1 H3 moves executed between the two M122 commands.
                                          2. The extruder steps done is greater than the steps commanded. The primary reason for this is that pressure advance causes retraction steps to be generated at the end of a move that ends at low speed, and the steps commanded figure doesn't take account of that. However, if I set pressure advance to zero then the extruder steps done is slightly less than the steps commanded, which is wrong. So I think there is a rounding error in the pressure advance calculation.
                                          3. Probably the most serious issue is that it has reported that some CAN messages have been lost and the peak Rx sync delay is very high. This suggests that movement messages are not being queued as fast as they are arriving. I was already planning to do that part of the move processing in a different way with lower latency, and I will now work on that urgently.
                                          Thanks for your patience. With your permission, I will retain and use your GCode file as one of our test files.
                                            evomotors @dc42
                                            Homing and leveling is done before every print. I will follow your directions if you need me to change something and re-test.
