    Duet 3 mini 5+ Did i get a dud? Wifi not working.
    609
    • Alucardiundefined
      Alucardi
      I have followed the guide several times but i wont connect to my wifi. After running M552 S1 i get alot of "WiFi reported error: network scan failed" spammed but after a while i get "WiFi module is connected to access point , IP address 255.255.255.255".
      But it is NOT connected to my wifi, the led is not blue either. Running firmware FIRMWARE_NAME: "RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-beta3.2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-11-15"
      • fcwiltundefined
        fcwilt
        What does your config.g file look like?
        What does M587 report?
        • Alucardiundefined
          Alucardi
          Just for testing purpose i tried to make a guest network and that works fine. What could be the issue?
          • gloomyandyundefined
            gloomyandy
            Do you have any other Duet3D boards connected to the same WiFi network?
            Enabling WiFi debug using M111 may provide a little more information as to what is going on.
            • idaho creatorundefined
              idaho creator
              I get this problem every so often as well. It happens on about every 2-3 power is turned off then on.
              ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 11 2021 23:48:34 GMT-0700 (Mountain Standard Time)
              M550 P"badass printer" ; set printer name
              ;M587 s"notyours" P"*************"
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              Stephen6309undefined 1 Reply Last reply Reply Quote 0
              • Stephen6309undefined
                Stephen6309 @idaho creator
                For a while I been having wifi problems with my Duets, they would only work in a few locations. Router in same room as the printers. I have an ASUS RT-AC56, recently the mesh wifi died and a reboot of the router fixed it, and the Duet wifi problems disappeared at the same time.
                • fcwiltundefined
                  fcwilt @Alucardi
                  @Alucardi said in Duet 3 mini 5+ Did i get a dud? Wifi not working.:
                  If would be helpful if you would post the results of running M587.
                  And what do you mean by "guest network"?
                  Alucardiundefined 1 Reply Last reply Reply Quote 0
                  • Alucardiundefined
                    Alucardi @fcwilt
                    @fcwilt guest network is just that. Most routers have the option of setting up a guest network.
                    I did set it up just like a full network with full access.
                    After it connected to that I deleted the guest network and it connects fine to my regular network.
                    Must have bin some glitch. Either in my mesh system (even though I rebooted it several
                    Times) or in the card.
                      Once you're connected to DWC, upload the 3.2 final release zip file to the system tab and then check that the firmware and DWC files are updated. If it doesn't apply the firmware the first time, upload it again.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
                      • fcwiltundefined
                        fcwilt @Alucardi
                        Got it.
                        That type of network typically is isolated from other computers on your local network.
                        It's fine for an outgoing connection to the Internet but that's about it.
                        • Vetiundefined
                          Veti
                          see if you have
                          802.11w Management Frame Protection
                          enabled.
                          this can cause problems with some clients
                          • Alucardiundefined
                            Alucardi @Veti
                            @Veti I will take a lol at that when I get home. My duet 2 WiFi connected fine though without this hassle before.
