    423
    99.0k
    • kraegarundefined
      kraegar
      I updated my piezo mount: http://www.thingiverse.com/thing:2268205
      The changes might be helpful to others. Basically I've learned that you can make the spacer above the hotend that presses on the piezo, and the ring that goes around the hotend both "full width" with just enough of a gap they slide nicely. I'm still using a nylon washer for my center spacer, but uploaded an STL for a spacer the same size. Making both of those wider added even more stability to my nozzle, but didn't lower the sensitivity at all.
      • Ad-1undefined
        Ad-1
        In the end I've modified Idris's effector to work with Hayden's mag arms at 64mm spacing. He also made some 15mm piezos for me
        Pict and details here https://www.thingiverse.com/thing:2361081/#files
        I coud only make it work in analog mode on my Duet. VR1 is at 11 and VR2 at 4 o'clock
        I'm probing on PEI at 210c hotend (Tested and is fine at 220 for 3 seconds) and 65c bed temp.
        Z offset is -0.15 and trigger value 500
        Deviation aroud 0.023
        This mesh is done on the aluminium plate.
        • DjDemonDundefined
          DjDemonD
          Looks great.
          www.precisionpiezo.co.uk
          • jrledererundefined
            jrlederer
            @dc42:
            Here's another possible configuration:
            1. Drill and tap the top end of an E3D heatsink with 3 small holes, probably M2.5 or possible M3. I hate groove mounts.
            2. Take a piezo element with the active element about 20mm diameter. Perhaps this one http://www.digikey.co.uk/product-detail/en/murata-electronics-north-america/7BB-27-4L0/490-7714-ND/4358154. Drill a central hole for the Bowden tube and collet, and 3 smaller holes around it.
            3. Attach the disk to the top of heatsink using 3 nylon screws, with a piece of insulation between the piezo and the heatsink. The purpose of the insulation is so that if the heater cartridge develops a short and makes the heatsink live, we don't get a short between the heater and the piezo.
            4. Clamp the brass surround of the piezo disc between the effector (which has a hole in it for the top of the heatsink to pass through) and a printed ring.
            For the electronics, I would take one of my IR sensors, remove the optical components, and feed the piezo into the analog input. Then program it to produce a nice clean pulse when it detects a shock. Piezos produce a good voltage from a very small mechanical shock if the load resistance is very high.
            I'd have a go at this myself, but I don't have a drill press for drilling the top of the E3D heatsink.
            David, or anyone else who may know how to answer this, you'd be helping me out of a bind I've found myself in. Once upon a time I had gotten two of DJ's new piezo sensor systems for probing accurately, but since I accidentally fried the spare i had and had to employ the second one, leaving me one more kit, though minus the circuit board with the potentiometer for tuning.
            My question is regarding the quoted text. Has anyone actually succeeded in converting an IR sensor board by dc42 into a feasible board to utilize with piezo discs? It certainly would be very helpful and much appreciated if you could explain to me how to go about converting dc's board (which, as s luck would have it, I've got four out five lying around currently so it'd be great to repurpose one to enable be to compete the second Piezo kit that's missing that very component.
            Thank you in advance for assisting me on this one.
            Cheers!
            Jonathan.
            "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
            • DjDemonDundefined
              DjDemonD
              Just to say we have stock currently of Piezo20 ready to use modules, and piezo z-probe kits (hotend or underbed use) at https://www.precisionpiezo.co.uk/shop .
              We are also selling printed part kits for both the Piezo20 Module so you can build your own (much cheaper than ready made) and the titan/titan aero piezo bracket enabling use of piezo sensing for these popular extruders (and in theory others that can be attached via this bracket).
              • whosrdaddyundefined
                whosrdaddy
                Hi Simon,
                i did some tests with the Seedstudio Grove piezzo vibration sensor with your mount.
                While it does work, it is not near sensitive enough for probing use.
                I am going to buy your board and see how it goes 🙂
                I see in your shop that I can order the board with one drilled piezzo.
                Is it possible to order the board with 2 drilled piezzos? One 20mm and one 27mm (I have a feeling the 20mm is not sensitive enough, but I could be wrong…)
                • DjDemonDundefined
                  DjDemonD
                  Yes sure leave a note on your order, or email me the order number and remind me and I'll drill 2 for you.
                    whosrdaddy
                    @DjDemonD:
                    Last question, if I buy the full kit, is it already calibrated or is that something I will need to do?
                    • DjDemonDundefined
                      DjDemonD
                      The kit is not assembled or tuned in any way, you attach the piezo, insert it in a suitable assembly, then attach endstop wires to your controller then tune the board (usually just one pot to set), its not tricky. How well it works will depend on whether the assembly mechanically works, i.e. is as firm as it can be whilst still compressing or flexing the piezo on nozzle contact, and on whether you can set it up in your firmware (easy on duet) and manage mechanical noise from your printer (use the R parameter in M558 to pause after moving to a probe point before diving to probe).
                      The Piezo20 module is ready assembled and tested and should work out of the box as long as the delivery service haven't bashed it about too much and moved the potentiometers, if they have you re-tune it in the same way as the kit board. Full instructions are on our site).
                        whosrdaddy
                        Ok, I went ahead and bought the full kit (ref Kryotech) I will see how it goes
                        /Kris
                        • DjDemonDundefined
                          DjDemonD
                          Thank you. You'll be pleasantly surprised once you start probing, its very accurate/versatile.
                          • okerchoundefined
                            okercho
                            Hi there,
                            I got the full kit yesterday, and I'm configuring it with DjDemonD groovemount for Piezo20. So far, I'm quite surprised about how this works, and it wasn't too hard to configure, however, there is something that bugs me, and I'm not sure if I'm doing something wrong, my mechanics doesn't allow to do it better or is just that I didn't tweak it fine yet.
                            I've recorded this: https://youtu.be/QJUzIwRm_js
                            You can see there that the led triggers when I push the nozzle, then I executed Z Homing, the nozzle touches the bed, and although is hard to see it in the video, the entire carriage moves slightly up a bit, then the nozzle goes down 5mm and waits. After that I requested in the web that Z goes 0, and (around second 38 in the video) the nozzle hits the bed and moves up (so it doesn't stop exactly at the bed), then I move the bed 1mm and the pressure over the hotend is released (that's the point where 0 should be). Summarizing, I'm getting 1mm Z offset consistently.
                            I've tried with different Z speeds and accelerations, and it's always like this, in fact, I've configured an offset of 1mm in my Slicer and prints really well, but I cannot stop thinking I'm doing something wrong.
                            This is my config:
                            ; PiezoSensor
                            G31 X0 Y0 Z0 P100
                            M558 P5 F200 H3 R2 X0 Y0 Z0
                            M557 X5:300 Y5:300 S50 ; Define mesh grid
                            M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X6000 Y6000 Z200 E1200 ; Set maximum speeds (mm/min)
                            M201 X900 Y900 Z150 E250 ; Set accelerations (mm/s^2)
                            Regards
                            Okercho
                            Custom Prusa i3 Hephestos with Duet Wi-Fi
                            E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                            Rebuilding Hypercube Evolution
                            • DjDemonDundefined
                              DjDemonD
                              This might be a really simple one reverse the polarity of your piezo then retune (wont be far off). I think its backwards. When you tap up it looks like it lights up when you release rather than the instant it is tapped. It will still trigger but in that clumsy way as shown in your video.
                              In M558 probably take your probing speed up a notch try F300 R you can probably get away with as little as 0.2. Youll be confident to do this when its triggered nicely.
                              The rest is fine.
                              • okerchoundefined
                                okercho
                                Thanks DjDemonD, will try it now.
                                Funny thing, I thought yesterday that the polarity was reversed and I swapped it xD.
                                Regards
                                Okercho
                                • DjDemonDundefined
                                  DjDemonD
                                  Did it make any difference?
                                  • okerchoundefined
                                    okercho
                                    No, is exactly the same… I've swapped it to be active all the time (led is ON until touch), then it touches, led goes out and the offset is still 1mm.
                                    Something I'm not sure about is that, when I do Z homing, once the nozzle touches the bed, the web interface shows 0'70 and then the bed moves to 5mm as configured:
                                    ; Lift Z relatively to current position
                                    G91
                                    G1 Z5 F6000
                                    ; Back to absolute positioning
                                    G90
                                    ; Go to first bed probe point and home the Z axis
                                    G1 X5 Y150 F6000
                                    G30
                                    G1 Z5 F100
                                    Apart from that, I've executed a series of G30 S-1 (with a G1 Z5 to move the bed before each G30), and the results are more or less the same:
                                    22:57:46Stopped at height 0.685 mm
                                    22:57:43Stopped at height 0.686 mm
                                    22:57:41Stopped at height 0.686 mm
                                    22:57:38Stopped at height 0.685 mm
                                    22:57:35Stopped at height 0.683 mm
                                    22:57:33Stopped at height 0.683 mm
                                    22:57:30Stopped at height 0.683 mm
                                    If I adjust the VR1 the stop height changes (0.6 is the lowest I got, 0.8 was the highest), but I'm not sure what means that offset... I guess is the real distance the bed forces the nozzle up.
                                    Any advice?
                                    Regards
                                    Okercho
                                    • DjDemonDundefined
                                      DjDemonD
                                      If you can measure vr1 pot resistance between a piezo pin and the pot itself, 0.4Mohm is a good setting, but 0.6Mohm or 0.8Mohm increases the sensitivity, the pots can be a little jumpy so make sure the reading is fairly stable.
                                      Determine the polarity for certain by pushing up on the hotend, if the LED changes on push up its right, if its on release its reversed.
                                      When you turn vr2 make sure its just a fraction past the point where the LED comes on and no further, this increases sensitivity even more.
                                      Make sure you have switch I1 in your M558 if you are using the board in NC mode (i..e led goes out when triggered).
                                      If your hotend is very wobbly this might be a problem as it doesn't give the piezo a firm tap on contact more of a gentle squash which generates a much less sharp rise in voltage and is harder to detect.
                                      • DjDemonDundefined
                                        DjDemonD
                                        I see something in your video which might be a problem or not, I can see some nuts between the top and bottom part of the module. These might be an issue. The idea is that the top part which has the printed groovemount, these holes need to not bind to the screws, the lower part of the module prints with holes which are 2.8mm so your can tap m3 screws into them.
                                        The disc needs to be able to be squeezed between the two parts of the module. Its only 0.2mm but unless the module can easily compress you might not be getting a full signal.
                                        If you take it off and change the assembly, reassemble it and before you mount it wire it up and make sure the led changes on the slightest tap on the bed holding it in your hand.
                                        Make sure it looks like this assembled
                                        And ensure the solder pads on the disc sit in the recess in the flange on top of the lower part.
                                        • DjDemonDundefined
                                          DjDemonD
                                          At some point I am going to do an assembly video for youtube.
                                          • okerchoundefined
                                            okercho
                                            I setup the resistance to 650 (my multimeter is at 2000k scale), but it's still the same.
                                            I've spent more time levelling my bed (never was so well levelled as per Duet!), and I've observed that in some points the touch is more gentle (the pressure upwards is less noticeable), the point that seems to be the best is the front right corner, meanwhile other points (even those quite near the screws, so is not because of the screws "pushing") the hit is the same as before.
                                            However, the bed levelling after homing Z in the corner or in the middle of the bed is more or less the same:
                                            Homing at X285 Y5
                                            Homing at X150 Y150
                                            I had the nuts there as I had problems with the printed parts (it warped so the bottom is not perfectly flat), as it seems my level is much better now, I'm going to print another set of parts and will disassemble the hotend tomorrow to remove the nuts.
                                            I had some doubts during the assembling, mainly with the pressure I should put between the parts that holds the piezo disk (at the beginning it seems that it was too close and the piezo didn't trigger at all), so a video will be much appreciated :).
                                            Anyway, thanks a lot for your answers!
                                            Regards
                                            Okercho
