    Invalid max. MCU Temperature in DWC
    Duet Web Control
    • TopperHarleyundefined
      TopperHarley
      Just a small issue i have notivced:
      Looks like the maximum value is not updated properly.
      (Duet Web Control 3.2.0)
      Best regards
      Topper Harley
      • chrishammundefined
        chrishamm administrators
        If you are on DWC 3.2, please send this from the G-code console and post the output:
        echo boards[0].mcuTemp.current
        echo boards[0].mcuTemp.min
        echo boards[0].mcuTemp.max
        AFAICS the correct fields are used DWC.
        Duet software engineer
        • achrnundefined
          achrn
          @chrishamm said in Invalid max. MCU Temperature in DWC:
          If I hover the mouse over the MCU temperature in the status box the reported maximum is less than the current temperature, but boards[0].mcuTemp.max reports a different temperature that is higher than the current temperature (i.e. that could be teh maximum temperature).
            What board do you have? If it is a Duet 3, do you have a Pi connected?
            TopperHarleyundefined achrnundefined 2 Replies Last reply Reply Quote 0
              TopperHarley @chrishamm
              @chrishamm
              Im running a Duet2 Ethernet (standalone) with RRF3.2 + DWC 3.2.
              I have tried to reproduce the issue, but this time everything looks just fine...
              • achrnundefined
                achrn @chrishamm
                @chrishamm
                Yes, it has a Pi 4, 4GB
                Board: Duet 3 MB6HC (MB6HC)
                DSF Version: 3.2.0
                Firmware: RepRapFirmware for Duet 3 MB6HC 3.2 (2021-01-05)
                Firefox 84.0.2 (64-bit) on a win 10 machine
                The box that displays when I hover mouse over the MCU temperature displays the wrong maximum value - one that is lower than the current value, and lower than the boards[0].mcuTemp.max value:
                  TopperHarley
                  @chrishamm
                  I was able to reproduce the issue:
