    Duet 2 Upgrade Prints coming out stretched
    394
    • garyd9undefined
      garyd9 @karatektus
      @karatektus
      What type of printer? Cartesian? Delta? CoreXY?
      The things to check somewhat depend on the answer to the above. I agree that using M579 to scale X and Y the same amount shouldn't be needed.
      Perhaps post a copy of your config file (config.g) to help us to examine what might be going on, but this might be as simple as calibrating the steps/mm for X and Y axis.
      karatektusundefined 1 Reply Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @karatektus
        @karatektus said in Duet 2 Upgrade Prints coming out stretched:
        well thats one hell of a dirty hack 😄
        ill give it a shot to get at least this print done. thanks.
        It's not really a hack.
        For a simple Cartesian printer you could adjust the M92 steps/mm settings.
        But that doesn't work so well with things like a CoreXY machine where both motors contribute to motion on an single axis.
        Thus M579 comes to the rescue.
        • karatektusundefined
          karatektus @garyd9
          @garyd9 said in Duet 2 Upgrade Prints coming out stretched:
          jeez. i actually forgot to mention that 😄
          It's a delta. Ill edit my first post to include that info and the config.g file.
          Edit: Well the forum doesn't allow that, so here it is:
          Printer Information: Delta Printer 300mm diameter 0.9° Steppers
          config.g:
          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Wed Jan 06 2021 12:03:41 GMT+0100 (Central European Standard Time)
          G90                                            ; send absolute coordinates...
          M83                                            ; ...but relative extruder moves
          M550 P"Reese"                                  ; set printer name
          M665 R178.07 L360.24 B150 H495 X-0.06° Y0.05°                 ; Set delta radius, diagonal rod length, printable radius and homed heights
          M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
          M551 P"rg21l7m6k"                              ; set password
          M552 S1                                        ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0 S1                                     ; physical drive 0 goes forwards
          M569 P1 S1                                     ; physical drive 1 goes forwards
          M569 P2 S1                                     ; physical drive 2 goes forwards
          M569 P3 S1                                     ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                               ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
          M92 X160.00 Y160.00 Z160.00 E415.56            ; set steps per mm
          M566 X800.00 Y800.00 Z800.00 E800.00       ; set maximum instantaneous speed changes (mm/min)
          M203 X48000.00 Y48000.00 Z48000.00 E3600.00    ; set maximum speeds (mm/min)
          M201 X800.00 Y800.00 Z800.00 E1000.00       ; set accelerations (mm/s^2)
          M906 X1500 Y1500 Z1500 E1600 I70               ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          M208 Z0 S1                                     ; set minimum Z
          M574 X2 S1 P"!xstop"                                    ; configure sensorless endstop for high end on X
          M574 Y2 S1 P"!ystop"                                    ; configure sensorless endstop for high end on Y
          M574 Z2 S1 P"!zstop"                                    ; configure sensorless endstop for high end on Z
          M558 C"^zprobe.in" P8 R0.4 F1000 H10                         ; disable Z probe but set dive height, probe speed and travel speed
          G31 P100 X0 Y0 Z-0.1
          M556 S78 X0 Y0 Z0                              ; set orthogonal axis compensation parameters
          M557 R150 S20                                   ; define mesh grid
          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
          M950 F1 C"fan1" Q200                          ; create fan 0 on pin fan0 and set its frequency
          M106 P1 C"FAN0_E0" S0.5 H1 T45                   ; set fan 0 name and value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P2 S0 H-1                                 ; set fan 1 value. Thermostatic control is turned off
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
          M579 X0.970 Y0.970
          M575 P1 S1 B57600                              ; enable support for PanelDue
          M501                                           ; load saved parameters from non-volatile memory
          garyd9undefined 1 Reply Last reply Reply Quote 1
            karatektus @fcwilt
            @fcwilt said in Duet 2 Upgrade Prints coming out stretched:
            Yeah It'll work for sure. but it doesn't fix the root problem.
            • garyd9undefined
              garyd9 @karatektus
              Check that the arm length specified in M665 is correct. Instead of checking config.g and then config-override.g, just type "m665" in the console and hit enter. That will tell you the values it's actually using (regardless of what might be in various config files.)
              If the arm length is accurate, are you doing a delta auto-calibration? What is the "S" parameter on the final G30 in your bed.g? (If it's 7 or 9, then the autocalibration will be overwriting the physical arm length you specify - which might not be what you want.)
              Please review this document: https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
              • fcwiltundefined
                fcwilt @karatektus
                The "root" problem may be a bug in the firmware or it could be something in the hardware - I don't know how you would determine that.
                I just set M92 according to the theoretical values and tweak things with M579.
                The prints come out fine.
                But since we now know you are using a delta you have other settings to consider.
                • garyd9undefined
                  garyd9
                  Your config.g doesn't show any M665 at all... Do you have that command in a config-override.g? If so, does the "L" parameter match the length of the delta diagonal arms (measured in mm)?
                    karatektus @garyd9
                    I already checked that. its a 6 factor calibration.
                    The M665 command is kinda weird. It doesnt show the rod length.
                    m665
                    Diagonals 350.000:350.000:350.000, delta radius 169.494, homed height 477.998, bed radius 150.0, X -0.251°, Y -0.014°, Z 0.000°
                    I am using a Smart effector + Haydn Huntley’s Magball delta arms which are specified at 360.24 so I figure this shouldn't be the problem.
                    garyd9undefined 1 Reply Last reply Reply Quote 0
                      karatektus @garyd9
                      both. its the third command in my config.g (guess you missed it?)and its autogenerated in the config-override
                      • garyd9undefined
                        garyd9 @karatektus
                         m665
                        That's your problem. It is showing the L parameter (Diagonals: 350) and the value is very different from 360.24.
                        It's possible there's a M665 in your config-override.g with the wrong L parameter. Just change that in the config-overide.g to be exactly what the sticker on your arms claim. Or, just run: M665 L360.24 and then re-run the auto-calibration and save it via M500
                          karatektus
                          wow.... im slightly embarrassed now... thank you! also: m500 saves my autocal so i dont have to run it everytime i homed the printer?
                          • garyd9undefined
                            garyd9 @karatektus
                            @karatektus
                            Running a delta calibration (G32) sets the calibrated values to "current"
                            M500 saves the "current" values for any temperature calibrations and delta calibrations to your config-override.g.
                            M501 (which you have at the end of your config.g) loads the values from config-override.g
                            (The reason I spelled it out like that was to ensure that your aware it writes more than just the delta calibration stuff.)
                              karatektus
                              ok got it 🙂 thanks!
