    BLtouch does not work after changing to DUEX5 board
    2.3k
      I'm beginning to think your BLTouch may be failed.
      Haggan90undefined 1 Reply Last reply Reply Quote 0
      • Haggan90undefined
        Haggan90 @Phaedrux
        @Phaedrux said in BLtouch does not work after changing to DUEX5 board:
        Dammit... couldn't there be any other reason for the bltouch to light up red all the time?
          Photo of the BLTouch? It doesn't have a trace to cut, but it also has a metal pin, so perhaps it's a very old version that requires the resistor?
          It was working on a Duex2? Do you still have the Duex2 to test with to see if it works there again?
          If you really need to return to printing you could set the probe type to 0 and use manual probing. M558 P0
          • Haggan90undefined
            Haggan90 @Phaedrux
            Problem is that I manage to connect 12VDC to 5VDC and burned the duex2 🙂
            I manage to fix the DuetWIFI but not the Duex2, that's why I bought a new Duex5. 20210119_204733.jpg
              Phaedrux Moderator @Haggan90
              @Haggan90 said in BLtouch does not work after changing to DUEX5 board:
              The BLTouch is on 5v as well...
              • Haggan90undefined
                Haggan90 @Phaedrux
                Well... that's something I had NOT thought of >.<
                But how is it still lighting up?
                  Well the led is still getting 5v but I think maybe the logic portion got fried.
                  Haggan90undefined 2 Replies Last reply Reply Quote 1
                  • Haggan90undefined
                    Haggan90
                    @dc42 Is it possible that the BLTouch got fried when I connected 12VDC on the 5VDC rail? 😃
                    • Haggan90undefined
                      Haggan90 @Phaedrux
                      @Phaedrux I ordered a new BLtouch, should be arriving today!
                      • Haggan90undefined
                        Haggan90 @Phaedrux
                        @Phaedrux Well, now I got the new BLtouch installed and everything is working again!
                        Thank you for pointing out the obvious solution 🙂
                          Glad it's working now.
