Lower bed after print is finished, cartesian XY
    brasse
    Hey 🙂 I have a CR-5 Pro, cartesian XY, that is the bed moves up and down as Z.
    Is there some clever GCODE to use to lower the bed when a print is finished, but not when the bed is already lowered a bit?
    To clarify a bit, when the print is done, i want to lower the bed to ie. 150mm, but only if the print is not lower than 150mm.
    undefined 1 Reply Last reply 23 Jan 2021, 20:13 Reply Quote 0
      fcwilt
      If you are using v3 firmware (v3.1.1, v3.2) then yes - you could use the conditional code feature to test the current position and move or not based on that.
      undefined 1 Reply Last reply 23 Jan 2021, 20:12 Reply Quote 0
        Well if you use a relative move to lower the bed it will respect the bed axis distance limit. Are you worried it will try to go lower than it physically can?
          brasse @fcwilt
          @fcwilt Oh that sounds interesting, i will look in to that 🙂
            dc42 administrators @brasse
            @brasse said in Lower bed after print is finished, cartesian XY:
            This will work if you are using RRF3:
            if move.axes[2].userPosition < 150
            G1 Z150 F1000
            Adjust the F parameter as required for your printer.
            undefined 1 Reply Last reply 24 Jan 2021, 12:52 Reply Quote 1
              brasse @Phaedrux
              @Phaedrux Yeah a bit, also a bit worried to hit the print.
              You can never be too safe 😉
                brasse @dc42
                @dc42 Oh thats clever, just what i was looking for. Thanks 🙂
                1 out of 7
