What setting/s cause this?
391
    Blacksheep99
    I'm tuning my printer. Things are going okay but I get this stretched effect at the start of a layer. It's visible on the surface of a part. Additional walls may hide it I guess?
    Is this linked to acceleration settings, retraction & could pressure advance help?
      Veti
      yes that can be caused by retraction.
      it could be to much retraction. or the filament slipping.
      it could also be a wrong thermistor setting.
      post your config.g
      undefined 1 Reply Last reply 26 Jan 2021, 09:59 Reply Quote 0
        Blacksheep99 @Veti
        @Veti
        ; Configuration file for Duet Maestro (firmware version 3)
        ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 18:02:08 GMT+0000 (Greenwich Mean Time)
        M550 P"ST3Di280 Duet" ; set printer name
        M552 P192.168.0.60 S1 ; enable network and acquire dynamic address via DHCP
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P4 S1 ; physical drive 4 goes forwards
        M584 X0 Y1 Z2 E3:4 ; set drive mapping
        M92 X91.13 Y106.84 Z1242.228 E104.76:104.76 ; set steps per mm
        M566 X1600.00 Y1600.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X-140 Y-75 Z0 S1 ; set axis minima
        M208 X165 Y75 Z150 S0 ; set axis maxima
        ;M574 Z1 S1 ; Set endstops controlled by probe
        M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
        M558 P8 C"^zprobe.in" H3 F900 T6000 ; Set Z probe type to switch and the dive height + speeds
        G31 P50 X-43 Y5 Z1.816 ;Set Z probe trigger value, offset and trigger height 1.81
        M557 X-120:120 Y-65:75 S15 ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" A"Bed Heater" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M308 S1 P"e0temp" Y"thermistor" A"Left Extruder" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
        M308 S2 P"e1temp" Y"thermistor" A"Right Extruder" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
        M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
        M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
        M143 H2 S280 ; set temperature limit for heater 2 to 280C
        M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
        M563 P0 S"Left" D0 H1 F0 ; define tool 0
        G10 P0 X14.275 Y-0.25 Z0 ; set tool 0 axis offsets
        M563 P1 S"Right" D1 H2 F0 ; define tool 1
        G10 P1 X-14.275 Y0 Z0 ; set tool 1 axis offsets
        M575 P1 S1 B57600 ;PanelDue interface
        M912 P0 S1
        M501
        M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          Veti
          print a temperature tower to see if your thermistor settings is correct.
            Blacksheep99
            Okay, Will do
              Blacksheep99
              None of them look great, hotter the better though it seems although I cannot be sure the actual temp correlates with the temp in DWC.
              FYI the PLA was only opened at the weekend although I've had it sat around for a while. On my other printer 215 is about the sweet spot for this PLA.
                Veti
                @Blacksheep99 said in What setting/s cause this?:
                if your thermistor setting is incorrect then 215 will not be real 215
                it can easily be off by 20-40c
                undefined 1 Reply Last reply 26 Jan 2021, 18:08 Reply Quote 0
                  Blacksheep99 @Veti
                  @Veti said in What setting/s cause this?:
                  The other printer is a stock Polaroid 250s so I am assuming it’s calibrated somewhat? That’s my comparison. Point taken though
                    Blacksheep99
                    Benchy using my current settings, sliced in Cura 4.8.
                    0.2layers. Printed at '235' which is too hot for PLA.
                      Veti
                      can you print this
                      https://www.thingiverse.com/thing:2080224
                      and try and calibrate your retraction with it.
                      undefined 1 Reply Last reply 27 Jan 2021, 12:55 Reply Quote 0
                        Blacksheep99 @Veti
                        @Veti
                        I think 1.6mm retraction 50mm/s looks best.
                        0, 0.5, 1 retraction
                        1.5, 1.6, 1.75, 2
                        I think 1.5mm is close but has some slight surface blobs.
                        I previously had it set at 2.5mm.
                        Note: Pressure advance disabled in config.g for these prints.
                          Veti
                          ok see if that improves the benchy. nearly 1cm difference for retraction is a lot.
                          6 out of 12
