    Scara Printer Flip X axis
    • fhoranundefined
      fhoran
      I am trying to flip the X axis of a 3D Potter SCARA printer.
      Currently it uses a left handed co-ordinate system. The printer is owned by my school but students new to 3D printing and digital fabrication find it confusing.
      I tried setting the proximal arms minimum angle to the X axis orientation I wanted but that also rotated the Y axis direction.
      Thanks in advance.
      Config file:
      ; 3D Potterbot Scara firmware Rev-1
      ; 1/11/2021
      ; Configuration file for Duet WiFi (firmware version 3.1.1)
      M550 P"Scara" ; set printer name
      ; Drives and Movment
      M569 P5 S1 R0 T4 ; Drive 5 goes reverse X
      M569 P6 S1 R0 T4 ; Drive 6 goes reverse Y
      M569 P7 S0 R0 T4 ; Drive 7 goes fowards Z
      M569 P9 S1 R0 T4 ; Drive 9 goes reverse E
      M584 X5 Y6 Z7 E9 ; set drive mapping
      M84 S30 ; Set idle timeout
      M92 X736.36 Y736.36 ; Steps/degree for proximal and distal joints 50:1Y463.63
      M350 X1 Y1 Z1 E1 I1 ; Set 1x microstepping with interpolation
      M92 Z6359.75 E42 ; Steps/mm for Z and E
      M906 X0 Y0 Z0 E0 I30 ; Set motor currents (mA) and increase idle current to 60%
      M201 X3000 Y3000 Z2000 E10000 ; Accelerations (mm/s^2)
      M203 X4000 Y4000 Z2000 E70000 ; Maximum speeds (mm/min)
      M566 X3000 Y3000 Z600 E10000 ; Maximum instant speed changes mm/minute
      M669 K4 P554 D466 A-180:181 B-157:157 C0:0:0 R100 T1 ;Set kinematics type and parameters NO DIS CASTING P535 D458.75 P555 D455
      M208 S1 X-1000 Y-1000 Z0 ; Set axis min travel
      M208 S0 X1000 Y1000 Z500 ; Set axis max travel
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z2 S1 P"!zstop" ; configure active-high endstop for high end on Z via pin zstop
      M563 S"clay" P0 D0 ; define tool 0
      M911 S22 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0 ; select first tool
      M302 P1 ; Allow cold extrudes
      M558 P0 H5 I1 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      • fhoranundefined
        fhoran
        This post is deleted!
        • fhoranundefined fhoran has marked this topic as solved
