    DueUI install not working in Standalone
    DueUI
    793
    • jnofsingerundefined
      jnofsinger
      I keep running into the error below on a brand new standalone install with RRF3.2 on a DuetWifi board.
      I used
      http://[ip of Duet]/rr_download?name=/sys/dueui_config.json
      I have no password on the duet. Can anyone point me in the right direction on what is going on? I can't get it to work.
      • gtj0undefined
        gtj0 @jnofsinger
        @jnofsinger said in DueUI install not working in Standalone:
        Can you navigate to http://[ip of Duet]/rr_download?name=/sys/dueui_config.json directly from a browser and get the json?
          jnofsinger
          yes it will download the file onto my computer.
          • gtj0undefined
            gtj0 @jnofsinger
            @jnofsinger If you look at the "Network" tab in the debugger, is it actually downloading the file or is it failing with some error code? Are you sure the file is actually valid javascript? What happens if you create just a short skeleton dueui_config.json file and try that?
              jnofsinger
              The skeleton file would just be the configuration? I am trying the standalone.json example file.
              • gtj0undefined
                gtj0 @jnofsinger
                unmodified? hmmm.
                check the network tab and i'll also check the standalone file here again.
                  jnofsinger
                  all 200 responses, but still nothing showing up on screen.
                  ![0_1611783648058_8f3b65c9-b51b-4ae1-af4f-f3cdbb6b5bf2-image.png](Uploading 100%)
                  jnofsingerundefined 1 Reply Last reply Reply Quote 0
                    jnofsinger @jnofsinger
                    images aren't uploading on responses apparently. they are all found and used... css files, fonts etc.
                    • gtj0undefined
                      gtj0 @jnofsinger
                      @jnofsinger OK, I'm testing now. How did you do the install? Upload the zip file via Duet Web Control?
                        jnofsinger
                        Yes the latest beta2 standalone and zip uploaded via duet web control
                        • gtj0undefined
                          gtj0 @jnofsinger
                          @jnofsinger I think I know what the issue is. Give me about 30 minutes and I'll have a fix up.
                          • gtj0undefined
                            gtj0
                            Grab the latest release from
                            https://github.com/gtjoseph/DueUI/releases/tag/v3.2.0
                            That should fix the issue.
                              jnofsinger @gtj0
                              @gtj0
                              Awesome it works! handful of undefined things, but i think that is to be expected.
                              Thanks for the quick turnaround... I tried for 2 days to get it working 😉
                              • gtj0undefined
                                gtj0 @jnofsinger
                                @jnofsinger No problem!
