Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
@Veti ok...i ll keep it for now
Veti, i find out i have a "G10" on tools, setting the axis offsets to 0. Could that be the problem when i was trying to define a different offset on G31 when i was calibrating my BLTouch?
On TOOLS i have this:G10 P0 X0 Y0 Z0
no the first tool should not have an offset
@Veti so... i should erase it?
no. compare to the config that the configuration generates. its there.
@Veti i a making the changes directly in the config.g
note what i wrote above
what i do in that case, is generate a config in the online configurator and have a look at that layout
@Veti yes, i know... your right but, i dont understand nothing about what the online configuration RRF asks! For instance... i am looking at it and in the heaters, in the bed, what is going to be the output? Bedheat= Inverted? e0heat?... i dont know what that means and a lot of other things in it!! Thats why i have to copy from what other people do....sorry Veti, but this is not my area of expertise, just want to have a nice and good printer working!
invert means swap the signal. so if for some reason your heater would be heating if its off, you invert the signal. unlikely that you will need it for the heaters.
@Veti allright... sinse i have a CR-10, but with a lot of upgrades in it, in the web configuration tool, i selected the ender 3, because is from creality also. I beleave a lot of things ara alike.
Ok... in the first board i change the name of the rinter, change the neasurs of the bed and the height of the printes. About the homing preferences, i didnt touched. 2º board:Drives:
Xstop;
Ystop
Zstop.Heaters:
Bed-bedheat-bedtemp
Nozzle-e0heat-e0tempZprobe (i have a bltouch):
Zprobe.in
Zprobe.mod
exp.heater7 (not sure about this one)fan mapping:
fan0
fan1
fan2could it be ok? I dont know about the bed, because i have a silicone heater that is powered with 230V and is controled by a rele.
looks ok.
the bltouch port depends on the port where you connected it
@Veti said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
looks ok.
Yes... i have it on the 4th pin near the red and the broun. I beleave is nº7
do you have an idea abou the trigger height i should give to the Bltouch?
take the value from your old config
@Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
looks ok.
I change it to heater 3... the connections are just like the ones you find here:
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch -
Done...i am now uploading the new config
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
Here's a walk through of the config tool for RRF3 and an Ender3, which is pretty similar to the CR-10.
@Phaedrux Tks.... at the momment im with other problem. Forgot to include in the new config file the access point and now, i cant get access to it!
If it was added once before the SSID should be saved on the wifi module itself and sending M552 S1 should enable the module and it will try to connect to the strongest SSID it knows about.
If it doesn't seem to be doing that you can try re-adding it. Same steps as initial connection.
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
@Phaedrux I think i messed this up... it steel giving me the message that the access point is working, and i can connect to it, but i dont know why, im not ablet to accesse the IP... "page not work"
